V8 fuel flow
Old January 17th 05, 02:03 AM
Robert Bates
Default V8 fuel flow
I was reading on a site about someone running a Chevy LS1 that was derated
to 320hp and bone stock that was running 10.9 gal/hr at cruise. Does anyone
have experience with these engines? If it is accurate, that is quite a
savings over Lycoming and Continentals of that HP.
Old January 17th 05, 02:24 AM
stol
derated
anyone
a
My Zenith 801 is running a 347 cu in all aluminum Ford V-8. I detuned
it to about 310 hp to keep the plane from breaking in half and on take
off I am burning 11.8-12.3 an hour. I throttle back to a fuel burn of
6.5 or so for cruise. Remember, on aircooled motors they use 30-40 % of
the fuel just to cool the heads/cylinders. Being liquid cooled we can
shift that cooling demand to our radiators and burn less fuel in the
process.
Ben Haas N801BH
Old January 17th 05, 02:37 AM
Robert Bates
That is impressive! What weight did the engine end up at with the PSRU and
is the engine stock?
"stol" wrote in message
derated
anyone
a
process.
Ben Haas N801BH
Old January 17th 05, 02:52 AM
stol
The engine is far from stock. It uses a Ford Motorsports block, cocla
crank. H beam rods, titaniam valves etc. The best stuff one can buy. It
did cost me 12,000+ to build including the redrive but thats far less
expensive then a comparable certified 300 hp motor.If you are a true
motor head you will appreaciate pics of it. here are a few links of the
plane. There are some on Jays, alexisparkinn's site, Beltedairs'site
and www.ch701.com.
http://www.zenithair.com/stolch801/builder-pics/bh2.jpg
http://www.zenithair.com/stolch801/builder-pics/bh1.jpg
Firewallforward weight including a three bladed inflight adj prop is
less then 420 lbs. A little lighter then a fully dressed 0-360Lyc and
twice the power in a detuned state. It is basically a full race sprint
car motor capable of 800+ hp so it is just idleing along,
Ben
Old January 17th 05, 03:10 AM
Robert Bates
Thanks for the links. That is one beautiful engine and the weight is better
than I thought. I'll bet it sounds nice too. I have been leaning toward an
experimental with a V8 since I talked with a friend who ate a sprague gear
on his 421 which lead to a 50k rebuild and six weeks of waiting. Granted, a
520 or 540 is less but still...
did cost me 12,000+ to build including the redrive but that's far less
motor head you will appreciate pics of it. here are a few links of the
and www.ch701.com.
Ben
Old January 17th 05, 07:29 PM
Dan Nafe
In article . com,
Wow!
Old January 17th 05, 11:01 PM
Dave Hyde
Dan Nafe wrote...
less then 420 lbs. A little lighter then a fully dressed 0-360Lyc...
Wow!
Wow is right...what did they have to do to get an
O-360 150 lb over its dry weight to make this comparison?
Dave 'porky' Hyde
Old January 17th 05, 11:03 PM
Blueskies
"stol" wrote in message ups.com...
and www.ch701.com.
Ben
Nice looking setup. Where are your radiators and are they and the coolant included in the weight?
Old January 21st 05, 05:57 AM
take
Ben,
This equates to a BSFC of about 0.22 , essentially "impossible".
Please explain the reasoning behind this (IMHO bizarre ) statement.
Sid Knox
Oklahoma
Velocity N199RS
Starduster N666SK
KR2 N24TC
W7QJQ
Old January 21st 05, 01:54 PM
Corky Scott
take
Ben,
Sid, you must have missed the following, it explains a lot:
"Let me clear up some things. My plane is tied down in its hangar at
almost 7000 feet msl. So the 310 hp is down 22% right off the bat, now
it's at 240 or so. The fuel flow for that HP range is damn close. I
agree that any motor running below .38-.40 is pushing the limit on
thermal dynamics of current technology. I admit that there is some
cutting edge stuff in my motor that helps squeeze out more hp per pound of fuel.
Ben Haas N801BH Jackson Hole Wyoming"
Sid asks:
When properly set up aircooled engines with fixed timing (which
describes all of them except for those equipped with electronic
aftermarket timing or FADEC) are advanced to full power, the fuel
system is designed to produce a strongly overrich mixture in order to
prevent detonation and overheating.
There may be some confusion as to how an overrich mixture actually
achieves this. The answer in depth may be found at:
http://www.avweb.com/news/columns/182084-1.html
REALLY simplifying the explanation, since the timing is fixed, the
only way to vary the timing is by varying the mixture. The speed of
combustion within the combustion chamber will vary from very lean to
ideal to very rich: going from slow (relatively speaking) to fast and
back to slow again respectively.
Engineers preset the point of ignition in order for the peak pressure
point to occur at 16 degrees after top dead center while at full power
and full rich mixture. This is the point where the combustion reached
it's maximum pressure during the combustion process. Engineers have
long known that the PPP should occur at 16 degrees ATDC for maximum
power and cooling.
If the mixture is leaned while under full power the combustion will
speed up. If the combustion speeds up, the PPP may begin to occur at
close to TDC. If the PPP is occurring at TDC, all that pressure has
no where to go and pressure and temperatures skyrocket.
This is why you do NOT lean the mixture while the at full power and
taking off, unless you are at a high altitude airport, which is
another story. It's also why you should NOT pull back the throttle in
an effort to "save" the engine. Pulling back the throttle slows the
engine (fixed prop), which brings the PPP close to TDC (bad).
Anyway, the rich mixture for takeoff allows the engine to achieve it's
best PPP location at 16 degrees ATDC which allows the engine to
produce maximum power and not overheat. It does not cool the engine
by hosing down the combustion chamber with excess fuel.
Corky Scott
fuel flow measurement khanindra jyoti deka Home Built 0 January 5th 05 04:34 AM
advanced fuel flow mesurement system using microcontroller khanindra jyoti deka Home Built 4 January 4th 05 01:18 AM
spaceship one Pianome Home Built 169 June 30th 04 05:47 AM
Yo! Fuel Tank! Veeduber Home Built 15 October 25th 03 02:57 AM
Pumping fuel backwards through an electric fuel pump Greg Reid Home Built 15 October 7th 03 07:09 PM
