#31
By now, most will realize that electricity is pretty dangerous stuff and not
to be trifled with. Yeah, it's maybe okay in small doses, flashlight batteries come to mind as being pretty safe if not swallowed. Not a believer? If you want to see the incredible destructive power that lurks in seemingly innocent, but higher voltage batteries, try touching the terminals on a cute little 9 volt battery to a scrap of fine steel wool!! (use caution and make sure the steel wool in on a surface that won't burn) Yup, 12 volts DC is right at the maximum sane voltage. Any more is downright foolish. In fact, the force fields that result from adding just 2 additional volts (14 volts DC) will cause the hapless pilot to undergo some sort of cultish brain damage. In some cases these poor deranged pilots will then start preaching on street corners, warning those who use lesser voltages that the end is near and they will be discharged. Curiously, by abandoning the idea of using DC (direct current), and switching all systems over to AC, alternating current, one can safely increase voltage doses up to about 120 VAC or so, with little attendent risk of dain bramage. Beyond that, there is the ever present risk of vaporization. Which is, of course, why pilots should do their best to avoid high voltage transmission lines. all the best, bumper (12 volts DC and proud of it) |
#32
OK. I'm laughing out loud at that one. Well done.
Paul Remde "bumper" wrote in message ... By now, most will realize that electricity is pretty dangerous stuff and not to be trifled with. Yeah, it's maybe okay in small doses, flashlight batteries come to mind as being pretty safe if not swallowed. Not a believer? If you want to see the incredible destructive power that lurks in seemingly innocent, but higher voltage batteries, try touching the terminals on a cute little 9 volt battery to a scrap of fine steel wool!! (use caution and make sure the steel wool in on a surface that won't burn) Yup, 12 volts DC is right at the maximum sane voltage. Any more is downright foolish. In fact, the force fields that result from adding just 2 additional volts (14 volts DC) will cause the hapless pilot to undergo some sort of cultish brain damage. In some cases these poor deranged pilots will then start preaching on street corners, warning those who use lesser voltages that the end is near and they will be discharged. Curiously, by abandoning the idea of using DC (direct current), and switching all systems over to AC, alternating current, one can safely increase voltage doses up to about 120 VAC or so, with little attendent risk of dain bramage. Beyond that, there is the ever present risk of vaporization. Which is, of course, why pilots should do their best to avoid high voltage transmission lines. all the best, bumper (12 volts DC and proud of it) |
#33
When I started this thread, all I was looking for was a source for a
battery for my Discus fin box. My backup battery under my panel is about to be switched to a dedicated source to my new transponder and I like the idea of having a separate source for my main panel instruments and radio just in case. I lost my main battery in a glider some years ago when a wire joint failed at the faston tab at the battery, so I believe that a backup source is common sense. I was considering using a 14 V seven-stack of D+ del cells for my tail fin to take account of the extra voltage drop in the longer wiring to the fin but decided it wasn't worth the hassle when I calculated 12 V would work fine for the hour or two I might need it. In any case, I hadn't intended starting rival polemics about 12 V versus 14 V systems! Having said that, some of the arguments for 14 V sources don't seem to make much sense. One main argument seems to be that the higher voltage removes the need for a second backup. Presumably using this thinking the authors have installed heavy-duty tires on their cars and removed their spares. The extra 20% to 30% power from a radio transmitter also makes very little difference. If the radio quits because of low voltage, that's a different matter, but the extra power from a working radio is inconsequential. Most communication problems arise from either bad antennas or defective ones. The rubber duckies on handhelds are a particular example of this and are horribly inefficient. Some years ago, I did tests on the 144 MHz FM amateur frequencies from a glider and using standard commercial equipment with good antennas was able to maintain perfect communications with 1 watt at up to a hundred miles with line-of-sight conditions. The 120 MHz AM aircraft radios might not be quite so good, but a couple of watts should be good enough for 50 miles or more. |
#34
Udo Rumpf wrote:
It's possible you have a problem not related to the voltage; e.g., maybe the voltage is dropping well below the 11.8 volts when the transmitter is keyed, or the radio is not functioning within specifications. Eric Greenwell I have a 720A Dittle radio Power requirements; Receive .1 - .4 amps Transmit (tone) 1.4 amps (.8 amps unmodulated) The 11.8 volts I was referring to is before transmit. If I remember correctly when the battery is fully charged and I hit the transmit button the voltage drops from 12.7 to 12.2. Udo With the battery run down to 11.8 volts, measure the voltage right at the radio connector while keying the transmitter for 5-10 seconds. If it drops more than it does when the battery is fully (or nearly so) charged, the problem might be the battery. However.... I found a German manual for the ATR720A (and ATR70C in English) on the Filser site (I think they took over the radios from Avionic Dittel). The specifications don't make any mention of what voltage range the radio will function over, so I suspect 12 volt battery operation wasn't on their minds when it was designed. This appears to be an older design radio, and likely is one that would benefit from 14 volt operation. So, if it's not the battery, your choices seem to be a modern radio (like the Walter Dittel FSG 2T I mentioned) or going to a 14 volt battery pack. Or waiting till you get closer to the airfield to make your call :^) -- Change "netto" to "net" to email me directly Eric Greenwell Washington State USA |
#35
Power requirements; Receive .1 - .4 amps Transmit (tone) 1.4 amps (.8 amps unmodulated) The 11.8 volts I was referring to is before transmit. If I remember correctly when the battery is fully charged and I hit the transmit button the voltage drops from 12.7 to 12.2. Udo With the battery run down to 11.8 volts, measure the voltage right at the radio connector while keying the transmitter for 5-10 seconds. If it drops more than it does when the battery is fully (or nearly so) charged, the problem might be the battery. However.... I found a German manual for the ATR720A (and ATR70C in English) on the Filser site (I think they took over the radios from Avionic Dittel). The specifications don't make any mention of what voltage range the radio will function over, so I suspect 12 volt battery operation wasn't on their minds when it was designed. This appears to be an older design radio, and likely is one that would benefit from 14 volt operation. So, if it's not the battery, your choices seem to be a modern radio (like the Walter Dittel FSG 2T I mentioned) or going to a 14 volt battery pack. Or waiting till you get closer to the airfield to make your call :^) Eric Greenwell I have this Radio now for many years. Based on what you and Tim are saying, I concluded that this radio does not perform very well at lower voltage. Only in the past couple of years while flying a glider with restrictive space for a batteries (the standard 12v 7amp) have I noticed any deficiency at low voltage even with fresh sets of batteries. also this radio seem to eat more on stand by. Prior to this I had no restriction in capacity and the problem never came up. Other then that the radio works fine and has good range when the voltage is up. Thanks Udo |
#36
Paul Remde mentioned that he replaces his batteries after two years of use.
The sealed lead acid batteries we use, start life with a given capacity, rated in amp hours. After manufacture, and during the first several charge/discharge cycles, these batteries will actually gain a small amount of capacity. After that, it's all downhill, with the battery losing capacity over time and discharge cycles. In the alarm industry, we replace the batteries at 5 year intervals. At this point, most of the batteries will be down to about 70% of capacity. However, these batteries have a pretty easy life, rarely being called upon to provide power and generally not bieng discharged deeply. In a glider, life for a battery is tough. Deep discharge cycles and wild temperature swings being the norm. Generally, discharging a lead acid below 80% charge will have an impact on its remaining life, below 50% is not recommended. So life will be short, so to speak. I agree with Paul, replacing batteries often is cheap insurance. I change mine at 3 years and always store them fully charged. all the best, bumper (12 volts and proud of it!) |
#37
Udo Rumpf wrote:
So, if it's not the battery, your choices seem to be a modern radio (like the Walter Dittel FSG 2T I mentioned) or going to a 14 volt battery pack. Or waiting till you get closer to the airfield to make your call :^) Eric Greenwell I have this Radio now for many years. Based on what you and Tim are saying, I concluded that this radio does not perform very well at lower voltage. Only in the past couple of years while flying a glider with restrictive space for a batteries (the standard 12v 7amp) have I noticed any deficiency at low voltage even with fresh sets of batteries. also this radio seem to eat more on stand by. Prior to this I had no restriction in capacity and the problem never came up. Other then that the radio works fine and has good range when the voltage is up. It's possible the radio is not performing as well at low voltages as it did when new. Electronic parts do age, particularly capacitors. If this is the problem, a clever and determined technician might be able to discover the correct parts to replace. A couple calls to people that repair these would be worth the effort - perhaps there are common problems that are cheaply fixed. -- Change "netto" to "net" to email me directly Eric Greenwell Washington State USA |
#38
T o d d P a t t i s t wrote:
I've run 12 volts and I've run 14 volts. The charger comment above is the main disadvantage of 14 volts. The secondary disadvantage is the "non-standard battery stack" may not want to fit into your standard-sized battery location. An advantage to 14 volt is more radio power/longer range on transmit. Modern radios don't cut out at lower voltage, like older radios that assumed 13.8 volts, but they all drive the output stages off the full voltage - the more voltage, the more output power. Other advantages are that you can run the battery longer before it gets too low, and for any switchmode DC-DC downconverters, such as I use for my IPAQ's 5 volt... What about getting the best of both worlds? It seems agreed that only the radio's performance improves with higher voltage. Why not keep a 12V system with its easy charging and standard sizes but add a DC-DC UP converter into the radio circuit so that a constant 13-14V is supplied to the radio even though the battery supply voltage drops? I have no technical skill in electronics - meaning my ego isn't involved if I'm told it's a stupid idea. Would it just be a further drain on the battery or would it usefully improve the radio's range? Does such a converter exist? More specifically on batteries, my glider has 4 x 6V 12ah cells arranged in two series pairs connected in parallel (no, not my idea, the manufacturer did it) which have reached the end of their life. The original cells are clearly a carefully matched set (marked 6.47, 6.47, 6.45, 6.46). How important is it that I match the replacements - and on which characteristics? The Yuasa website seems to imply that the only important things are that the cells be the same and the same age. Oh ...and the cells are almost impossible to remove from the glider so they have to be charged in place in the series/parallel configuration. Any advice welcomed. Graeme Cant |
#39
![]() "Graeme Cant" wrote in message ... T o d d P a t t i s t wrote: What about getting the best of both worlds? It seems agreed that only the radio's performance improves with higher voltage. Why not keep a 12V system with its easy charging and standard sizes but add a DC-DC UP converter into the radio circuit so that a constant 13-14V is supplied to the radio even though the battery supply voltage drops? By the time most modern radios would start to falter, the battery is already pretty much discharged. Using an up-converter is this circumstance would only result in a very limited amount of additional radio use - - along with a very discharged battery! Better and cheaper to insure you have adequate battery capacity by replacing batteries on a regular basis, as these batteries lose capacity with time (I replace mine at 3 year intervals - - 2 years is probably better). If room allows, consider adding an additional battery pack. Fortunately, Schleicher was kind enough to install two 12 volt 18 amp hour batteries in my ASH26E (bless their little hearts!). bumper |
#40
Graeme Cant wrote:
What about getting the best of both worlds? It seems agreed that only the radio's performance improves with higher voltage. Why not keep a 12V system with its easy charging and standard sizes but add a DC-DC UP converter into the radio circuit so that a constant 13-14V is supplied to the radio even though the battery supply voltage drops? I have no technical skill in electronics - meaning my ego isn't involved if I'm told it's a stupid idea. Would it just be a further drain on the battery or would it usefully improve the radio's range? Older radios would generally benefit, but modern radios would see less improvement. Does such a converter exist? Yes; in fact, modern radios often have exactly this kind of power supply built into them (my Becker transponder is an example of this). A potential problem with an "add-on" external unit is the losses of the conversion might overcome the value of the improved operation. I hope someone will determine what's available out there and let's us know how good they are. More specifically on batteries, my glider has 4 x 6V 12ah cells arranged in two series pairs connected in parallel (no, not my idea, the manufacturer did it) which have reached the end of their life. I've always wondered why DG thought that was a good idea. The original cells are clearly a carefully matched set (marked 6.47, 6.47, 6.45, 6.46). How important is it that I match the replacements - and on which characteristics? The Yuasa website seems to imply that the only important things are that the cells be the same and the same age. The DG owners here seem to just buy 4 batteries at the same time from the same place and not worry about matching them. If you don't get a good answer here, try the DG owners group listed on the www.motorglider.org site. Oh ...and the cells are almost impossible to remove from the glider so they have to be charged in place in the series/parallel configuration. Again, the DG owners group will offer a plethora of ideas, but this is common for motorgliders anyway. The batteries are usually large enough that they have to be mounted more firmly than the usual 7 AH unit, making it hard to remove them. A solar panel on the trailer is a favorite (or one placed next to the glider if it's tied down). I just put charger on mine while it's at home in the trailer, then remove it after it's charged. There's no need to keep it "topped up" if you are flying at least once every month or so. -- Change "netto" to "net" to email me directly Eric Greenwell Washington State USA |
Battery Question | [email protected] | Soaring | 19 | September 15th 05 01:38 AM |
Batteries, charger for Yaesu handheld - NiCad or NiMH? | David Herman | Owning | 10 | November 7th 04 04:30 PM |
14 Volt Gel Cell? | Joe Allbritten | Soaring | 32 | May 11th 04 01:37 AM |
Icom A5 Battery Tester ?? | Harry Gordon | Piloting | 5 | January 10th 04 01:29 PM |
Battery life...how to test? | Jim Kelly | Soaring | 2 | July 11th 03 09:12 PM |
