Runway ID
Old October 16th 05, 02:37 PM
Steven P. McNicoll
Default Runway ID
"Hilton" wrote in message
nk.net...
SJC's runway 29 is 303.3 degrees.
ATW's runway 29 is 297.9 degrees.
  #32
Old October 16th 05, 03:53 PM
GeorgeB
Default Runway ID
On Sun, 16 Oct 2005 04:27:48 GMT, "Steven P. McNicoll"
"Mike W." wrote in message
No, Bill has this right. If rounded correctly, 045 becomes 'runway 4' and
055 becomes 'runway 6'.
So why is it correct to round 045 down to 'runway 4' and 055 up to 'runway
6'?
Ah, because the REAL rounding rule, designed so that averages will not
become distorted high from rounding 1/2 up, is to round 1/2 to the
EVEN number.
I know of almost no teacher nor textbook that remembers this, much
less why it is so.
  #33
Old October 16th 05, 04:10 PM
Newps
Default Runway ID
I'm sure I read a reg quoted earlier in this thread, that you got to choose
going up or down, when it was --5.
You would choose the number to which the magnetic variation is taking
the runway. For example around the western US you would choose the
higher number as if you don't you'll have to renumber the runway that
much sooner.
  #34
Old October 16th 05, 04:16 PM
Jose
Default Runway ID
EVEN number.
less why it is so.
That's because it's not so.
The standard rounding rule is 5 goes up.
The catch is that you ONLY round from the digit after the one you're
rounding to. For example, .2447 rounds to .245 or to .24 or to .2
although a common error is to round (to the hundredths) as .25, because
the "rounded to the thousanths" version would end in a five. When
rounding, always round from the source, not an already adulterated version.
Jose
Money: what you need when you run out of brains.
  #35
Old October 16th 05, 05:32 PM
Steven P. McNicoll
Default Runway ID
"GeorgeB" wrote in message
EVEN number.
If these runways were at the same field, your method would have runway
designators that differ by twenty degrees for runways that have a difference
in azimuth of only ten degrees. I think I'd round both in the direction
that local magnetic variation was moving.
  #36
Old October 16th 05, 09:19 PM
Bill Zaleski
Default Runway ID
I have seen many runways get renumbered after enough years of slow
change in the mag heading. Daytona Beach is an example that I can
quickly remember. Runway 7 used to be runway 6 about 20 years ago.
On Sun, 16 Oct 2005 17:11:12 -0400, "Morgans"
much sooner.
What??? You don't rename a runway after it has been named.
The reg has been quoted. Show me where it says you have to take the
movement of magnetic variation into account.
  #37
Old October 16th 05, 10:11 PM
Morgans
Default Runway ID
much sooner.
  #38
Old October 16th 05, 10:52 PM
Steven P. McNicoll
Default Runway ID
"Morgans" wrote in message
"On a single runway, dual parallel runways and triple parallel runways, the
designation number is the whole number nearest one-tenth of the magnetic
azimuth when viewed from the direction of approach."
  #39
Old October 16th 05, 10:56 PM
Newps
Default Runway ID
much sooner.
You most certainly do. Our parallel runways here at BIL were renumbered
from 27 R+L to 28 R+L several years ago. They did this at the same time
they rotated the VOR for the same reason. Another example is MSP. The
parallel runways there were 11/29 until a few years ago when they were
renumbered to 12/30
  #40
Old October 16th 05, 11:29 PM
nrp
Default Runway ID
Crystal airport (MIC) in Minneapolis area went from runways 4/22 to
6/24 a few years ago. I don't know why so much change though.......
Pilots Slick Piloting 4 November 20th 04 11:21 AM
Diamond DA-40 with G-1000 pirep C J Campbell Instrument Flight Rules 117 July 22nd 04 05:40 PM
Diamond DA-40 with G-1000 pirep C J Campbell Owning 114 July 22nd 04 05:40 PM
Diamond DA-40 with G-1000 pirep C J Campbell Piloting 114 July 22nd 04 05:40 PM
Rwy incursions Hankal Piloting 10 November 16th 03 02:33 AM
