Avionics (Radio Problem) Narrowed Down... I Think???
Old November 21st 05, 06:46 PM posted to rec.aviation.owning
Default Avionics (Radio Problem) Narrowed Down... I Think???
Thanks! I will do that...
Off topic question:
The audio panel from the front, has every indication that it has marker
beacons (O, M, I indicators), but there's nothing there... Simply no
led's or wires to the panel. This would seem like a fairly simple
thing to implement??? Should I just cut my losses and be happy I can
communicate, or am I getting greedy, thinking I could go to Radio Shack
and with minimal effort, upgrade this existing audio panel by myself?
If you think it's not worth the effort, I'll close this thread and open
a new one on how to repack and seal the front nose strut, or how to
find the source for fuel in the cabin smell after topping the tanks, or
tip tanks... Keep em' full or not??? :-))
Thanks!
Todd
Old November 21st 05, 11:28 PM posted to rec.aviation.owning
You might be able to find light bulbs at The Shack, but more probably would
be a model train shop for 12 volt grain-of-wheat lamps.
"three-eight-hotel" wrote in message
Off topic question:
Old November 22nd 05, 03:25 AM posted to rec.aviation.owning
"three-eight-hotel" writes:
Off topic question:
Does the panel have the decoders; just no indicators? It could be
the PCB section for that function was never populated, or it's a
daughter board that was not installed...
A host is a host from coast to
& no one will talk to a host that's close........[v].(301) 56-LINUX
Unless the host (that isn't close).........................pob 1433
is busy, hung or dead....................................20915-1433
Old November 22nd 05, 04:11 AM posted to rec.aviation.owning
hmmm...??? If you followed any of my previous posts, you wouldn't be
surprised that I don't know what decoders or PCB's are... LOL!!! ;-)
The holes for the tri-colored lights are on the panel and labeled, but
there is nothing behind them. No led's, no wires... Is there an
entire daughter board that runs the MB's? I may be biting off more
than I can chew, but looking at pics of other Cessna audio panels
on-line, it just looked like there were led's and wires running to the
main board, but it was hard to tell...
Todd
Old November 22nd 05, 07:18 AM posted to rec.aviation.owning
three-eight-hotel wrote:
/snip/
Thanks!
Todd
Todd,
Close this thread now! Those old Cessna audio panels (actually, just
switching panels) were junk the day they were new, and have NOT improved
with age. To make the marker beacons work, you need a marker receiver
box (R403B, IIRC), plus all the associatd wiring, PLUS the missing
components on your "audio panel".
IMHO, it's not worth it. Stop putting any money in to the unit you
have, and save up for a true upgrade, when you "just gotta have"
improved capability.
Happy Flying!
Scott Skylane
N92054
Old November 21st 05, 07:38 PM posted to rec.aviation.owning
RST Engineering wrote:
: OK, now take that old relay, get a piece of bond copy paper and some pure
: isopropyl (the 99% stuff) alcohol, tear/cut a strip of the bond paper about
: a quarter of an inch wide, soak the first two inches of the paper in the
: alcohol, and run the paper between EACH of the contacts of the old relay,
: holding pressure on the top and bottom contact just enough so that the paper
: doesn't tear.
I find old business cards are just the right thickness & strength to handle
this task. Since my old company changed area codes, then logos, I have enough
old business cards to last a few lifetimes.
Aaron C.
Old November 21st 05, 08:17 PM posted to rec.aviation.owning
: : OK, now take that old relay, get a piece of bond copy paper and some pure
: : isopropyl (the 99% stuff) alcohol, tear/cut a strip of the bond paper about
: : a quarter of an inch wide, soak the first two inches of the paper in the
: : alcohol, and run the paper between EACH of the contacts of the old relay,
: : holding pressure on the top and bottom contact just enough so that the paper
: : doesn't tear.
: I find old business cards are just the right thickness & strength to handle
: this task. Since my old company changed area codes, then logos, I have enough
: old business cards to last a few lifetimes.
IIRC, the Bendix mag service instructions allow for cleaning of the points
using exactly that... a business card. Note, however, that pulling it through is
*NOT* allowed... simply closing the points on it and opening it back up.
I think that it has to do with the microscopic roughness on the mating
surfaces. Once they've "worn in," dragging a card through will cause the "teeth" not
to mate anymore.
-Cory
* Cory Papenfuss *
Old November 22nd 05, 02:19 PM posted to rec.aviation.owning
All righty then...
Consider this thread closed. I'm going to count my blessings and be
happy I can communicate, and focus on the aviate part again! ;-)
I'll start putting some money aside and start upgrading my panel the
next time a piece of avionics goes toes-up.
Thanks again to all for your input. and... for the record... I
realized after my last send, that I do know what a Printed Circuit
Board is... ;-)
Best Regards,
Todd
MX385 Radio removal Marty from Florida Owning 3 May 24th 13 08:26 AM
Engine Balancing and Resonance Vibration Problem AllanFuller Owning 13 September 12th 05 12:51 AM
(sorta OT) Free Ham Radio Course RST Engineering Home Built 51 January 24th 05 08:05 PM
(sorta OT) Free Ham Radio Course RST Engineering Piloting 43 January 24th 05 08:05 PM
