#31
"Skylune" wrote:
Idiot. Ad hominem. Your nonsense is "easily refuted." My counter-arguments to your refutations follow: In fact, the graph you attached from BTS compares apples and oranges. I converted from hours flown to miles flown by assuming a certain average airspeed. This provides a reasonable order-of-magnitude estimate. As it happens, the ATSB estimate for Australian GA (17.5 fatalities/100 million kilometers - 28 fatalities/100 million miles) is very close to my converted value for U.S. GA (20 fatalities/100 million miles). The remarkably close correspondence indicates an apples-to-apples comparison. I suggest a Stat 101 course from your local community college. More ad hominem. Studies that adjust usage rates using the same denominator (i.e. passenger miles, hours travelled, etc.) all conclude that GA is the most dangerous form of transportation. The ATSB begs to differ: "These comparisons, summarised in table 1, find: .... c. Motorcycling is the least safe form of transport." (From: http://www.atsb.gov.au/road/statistics/cross_modal.aspx ) Here is one example: http://www.planecrashinfo.com/cause.htm The reference you cite does not include motorcycling, recreational boating, or bicycling, among other modes of transport. So it does not contradict the references I cited, which did show motorcycling to have a higher fatality rate than fixed wing general aviation. Also, you may want to check the BLS studies of most dangerous occupations, which can also serve as a proxy. Aircraft associated professions have the highest mortality rates in the US, behind only lumbering. You may also want to check historical BLS studies, since some of them don't support your "proxy" method. In 1997 water transportation occupations had more fatalities per worker than aircraft pilots: http://www.bls.gov/opub/ted/1999/Jan/wk1/art01.htm Or, the common sense test. You suggest that Bicyclists and pedestrians are at greater risk by "some measures." That may be true. Quite. You wrote: "Statistically, GA is the most dangerous of all forms of transportation." Now you know it isn't. |
#32
"Skylune" wrote:
Hey. By using vehicle miles as the standardization factor for statistical comparisons, the Space Shuttle should be by far the safest form of transportation. Right Jim? Well, let's see, first we have to find the miles traveled. I found this site with some totals: http://www.space.com/missionlaunches..._sidebar2.html They say: "Fleet Total: 354,775,865 miles (567,641,384 kilometers)." Space fatalities (and many other space stats) found he http://www.cbsnews.com/network/news/...pacestats.html 14 fatalities. So the rate for the Space Shuttle fleet works out to: ~3.9 fatalities per 100 million vehicle miles. By comparison, according to http://www-fars.nhtsa.dot.gov/ the U.S. rate for motor vehicle accidents is: ~1.7 fatalities per 100 million vehicle miles. CONCLUSION 1: On a per mile basis, auto travel is safer than space shuttle travel. So it isn't the safest form of transportation even by that generous measure. CONCLUSION 2: You don't actually research anything yourself, thus getting yourself into trouble by making assertions you haven't checked. You could have found the space shuttle stats yourself with some trivially obvious search keywords. |
#33
Skylune opined
Hey. By using vehicle miles as the standardization factor for statistical comparisons, the Space Shuttle should be by far the safest form of transportation. Right Jim? When making comparisions, there are 3 metrics. Per hour, per mile, and per trip. The shuttle is (I suspect) pretty good per mile, iffy per hour and terrible per trip. What metric you use depends on why you are using a particular vehicle. -ash Cthulhu in 2005! Why wait for nature? |
#34
![]() "Greg Farris" wrote Ah, but there's method to his madness. He's (skylune) there to irk private pilots, and knows enough about the subject to do so. It must be fun for him, sitting back and watching knees jerk! Exactly! I have quit playing his game, and no longer read any of his posts. If everyone did that, he would go away. -- Jim in NC |
#35
![]() "Andrew Gideon" wrote in message online.com... Stefan wrote: Comparing aviation and pedestrians by looking at the accident rate per mile is sheer nonsense. Why? The idea is to compare accidents to the value accrued from the travel. Ignoring "fun" (as it's tough to quantity whether we're speaking of flying, biking, etc.), why isn't "distance" a good metric for value? In that case, we should all get the fastest plane we can, because that way we can cover more miles per hour, and be safer. Can you see how ridiculous that sounds? -- Jim in NC |
#36
Oh, I don't know. The trips were only about three thousand miles apiece. Jose -- Money: what you need when you run out of brains. for Email, make the obvious change in the address. |
#37
Where did that number come from?
According to the Nall Report, the actual number is 11 or 12 fatal accidents per million hours of GA flights (averaging just under two deaths per fatal accident). Okay, you statistic gurus, figure this out for me, please? If, say, I end up flying 4000 hours in my flying life, using your figures (above), what are my odd of dying in a fatal crash? Is it possible for you to factor out accidents caused by fuel starvation, flying into IMC, and flying at night? If so, what are my odds then? -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
#38
accidents per million hours of GA flights (averaging just under two deaths per fatal accident). Okay, you statistic gurus, figure this out for me, please? If, say, I end up flying 4000 hours in my flying life, using your figures (above), what are my odd of dying in a fatal crash? Without scouring the Nall Report for details, and using round numbers of 10 fatal accidents per million hours, that's one per 100,000 hours. That comes to 4/100 of a fatal accident per 4000 hours. The numbers are small enough so that a linear approximation will come close enough - it's a 4% chance of being involved in a fatal accident. General Aviation covers a broad range of activities, some inherently more risky than others, and some carrying more passengers than others. It is more likely that a hundred-passenger plane that crashes would generate a fatailty than that a two passenger plane does, just because more passengers have the opportunity to die. However it's probably not unreasonable to use the overall figures and figure 4% chance of being involved in a fatal. But I suspect that 2 passengers is fairly average for a general aviation flight, and not too far off from your flying. Based on that, I'd say that if you are involved in a fatal accident, you'd have a good chance of not being one that survives. Is it possible for you to factor out accidents caused by fuel starvation, flying into IMC, and flying at night? If so, what are my odds then? No. You might be able to factor them out, but you would no longer have a reasonable calculation. People rarely crash due to intentional fuel starvation, or intentional VFR in IMC. It just creeps up on them unexpectedly, as does nightfall. This is why they are called "accidents". You could reasonably exclude IFR flying, but you should not exclude IMC. It is unreasonable to exclude night flight, even if you never intend to fly at night. If you never fly at night, it just means that when nightfall =does= sneak up on you, you will be unprepared for it. And in 4000 hours, one day nightfall =will= sneak up on you. And it will be the day you were in a hurry to make it before dark, the fuel pumps rejected your credit card, and you still had mostly full tanks and a good shot at making it. And you would have made it too, if the wing wasn't just a little bit tilted when you dipped the tank. There were some clouds in the way but you climbed over them... at Vx - full power, full rich, and they were higher than you thought. Oh, a new moon. Dang - where'd the lights go all of a sudden? Don't say you won't be there. 4000 hours is a lot of hours. You =will= make mistakes. Four percent if the source numbers are accurate. No fudging. Jose -- Money: what you need when you run out of brains. for Email, make the obvious change in the address. |
#39
If, say, I end up flying 4000 hours in my flying life, using your figures (above), what are my odd of dying in a fatal crash? 1 in 25 Is it possible for you to factor out accidents caused by fuel starvation, flying into IMC, and flying at night? If so, what are my odds then? Greatly improved. But - against that, hoteliers are high risk! In England, hoteliers pay a LOT more for car insurance (in the same class as bartenders and waiters) because they have a lot more accidents. Does this translate across to pilots? I don't know. It isn't just about alcohol consumption - it is also about working long stressful hours and then driving (flying?) tired. So there is the factor that I don't really know how to factor in. As a matter of interest - do hoteliers in the USA pay higher aircraft liability insurance? Do they even have to declare their profession? Tony (who used to be a hotelier - in England) -- Tony Roberts PP-ASEL VFR OTT Night Cessna 172H C-GICE |
#40
Jose opined
The shuttle is (I suspect) pretty good per mile Oh, I don't know. The trips were only about three thousand miles apiece. Many were were about 5 miles. I guess that makes the shuttle worse than private GA. -ash Cthulhu in 2005! Why wait for nature? |
