Oct 18 course reversal change
Old November 4th 05, 05:24 PM
Jose
Default Oct 18 course reversal change
What made more sense with your previous understanding?
When I think of a "sector" I think of a block of airspace, not a set of
arrival points or routes.
Hmmm...well, the procedure requires you to start at the fix that defines the NoPT
terminal route. Where is the mystery in that to the designer?
I am cleared to a fix, and cleared for the approach. The fix I am
cleared to (especially in a GPS world) is not necessarily "the fix that
defines the NoPT terminal route" but may be a fix that is on the
approach. It's not on a NoPT terminal route, but it is aligned with the
FAC and I'm at an appropriate altitude.
I suppose the designer didn't design it for that, but sometimes it's
used that way.
Jose
Money: what you need when you run out of brains.
  #32
Old November 4th 05, 07:34 PM
used that way.
That practice is different than arrival along an NoPT route. That is an "innovation,"
which is more akin to a vector to final. It is "bogus" but will be approved as a new
ATC procedure early next year. It is intended to be limited to RNAV IAPs (hopefully
;-). The clearance must be to the intermediate waypoint/fix (IF), must not exceed a
90-degree course change and at an altitude compatible with the procedure.
!!! WARNING -- AOPA credit card holders. The credit card company is trying to change the rules in mid-game. Read the statement sent to you by MBNA. Chuck Owning 22 May 23rd 05 12:37 AM
WARNING -- AOPA credit card holders. The credit card company is trying to change the rules in mid-game. Read the statement sent to you by MBNA. Chuck Owning 7 May 5th 05 08:01 PM
How do you explain why the A/S increases on thermal entry? Fred Soaring 43 April 24th 05 02:33 PM
