![]() Jay Beckman wrote: When I get handed off to ZAB Center, I check in with them for flight follwing and the controller says "Recycle Transponder, Squawk XXXX." They only mean to enter the new code, right? They aren't really asking me to go to STBY, enter the new squawk, then go back to ALT, are they? Is this correct phrasiology on their part? They should be saying..."reset transponder, squawk xxxx." |
![]() "Jay Beckman" wrote in message news:FfsXe.253826$E95.128149@fed1read01... Here's one that's maybe a bit different... Tucson, AZ Clearance Delivery gives me a squawk of YYYY for departure from the Class C airspace. When I get handed off to ZAB Center, I check in with them for flight follwing and the controller says "Recycle Transponder, Squawk XXXX." They only mean to enter the new code, right? Right. They aren't really asking me to go to STBY, enter the new squawk, then go back to ALT, are they? No. Is this correct phrasiology on their part? No, correct phraseology would be just "Squawk XXXX". |
"Ross Richardson" wrote in message
... What do you do when requested to "recycle" your transponder? Reply with 'Can't -- Slash X-Ray!' |
Ross,
What do you do when requested to "recycle" your transponder? I take the hint and switch it on after previously forgetting to ;-) Or, if it is on, I switch to off and back on. -- Thomas Borchert (EDDH) |
Turn it on and then say "roger .. how's that?"
"Ross Richardson" wrote in message ... What do you do when requested to "recycle" your transponder? -- ------------- Regards, Ross C-172F 180HP KSWI |
![]() "OtisWinslow" wrote in message .. . Turn it on and then say "roger .. how's that?" There's no point in asking an aircraft to reset a transponder that hasn't been turned on. An aircraft that is instructed to recycle the transponder is usually one that has previously supplied a good beacon target. When an aircraft departs and no beacon target is seen where one should be seen the instruction is usually "verify you're squawking NNNN". |
link.net... There's no point in asking an aircraft to reset a transponder that hasn't been turned on. An aircraft that is instructed to recycle the transponder is usually one that has previously supplied a good beacon target. When an aircraft departs and no beacon target is seen where one should be seen the instruction is usually "verify you're squawking NNNN". A few years ago I got a call from tower after departure to check my transponder. I don't remember his exact wording to me was to recycle or just to turn it on, but I replied that I was slash x-ray and never heard from him again... -Greg B. Still /X |
A few times while flying home to KBIL on a cold night I've been told
that approach isn't getting my xpdr. Is this likely somehow related to the cold temp? Also, what is atc's attitude toward me hitting IDENT, and asking if that shows anything? (I know I'm leaving myself open here.) |
![]() skym wrote: A few times while flying home to KBIL on a cold night I've been told that approach isn't getting my xpdr. Is this likely somehow related to the cold temp? No, just your crappy transponder. Also, what is atc's attitude toward me hitting IDENT, and asking if that shows anything? (I know I'm leaving myself open here.) Hitting ident won't change anything if the transponder isn't currently working. |
Gee, it's only about 20 yrs old!!
I want to ask you the most important question of your life. | Douglas Olson | Owning | 1 | May 22nd 05 05:15 AM |
Good morning or good evening depending upon your location. I want to ask you the most important question of your life. Your joy or sorrow for all eternity depends upon your answer. The question is: Are you saved? It is not a question of how good | Excelsior | Home Built | 0 | April 22nd 05 01:11 AM |
Special Flight Setup Question (COF) | Dudley Henriques | Simulators | 4 | October 11th 03 12:14 AM |
