Flight Level and a half
Old September 24th 05, 09:13 PM
Matt Barrow
"Newps" wrote in message
Matt Barrow wrote:
Well knock me over with a feather!!
Above 18,000 feet, where the separation is 1000 feet
The separation is a minimum of 1000 feet, no reason I can't just give you
more airspace.
So where in the FAR' is there authorization for VFR ops above FL180?
and AFAIK, VFR
operations are definitely NOT allowed? The example given was 33,500
feet...RVSM air space.
You won't be given an OTP clearance but then at 330 you wouldn't need that
since you're hard pressed to find many clouds up there that aren't already
thunderstorms.
So you're saying one could operate VFR at FL330?
Matt
Matthew W. Barrow
Site-Fill Homes, LLC.
Montrose, CO
  #32
Old September 25th 05, 01:25 AM
Mike Rapoport
The US mountains where 1500AGL is over 18K' are all in AK. There is also no
class A over the Aleution Islands.
MU-2
"Blanche" wrote in message
Uh....if you're between 18K and 60K in the US, then you are required
to be on an IFR flight plan, hence only at even number altitudes.
33,500 is inappropriate.
That's not correct. You're required to be on an IFR flight plan in Class
A
airspace, but not all airspace between 18K and 60K in the US is Class A.
By the way, 33,500 IS an even number.
My bad. I meant all thousands, not the half thousands that we're
used to in VFR.
Second my bad...what airspace in the US 18K and 60K is not
Class A? Not counting the big mountain in Washington state. (sorry,
can't remember the name)
  #33
Old September 25th 05, 01:27 AM
Mike Rapoport
It isn't a VFR op.
MU-2
"Matt Barrow" wrote in message
more airspace.
and AFAIK, VFR
that since you're hard pressed to find many clouds up there that aren't
already thunderstorms.
Matt
Matthew W. Barrow
Montrose, CO
  #34
Old September 25th 05, 03:14 AM
Matt Barrow
ink.net...
It isn't a VFR op.
VFR on top is not a VFR op?
you more airspace.
and AFAIK, VFR
Matt
Matthew W. Barrow
Montrose, CO
  #35
Old September 25th 05, 03:42 AM
Steven P. McNicoll
There isn't any. The FARs tend to prohibit things, not authorize them. So
where in the FARs is there prohibition of VFR ops above FL180?
Sure, as long as you're not in Class A airspace.
  #36
Old September 25th 05, 03:43 AM
Steven P. McNicoll
No, it isn't. VFR-on-top is an IFR operation.
  #37
Old September 26th 05, 04:16 AM
Mike Rapoport
No, like Steven said, it is an IFR operation.
MU-2
ink.net...
It isn't a VFR op.
you more airspace.
and AFAIK, VFR
Matt
Matthew W. Barrow
Montrose, CO
  #38
Old September 26th 05, 04:19 AM
Mike Rapoport
Actually VFR glider operations are frequently authorized above 18K' (in
class A). Near Minden, NV, ATC simply opens up blocks of airspace allowing
gliders to soar in mountain waves.
MU-2
nk.net...
So where in the FARs is there prohibition of VFR ops above FL180?
  #39
Old September 26th 05, 04:24 AM
Steven P. McNicoll
ink.net...
class A).
Sure, in accordance with FAR 91.135(d).
"An operator may deviate from any provision of this section under the
provisions of an ATC authorization issued by the ATC facility having
jurisdiction of the airspace concerned."
  #40
Old September 26th 05, 06:28 AM
Matt Barrow
nk.net...
Well, Newps and a couple others have been saying that VFR on top at 33,500
feet was legit. (or at least they snipped the original statement).
I agree with you that and hold that anything over 18,000 feet is strictly a
IFR operation and conducted in 1000 foot increments (also that if someone is
at a 500 foot intermediate level they are only passing through that
altitude, not cruising.
ink.net...
It isn't a VFR op.
you more airspace.
and AFAIK, VFR
aren't already thunderstorms.
Matt
Matthew W. Barrow
Montrose, CO
