Toasted my engine
Old September 22nd 05, 11:17 AM
Dale Scroggins
RST Engineering wrote:
Probably so. I see where you are coming from. It has always been my policy
to neither charge for nor sign a logbook when there are unairworthy items to
be taken care of. I see your point -- but I don't operate that way.
In any case, refusing to sign a legitimate annual when the mag switch(es)
were in conformance with the type certificate and the fabric punched at the
lower limit of acceptable strength was unethical in the least sense of the
word.
Are you saying that, if you perform an inspection, and the aircraft has
unairworthy items, that you make no entry in the aircraft records? If
so, do you believe this is legal?
I've owned several Pacers and Tripacers, and inspected scores of them.
I've never seen one that had only "On" and "Off" positions for the
magneto switch. Nor have I seen any such thing in the parts catalog or
maintenance data.
Punch testing fabric covering is not a sufficient test for determination
of airworthiness IF the fabric condition is questionable. I leave you
to reference AC43.13-1B for the only acceptable method of determination
if a covering either fails or barely passes a punch test.
Dale
Cut from 43.11:
(5) Except for progressive inspections, if the aircraft is not
approved for return to service because of needed maintenance,
noncompliance with applicable specifications, airworthiness directives,
or other approved data, the following or a similarly worded statement--
``I certify that this aircraft has been inspected in accordance with
(insert type) inspection and a list of discrepancies and unairworthy
items dated (date) has been provided for the aircraft owner or
operator.''
The annual inspection is an annual inspection.
Whether or not it is "approved for return to service" is the outcome of
the inspection.
No other inspection is necessary for the next year.
91.409
Sec. 91.409 - Inspections.
(a) Except as provided in paragraph (c) of this section, no person may
operate an aircraft unless, within the preceding 12 calendar months, it
has had --
(1) An annual inspection in accordance with part 43 of this chapter "and"
has been approved for return to service by a person authorized by §43.7 of
this chapter;
The big word here is "and" for allowed operation of the aircraft.
  #32
Old September 22nd 05, 11:40 AM
Dale Scroggins
There aren't a lot of possibilities, are there?
1. The case crack set up a vibration or torque that overstressed the
bolt -- and since it happened on startup when things are running less than
smooth in a Lyc, I'd bet on this one.
2. The bolt was WWAAAYYY overtorqued on installation. You'll never know
about this one. However, a through bolt shearing and a case crack by
another through bolt leads me to check the calibration on somebody's torque
wrench.
3. Something else in the engine was vibrating ... not likely as the whole
AIRplane would have been vibrating to shear a through bolt.
4. Defective bolt ... not likely as throughbolts get magnafluxed or x-rayed
at overhaul.
5. (Add yours here)
5. The engine had cylinder work done. Either the cylinder bases were
painted while off, as mentioned earlier, and the paint eventually
squeezed out beneath the fasteners leaving them loose, or, the mechanic
neglected to loosen and retorque all the through bolts, in proper
sequence, as Lycoming recommends. Both are good bets. Failure to
retorque ALL the through bolts in sequence after installation of a
cylinder is a VERY good bet, based upon my observations.
Oh, and BTW, mechanics cannot ground airplanes. IAs cannot ground
airplanes. The FAA (unless they pull the airworthiness cert.) cannot ground
airplanes. I know it is a common phrase, but the mechanic simply suggested
that it would be less than wise to fly the airplane in its current
condition.
FAA inspectors have a form (more of a tag, really) that is designed to
be attached to an aircraft that the inspector believes should not be
flown. If one removes that tag, and flies the aircraft anyway, one may
lose the privilege of flying for some set period. Not immediately, but
in due course. I knew a pilot who did so. He flew the aircraft three
states away from the site it was tagged. The FAA inspector traced the
plane, found its location, notified the local FSDO, got the assistance
of the local sheriff, who chained and locked the aircraft to the ground.
All in one day. And merely because one of the elevators had a 12"
crack.
Dale
  #33
Old September 22nd 05, 11:53 AM
john smith
crack.
And then there was the FAA inspector who tagged an aircraft with a Q-tip
prop because he thought it had prop damage. True story, happened back in
the late-70's, early 80's.
  #34
Old September 22nd 05, 05:18 PM
Matt Barrow
"Matt Barrow" wrote in message
Already gone from my screen...oh well!
I take that back, it finally showed up my my ISP's news server today...three
days later.
Lemme take a look...
"Kobra" wrote in message
I'm not that knowledgeable about the internal details of the engines,
so
could you explain how that bolt could get sheared off?
See my post about three lines up under . I found some info
in
the Cardinal Flyers group.
Kobra
  #35
Old September 22nd 05, 05:41 PM
RST Engineering
"Dale Scroggins" wrote in message
unairworthy items, that you make no entry in the aircraft records? If so,
Case in point ... I'm "getting ready" to do the final inspection day after
tomorrow on a 150 for a fellow I've known for 30 years. He just busted a
medical and has to sell his airplane. The "pre-inspection" a month ago
found a bunch of piddledies like missing placards, filters that were due on
time, and the rest of it. I wrote these up on a bitch sheet and told him
that when they were taken care of, I'd finish the inspection.
Had I written the items up in the logbook and signed the annual, he would
have had to get a mechanic to either do the work or inspect the work after
he was done. This way he does, I inspect, and the whole thing gets taken
care of in one labor charge instead of two.
Which one do you think is more legal AND ethical?
I've never seen one that had only "On" and "Off" positions for the magneto
maintenance data.
The OP said that the switch was original equipment. I've never seen one on
a 'pacer series either, but that doesn't say that they don't exist. I can't
debate the OP assertation because I'm not there.
of airworthiness IF the fabric condition is questionable. I leave you to
reference AC43.13-1B for the only acceptable method of determination if a
Yes, the famous lab test. How many swatches have YOU sent in for lab
testing? And how do you know that the swatch you cut out is representative
of the covering as a whole?
  #36
Old September 22nd 05, 08:50 PM
LWG
I heard it was a "she" who tagged the Q tip. Owner thought it was joke his
buddies were playing on him.
"john smith" wrote in message
crack.
  #37
Old September 22nd 05, 11:07 PM
Peter Duniho
"LWG" wrote in message
As the owner of an airplane with a Q-tip prop, I've heard all sorts of
variations of that story.
I've yet to see ANY *documented* proof that it ever actually happened. I
doubt it did. Anyone who says "true story" ought to have more specific
information than that it "happened back in the late-70's, early 80's".
Like, some specific knowledge of a specific instance.
Pete
  #38
Old September 22nd 05, 11:21 PM
Bob Noel
I first heard it reported in an issue of Pacific Flyer (actually a reprint
of the that blurb was in the Atlantic Flyer). I will look to see if I still
have the newspaper scrap at work (the year was 1991 or 1992).
Bob Noel
no one likes an educated mule
  #39
Old September 23rd 05, 01:32 AM
john smith
New Cessna 152's came from the factory with a Q-tip prop in 1974? 75?
This was pre-internet, so the reporting came from the regular news
sources at the time (aviation periodicals, regional newspapers, etc).
It is difficult to cite a specific source from twenty-five to thirty
years ago without a clipping in front of me.
If you haven't been around that long, don't bitch about it.
You cannot GOOGLE everything. Not everything is available on the web,
and alot of what is is of dubious credibility. :-))
  #40
Old September 23rd 05, 01:56 AM
Yes it was a female that did the tagging along for various alleged
violations. If I remember correctly it was on one of the Phoenix area
airports. We had a client whose aircraft was there for maintenance that
got tagged for having 3" N numbers. He forwarded the violation letter
that he got to us as our boss was also his DAR. Turns out it was some
female within the DC office that wanted to get transferred to the
Flight Inspection group. She tagged something like 60 aircraft and
wrote up violation letters on them all to try and prove how good of an
inspector she was. Turns out that nothing she tagged was a violation
and it created a big headache for a couple of the FSDO's for a week or
two. Time frame was around 1989.
Engine Balancing and Resonance Vibration Problem AllanFuller Owning 13 September 12th 05 12:51 AM
Proposals for air breathing hypersonic craft. I Robert Clark Military Aviation 2 May 26th 04 06:42 PM
Car engine FAA certified for airplane use Cy Galley Home Built 10 February 6th 04 03:03 PM
What if the germans... Charles Gray Military Aviation 119 January 26th 04 11:20 PM
Real stats on engine failures? Captain Wubba Piloting 127 December 8th 03 04:09 PM
