#31
: The reason why all electric panels are becoming common is because
: electrical systems are more reliable than vacuum, and backup is easier to : provide for everything, a second battery. It also makes more sense to : unify around a single system, instead of having a hodge-podge of two : different systems. Easier is relative. Designing a truly redundant electrical system is nontrivial and expensive in both money, weight, and complexity. Strictly speaking, you should have dual alternators, dual busses with crossover breakers, etc, etc. It's not as simple as "throwing another battery" in the tail. If the system isn't designed properly or is improperly operated, a failed system can break the other system. The nice thing about the standard six-pack is that there's redundancy built into the instruments and sources. Yes, vacuum systems are less reliable, but short of something catastrophic, they are *completely* independent. It would probably be better to transition to an electric AI and vacuum TC as "standard equipment"... or maybe electric DG and vacuum TC. Still redundancy, but the likelihood of failure goes down with the electric replacements. A vac pump going out on a standard plane (and losing *all* bank except TC) is "unpleasant" and not that uncommon. Change 2 out of 3 bank instruments to be electric, rather than vacuum and one failure isn't nearly so bad. -Cory -- ************************************************** *********************** * Cory Papenfuss * * Electrical Engineering candidate Ph.D. graduate student * * Virginia Polytechnic Institute and State University * ************************************************** *********************** |
#33
Next time you droning along, trimmed out, with Ralph or Bob or whatever his name is turned off, replace your use of the AI with the TC. Of course the DG tells you how you are doing and which way to correct, but try flying with the TC only for longer than you would normally. The experience changed my scan.
I don't know why, but I never did use the AI much. I rely on the TC, altimiter, DG, and airspeed to give me my picture, and leave the AI sort of in the background. As a result, when the AI is covered, I fly equally well. One CFI commented that I fly better on partial panel then on the full panel. Jose -- Quantum Mechanics is like this: God =does= play dice with the universe, except there's no God, and there's no dice. And maybe there's no universe. for Email, make the obvious change in the address. |
#34
Jose wrote:
Next time you droning along, trimmed out, with Ralph or Bob or whatever his name is turned off, replace your use of the AI with the TC. Of course the DG tells you how you are doing and which way to correct, but try flying with the TC only for longer than you would normally. The experience changed my scan. I don't know why, but I never did use the AI much. I rely on the TC, altimiter, DG, and airspeed to give me my picture, and leave the AI sort of in the background. As a result, when the AI is covered, I fly equally well. One CFI commented that I fly better on partial panel then on the full panel. I have much the same experience. My instrument instructor was a nut for partial panel practice, so I got really good at it. I miss the DG when it's covered up, but for the most part, I fly the TC for bank and the ASI for pitch. After all these years, I honestly can't tell you how many bars up it takes to get Vy or what bank angle it takes for a standard rate turn. |
#35
Roy Smith wrote:
: I don't know why, but I never did use the AI much. I rely on the TC, : altimiter, DG, and airspeed to give me my picture, and leave the AI sort : of in the background. As a result, when the AI is covered, I fly : equally well. One CFI commented that I fly better on partial panel then : on the full panel. : I have much the same experience. My instrument instructor was a nut : for partial panel practice, so I got really good at it. I miss the DG : when it's covered up, but for the most part, I fly the TC for bank and : the ASI for pitch. : After all these years, I honestly can't tell you how many bars up it : takes to get Vy or what bank angle it takes for a standard rate turn. Whew... I thought I was the only one! In straight/level, I rarely look at the AI except once in awhile to cross-check. For straight/level it's useless, just as the T&B/TC is for bank. It's really only good for setting up an attitude (whether it be intentional transition or an "Oh crap... I busted my altitute/heading!") -Cory -- ************************************************** *********************** * Cory Papenfuss * * Electrical Engineering candidate Ph.D. graduate student * * Virginia Polytechnic Institute and State University * ************************************************** *********************** |
#36
Jose wrote:
I don't know why, but I never did use the AI much. I rely on the TC, altimiter, DG, and airspeed to give me my picture, and leave the AI sort of in the background. When I mostly flew an Archer, I did the same. Somehow in the transition to the Mooney, I've becomre more fixated on the AI. Not sure why. I think my scan now looks like that classic diagram in the training manuals where you look at the AI, then some other instrument, then back to the AI, then some other instrument, etc. I've wondered whether the change is a function of performance / stability of the airplane. The Archer was so stable it was easy to follow along just using the result-based instruments. In the Mooney, it became necesary to be more aware of slight changes in attitude that would affect the performance instruments in a few seconds. It also could be a better-quality AI in the Mooney that's easier to read. The Mooney is the highest-performing airplane I've flown, but I've noticed that people that fly jets seem to talk / write more about the importance of the AI. ....but I think you are experienced in higher-performance airplanes, right, Jose? Dave |
#37
Mooney, I've becomre more fixated on the AI. Not sure why. Because the Mooney demands more precision in your attitude control. The cleaner the airplane, the more true that is. Once you reach the ultimate clean airplane (a transport jet), there is no way to fly partial panel. No jet crew that lost all attitude indicators in IMC has ever survived. That's why the airlines have given up on teaching partial panel. On the other hand, an old, slow, draggy ragwing can be flown with no gyros at all, using just airspeed (or sound) for pitch and compass for roll. I know someone who has over an hour of IMC time in a ragwing with no gyros at all, doing it exactly that way. I've done it at night under the hood in the TriPacer. The Archer was so stable it was easy to follow along just using the result-based instruments. In the Mooney, it became necesary to be more aware of slight changes in attitude that would affect the performance instruments in a few seconds. Exactly correct. This is why I teach the control-performance model of the scan - my students are generally either flying slippery airplanes or are planning to move up to them. For someone who will fly his entire career in an Archer or Skyhawk, the FAA primary-secondary model works fine, and then the AI is just a way to crosscheck. Michael |
#38
I've flown in transport category jets, but in the back seat. Way back. ![]() I do have a little experience in high performance singles, but not very much. And you are probably right about the AI being more critical in high performance aircraft. Things happen faster. Jose -- Quantum Mechanics is like this: God =does= play dice with the universe, except there's no God, and there's no dice. And maybe there's no universe. for Email, make the obvious change in the address. |
#39
Michael wrote:
First off, with dual AI's next to each other, I believe that following a dying AI into an unusual attitude becomes far less likely, and thus while the chances of recovery from the unusual attitude are reduced slightly, the chances of encountering it in the first place are reduced dramatically.Â*Â*NotÂ*soÂ*withÂ*aÂ*backupÂ*vacuum *-Â*youÂ*haveÂ*toÂ*engageÂ*it. This is the first of my two major reasons for preferring the backup AI. It helps with problem detection. A backup vacuum doesn't. And even if you do, half the time (in my experience more) the problem is the AI, not the power source, so backup power for the AI does you no good. And this is #2. Some people to whom I've spoken about this have made a big deal about the fact that the backup AI does nothing for a HI during a vacuum failure. My response is typically "who cares?". Given a compass and a GPS, the HI has plenty of backup already. - Andrew |
#40
Wet vs Dry Vacuum Pump | Fastglasair | Owning | 7 | December 17th 04 11:46 PM |
Wet vs Dry Vacuum Pump | Fastglasair | Home Built | 1 | December 15th 04 05:17 PM |
Backup vacuum pump system STC'ed for Cherokee 180 | Chuck | Owning | 6 | September 18th 04 02:30 PM |
Reverse Vacuum Damging to Instruments? | O. Sami Saydjari | Owning | 8 | February 16th 04 04:00 AM |
Can vacuum AI be removed if a certified electric one is installed?? | Dave | Owning | 11 | January 12th 04 06:08 PM |
