Here's one I just read:
http://www.canada.com/montreal/montr...ry.html?id=cfe... Some fellow is claiming he has a small device that will boost combustion efficiency and save drivers lots of money, while reducing emissions. Obviously, plenty of claims have been made before, so I'm asking -- does this sound on the level? It sounds reasonable that injecting H2 into your fuel stream can improve the combustion. I assume that combusting the H2 in your cylinders along with the regular fuel will boost temperature to give a cleaner burn. Would the higher temperature harm your engine life at all? Since this device supposedly only holds a limited supply of distilled H2O, KOH, etc which get periodically replaced, can I assume that it's catalytically cracking some hydrogen from the hydrocarbon fuel stream itself, so that hydrogen can improve the combustion of the remaining fuel at the cylinder? Is this somehow akin to a sort of turbocharger, but which uses hydrogen instead of pressurized oxygen? Can it work for other things like aircraft engines, in order to boost their operating ceiling? Hmm, I dunno, I feel a little puzzled or suspicious of how he's achieving a net energy gain here. Can anyone debunk any obvious fallacies here? |
combustion efficiency and save drivers lots of money, while reducing emissions. Obviously, plenty of claims have been made before, so I'm asking -- does this sound on the level? Water injection has been around for a long time, both for internal combustion and aircraft jet engines, it does improve efficiency, reduce temperatures and reduce some emissions. It depends what is being claimed for the actual device. Regards Jeff |
Water injection does not increase efficiency, it lowers it. The water goes
in as a liquid and goes out as a gas. The energy to do that comes from burning fuel. It will always take more fuel to produce a given amount of power with water injection than without. Water injection does allow higher MP or higher compression so the engine can produce more power. Piston engine fighters used it for more peak horsepower and some turbines use it for the same purpose but it definately come at the price of higher fuel burn per horsepower. Mike "Jeff" wrote in message ... Some fellow is claiming he has a small device that will boost combustion efficiency and save drivers lots of money, while reducing emissions. Obviously, plenty of claims have been made before, so I'm asking -- does this sound on the level? Water injection has been around for a long time, both for internal combustion and aircraft jet engines, it does improve efficiency, reduce temperatures and reduce some emissions. It depends what is being claimed for the actual device. Regards Jeff |
![]() "Mike Rapoport" wrote in message ink.net... Water injection does not increase efficiency, it lowers it. The water goes in as a liquid and goes out as a gas. The energy to do that comes from burning fuel. It will always take more fuel to produce a given amount of power with water injection than without. Water injection does allow higher MP or higher compression so the engine can produce more power. Piston engine fighters used it for more peak horsepower and some turbines use it for the same purpose but it definately come at the price of higher fuel burn per horsepower. Mike Hmm, consulting my ancient copy of Ricardo's "High Speed Internal Combustion Engines", Sir Harry said that water injection can be substituted for any excess fuel consumed for the purpose of reducing cylinder temperature and/or increasing detonation margin. Further, evaporation of the water reduces the intake charge temperature so as to reduce pumping losses. He goes on to say that, while there is energy lost to evaporating the water droplets, the overall fuel economy of an aircraft engine at max power setting will be improved by use of water injection particularly if the compression ratio has been increased to take advantage of the increased detonation margin. Bill Daniels |
![]() "Bill Daniels" wrote in message ... "Mike Rapoport" wrote in message ink.net... Water injection does not increase efficiency, it lowers it. The water goes in as a liquid and goes out as a gas. The energy to do that comes from burning fuel. It will always take more fuel to produce a given amount of power with water injection than without. Water injection does allow higher MP or higher compression so the engine can produce more power. Piston engine fighters used it for more peak horsepower and some turbines use it for the same purpose but it definately come at the price of higher fuel burn per horsepower. Mike Hmm, consulting my ancient copy of Ricardo's "High Speed Internal Combustion Engines", Sir Harry said that water injection can be substituted for any excess fuel consumed for the purpose of reducing cylinder temperature and/or increasing detonation margin. Further, evaporation of the water reduces the intake charge temperature so as to reduce pumping losses. He goes on to say that, while there is energy lost to evaporating the water droplets, the overall fuel economy of an aircraft engine at max power setting will be improved by use of water injection particularly if the compression ratio has been increased to take advantage of the increased detonation margin. Bill Daniels Yes, water injection can replace fuel used for cooling. I was not precise enough in my wording. In the case of using water injection at lower power settings (where excess fuel for cooling is not used) efficiency will be reduced. I used water injection in a Corvette that had 11:1 compression to stop detonation. It worked but power was definately less than with high octane gasoline and without water injection. Mike |
Mike Rapoport wrote:
"Bill Daniels" wrote in message ... "Mike Rapoport" wrote in message ink.net... Water injection does not increase efficiency, it lowers it. The water goes in as a liquid and goes out as a gas. The energy to do that comes from burning fuel. It will always take more fuel to produce a given amount of power with water injection than without. Water injection does allow higher MP or higher compression so the engine can produce more power. Piston engine fighters used it for more peak horsepower and some turbines use it for the same purpose but it definately come at the price of higher fuel burn per horsepower. Mike Hmm, consulting my ancient copy of Ricardo's "High Speed Internal Combustion Engines", Sir Harry said that water injection can be substituted for any excess fuel consumed for the purpose of reducing cylinder temperature and/or increasing detonation margin. Further, evaporation of the water reduces the intake charge temperature so as to reduce pumping losses. He goes on to say that, while there is energy lost to evaporating the water droplets, the overall fuel economy of an aircraft engine at max power setting will be improved by use of water injection particularly if the compression ratio has been increased to take advantage of the increased detonation margin. Bill Daniels Yes, water injection can replace fuel used for cooling. I was not precise enough in my wording. In the case of using water injection at lower power settings (where excess fuel for cooling is not used) efficiency will be reduced. I used water injection in a Corvette that had 11:1 compression to stop detonation. It worked but power was definately less than with high octane gasoline and without water injection. That's because you weren't running a lean mixture at high manifold pressures while the water was going in. An integral part of ADI (Anti Detonant Injection) systems on the big reciprocating airplane engines was that the mixture would be leaned much closer to stochiometric, and specific power and fuel burn would increase. For example, the Wright R3350-32WA used on the P2V Neptune patrol airplane, and on most Constellations and DC-7s, burned 45 lbs/minute at max Dry Power (277 BMEP/2900 RPM), 'bout 3400 HP. The equivalent info with ADI operating was 34 lbs/min at 301 BMEP/2900 RPM, giving 3700 HP. These engines generally ran on 115/145 Octane fuel. While you can make water injection work by just dumping water in, you don't get the full benefit unless you can adjust the fuel flow properly. -- Pete Stickney Java Man knew nothing about coffee. |
![]() Mike Rapoport wrote: Water injection does not increase efficiency, it lowers it. The water goes in as a liquid and goes out as a gas. The energy to do that comes from burning fuel. Same thing is true of a steam engine. In a steam engine it is the phase-change of the water that makes it possible to convert the heat from burning fuel into mechanical energy. It will always take more fuel to produce a given amount of power with water injection than without. Water injection does allow higher MP or higher compression so the engine can produce more power. The thermodynamic efficiency of a heat engine is a function of the compression ratio. Increasing the compression ratio increases the efficiency. That is not to say that with water injection there are not also increased losses that negate that advantage, but the fact remains that increased compression ratio, absent other factors, increases efficiency. Piston engine fighters used it for more peak horsepower and some turbines use it for the same purpose but it definately come at the price of higher fuel burn per horsepower. Ok, I believe you. -- FF |
![]() wrote in message oups.com... Mike Rapoport wrote: Water injection does not increase efficiency, it lowers it. The water goes in as a liquid and goes out as a gas. The energy to do that comes from burning fuel. Same thing is true of a steam engine. In a steam engine it is the phase-change of the water that makes it possible to convert the heat from burning fuel into mechanical energy. Yes but the steam engine takes the high-energy water vapor and produces mechanical energy while returning the water as a low energy liquid. Mike |
![]() Mike Rapoport wrote: wrote in message oups.com... Mike Rapoport wrote: Water injection does not increase efficiency, it lowers it. The water goes in as a liquid and goes out as a gas. The energy to do that comes from burning fuel. Same thing is true of a steam engine. In a steam engine it is the phase-change of the water that makes it possible to convert the heat from burning fuel into mechanical energy. Yes but the steam engine takes the high-energy water vapor and produces mechanical energy while returning the water as a low energy liquid. Actually the conversion to mechanical energy ceases before the vapor condenses. Condensate in a turbine or even a steam piston is undesireable. Regarding water-injection of an internal combustion engine I would assume the water is injected during the intake stroke, evaporates completely or almost so near TDC and then mechanical energy is extracted from the water vapor, along with the combustion products, during the power stroke. One of those combustion products was already water, so it's not like such an engine doesn't already extract energy from expanding water vapor. There is an increase in entropy associated with the phase change. That energy is irretreiveably lost and probably accounts for why the water-injected engine is less efficient than a 'dry' engine despite the improved thermodynamic efficiency resulting from the higher compression ratio. But I'm not about to attempt the math. Entropy always make my brain hurt. -- FF |
![]() Mike Yep Big John `````````````````````````````````````````````````` ``````````````````````````` On Fri, 23 Sep 2005 15:19:07 GMT, "Mike Rapoport" wrote: Water injection does not increase efficiency, it lowers it. The water goes in as a liquid and goes out as a gas. The energy to do that comes from burning fuel. It will always take more fuel to produce a given amount of power with water injection than without. Water injection does allow higher MP or higher compression so the engine can produce more power. Piston engine fighters used it for more peak horsepower and some turbines use it for the same purpose but it definately come at the price of higher fuel burn per horsepower. Mike "Jeff" wrote in message ... Some fellow is claiming he has a small device that will boost combustion efficiency and save drivers lots of money, while reducing emissions. Obviously, plenty of claims have been made before, so I'm asking -- does this sound on the level? Water injection has been around for a long time, both for internal combustion and aircraft jet engines, it does improve efficiency, reduce temperatures and reduce some emissions. It depends what is being claimed for the actual device. Regards Jeff |
General Zinni on Sixty Minutes | WalterM140 | Military Aviation | 428 | July 1st 04 11:16 PM |
fetters or fetter's booster? | Cy Galley | Home Built | 11 | March 12th 04 10:46 PM |
high-speed camera view of a piston intake, combustion, exhaust | R.Hubbell | General Aviation | 0 | February 20th 04 03:36 AM |
59% increase in pulling power is claimed for an unusual new rotor propeller for airplanes | Larry Dighera | Piloting | 5 | November 21st 03 02:13 AM |
