#32
Morgans wrote:
"Anthony W" wrote Not that I can afford one of these at the moment but if I could, I'd be working on a way to stuff one of these in an old BMW motorcycle chassis. ;o) Talk about go like stink... That would be a real trick, since the BMW motorcycles use the engine case as part of the frame. Only the new ones do. I've seen a 1600cc VW bug engine in an older BMW. Tony |
#33
![]() "Anthony W" wrote Use avgas and mineral based 2 stroke oil and they shouldn't separate for the working life of stored fuel. That is not what I recall. I think it was the two stroke ultralight group that gave me that information, but I don't remember for sure where it was. It seemed quite definite. I don't think it was a separation problem, but rather the performance of the oil suffering, or the octane level lowering, or something. I think it was the Rotax opinion that said you should always use freshly mixed gas, or risk ruining the engine. Anyone have a clue what I am remembering? I didn't commit to total recall, because I will never fly behind a 2 stroke. I would rather not fly, if that is the only choice. -- Jim in NC |
#34
![]() "Anthony W" wrote Not that I can afford one of these at the moment but if I could, I'd be working on a way to stuff one of these in an old BMW motorcycle chassis. ;o) Talk about go like stink... That would be a real trick, since the BMW motorcycles use the engine case as part of the frame. -- Jim in NC |
#35
Hmm, I thought it said "Tips for building UltraLight"?
Yes I noticed the grin so I guess you know there was a LOT of claims out there that were no where near right! John Ok, mea culpa a little bit too. While on the subject, didja notice how many "Sport Legal" airplanes there were before the specs were even decided? "A man believes what he wants, and disregards the rest." Paul Simon |
#36
![]() One quart of oil will do for 4 or 5 fill ups depending on the size of your tank. One thing that I find peculiar is that Hirth doesn't list any expansion chamber exhaust systems. A good expansion chamber can easily double the HP and one more mildly tuned would add another 25% no problem. Tony Expansion chamber exhaust get their power increases over a very narrow range. Generally designed on a motorcycle to give max power at near max rpm. This is not what you want in an airplane where you plan on cruising at 75% power (then again if your working on a race airplane. . .). I think they said 40 or 50 to one so that makes 1 quart per 10 to 12 gallons so probably 1/2 to 2 quarts per fill up depending on tank (5 gal UL to 25 gallon regular plane (had to resist saying "real plane")). John |
#37
Richard Lamb wrote:
Hmm, I thought it said "Tips for building UltraLight"? Yes I noticed the grin so I guess you know there was a LOT of claims out there that were no where near right! John Ok, mea culpa a little bit too. While on the subject, didja notice how many "Sport Legal" airplanes there were before the specs were even decided? "A man believes what he wants, and disregards the rest." Paul Simon Yes but at least with the "sport legal" they could control max speed with prop changes and set the gross weight at whatever the regs stated. So at least they had the capability of having a "sport legal" when the standards did come out ( and some did ie 601XL for starters). John |
#38
UltraJohn wrote:
One quart of oil will do for 4 or 5 fill ups depending on the size of your tank. One thing that I find peculiar is that Hirth doesn't list any expansion chamber exhaust systems. A good expansion chamber can easily double the HP and one more mildly tuned would add another 25% no problem. Tony Expansion chamber exhaust get their power increases over a very narrow range. Generally designed on a motorcycle to give max power at near max rpm. This is not what you want in an airplane where you plan on cruising at 75% power (then again if your working on a race airplane. . .). I think they said 40 or 50 to one so that makes 1 quart per 10 to 12 gallons so probably 1/2 to 2 quarts per fill up depending on tank (5 gal UL to 25 gallon regular plane (had to resist saying "real plane")). John It depends on the design of the pipe. I used to build expansion chambers and you can either design them for max out put on one end of the scale or a broad power-band. The street pipes I used to build were somewhere in the middle leaning toward broad power-band. It would be easy to pick up 20% over straight exhaust pipes on a well made engine like the Hirth or Rotax within the normal operating RPM. I think one of the Hirth 4's with fan cooling might have been able to keep mini-500's in the air but this is pure speculation. If you ever find a copy, read the Two Stroke Tuners Handbook by Gordon Jennings. He could be a real butthole at times but he knew his stuff. I loaned my copy out and never got it back. It took me 20 years to track down another copy... BTW, bike engines need a broader power-band than airplane engines. A bike engine has to make usable power from 3k to red-line. I don't know for sure but don't most aircraft engines run within a 2k RPM range in flight? Tony |
#39
![]() "Anthony W" wrote Only the new ones do. I've seen a 1600cc VW bug engine in an older BMW. Must have been real old. I know the '75 60R did not have a real frame. -- Jim in NC |
#40
Richard Riley wrote:
On Sat, 22 Oct 2005 23:48:49 GMT, Anthony W wrote: :If you ever find a copy, read the Two Stroke Tuners Handbook by Gordon :Jennings. He could be a real butthole at times but he knew his stuff. :I loaned my copy out and never got it back. It took me 20 years to :track down another copy... Ain't the internet wonderful? It took me 20 seconds to find it here - http://tinyurl.com/e2wwh but the cheapest copy is $96!! Someone needs to put this one back into print! There's a copy on Ebay at http://tinyurl.com/exsup, $15 right now. One of the customers to my motorcycle parts biz eMailed me a copy in PDF format. If you're real nice, I'll eMail it to you one file at a time. I was thinking of adding it to my website but I don't want yo get into problems with royalties. Tony |
Ultralight rotorcraft | Skywise | Piloting | 27 | July 15th 05 02:56 AM |
Ultralight down in Eastern Oregon | Harry K | Home Built | 9 | March 29th 05 06:26 PM |
Ultralight Club Bylaws - Warning Long Post | MrHabilis | Home Built | 0 | June 11th 04 05:07 PM |
AL-12: New ultralight sailplane | ISoar | Soaring | 4 | March 24th 04 01:52 AM |
Ultralight magazine August 1981 | Gilan | Home Built | 0 | July 20th 03 04:34 AM |
