Chevy LS2 and Trans??? any real issues besides weight
Old November 12th 05, 11:00 PM
Bret Ludwig
Default Chevy LS2 and Trans??? any real issues besides weight
Morgans wrote:
"MrV" wrote in message
yes i did and that is why i posted it here asking for comments. if u
notice a number of times i have stated this is just for info and if it
is reasonable. I'm guessing you are just an idiot that doesn't bother
to read complete post.
from the replies i've received the only thing i can see wrong with my
idea is 1 weight and 2 vibration everything else can be solved readily
with some planning. instead of posting something stupid like this why
not give reasons why i'm TOTALLY off base.
The guy isn't completely on the ball but he did ask a question that
has a simple and well-known answer. Car transmissions don't work in
boats either.
  #32
Old November 12th 05, 11:12 PM
MrV
Hello Dan,
without saying so much i've already decided to sacrifice weight for
familiarity. considering the goal is to build a 2 seat aircraft i'm
pretty sure i can come in at an acceptable weight. no it will not be a
feather but should be reasonable considering the engine is aluminum.
i'm also trading weight for cost. the added cost of the approx equal
hp engine is a multiple of the cost of my auto engine.
now just quickly looking up a few things
O-360-A1D 180 284
O-360-A3A 180 285
IO-360-A1A 200 320
IO-360-B1B 180 295
IMO-360-B1B 225 274
GO-480-B1D 270 432
GO-480-G1D6 295 437
IGO-480-A1B6 295 469
IGSO-480-A1F6 340 498
O-540-A1A5 250 396
O-540-B2B5 235 395
O-540-B4B5 235 395
O-540-B4B5 260 398
IO-540-A1A5 290 437
IO-540-C4B5 250 402
IO-540-D4A5 260 402
IO-540-E1A5 290 437
compared to the 200hp io360 i give up 120 lbs to a tweaked out 360
engine acutally weighs about the same as a 540
now that doesn't take into account, radiator,coolant, associated
hardware, coils, alternators, etc. but some of that hardware is
common and would add to the weight of either engine.
i would estimate not giving up 200lbs at the same hp.
I haven't started building buying or even plotting out a time frame for
this project i'm jsut getting information at the moment formulating
ideas, plans and such. You guys actually seem to get threatened
maybe defensive what the hell.
number 6 i totally agree with and well already decided i'm willing to
take my risk. the thing i would fear more would be not trying.
no i don't have lots of money but i have enough to do what i want. In
reality the reason i chose the auto derivative is because i can INVEST
loads of time equity. i can tear down and rebuild a car engine how
much does that cost ? few hundred dollars in parts. now the lycoming
I CAN NOT WORK ON and the parts would cost more than the auto engine
probably. hell forget rebuilding i can buy a new engine for cheaper
than the cost of rebuilding a lyc.
I'm sorry bout the lycoming lawnmower comparison its not exactly true.
the briggs and straton is cheaper to repair. hehe JUST KIDDING.
the simple truth is I feel more comfortable with an auto engine. There
has not been 1 airplane mechanic i've spoken too that has said any
airplane piston engine is more reliable than a car engine. NOT ONE and
i've spoken to atleast 2 dozen of them since before i got my license.
that is not saying the car engine would be just as reliable in a plane
its just saying in their respective environments the airplane engine
has NOT shown any more reliability than the auto engine. also a few of
the mechanics stated they may be less reliable. NOT TROLLING THAT IS
WHAT THEY SAID
now 1 thing i would have u know I'm not a troll i'm not trying ****
anyone off just want ideas.
I want to know WHY an engine with nice rubber motormounts, tranny with
poly bushings between the tranny and SHORT drive shaft connected to a
thrustbearing secured to the frame would not live.
i'll state the conditions more clearly.
engine and tranny will run at a MAX OF 65% rated power. more likely
60%
they will not under any condition run above this power range. IN other
words at FULL OUT throttle wide open thign will spin at 3500 rpm if
that.
truthfully the idea of using the tranny as reduction unit was just that
an idea but now i want someone to explain to me where it will fail
given proper mounting and isolation.
  #33
Old November 12th 05, 11:27 PM
Morgans
I guess you can't read a whole post, either. I said before, that there are
so many problems, there is no good place to start the shooting down process.
Why don't YOU start by doing your homework, and do some research about what
is being done out there, and why some things are NOT being done.
Hint: If you start _without_ vibration and WEIGHT being solved, you can't
start. EVERYTHING will change, solving those problems.
Still haven't found the "shift" key, I see. It makes you look like a child,
or a lazy person. Maybe both.
  #34
Old November 12th 05, 11:31 PM
Bret Ludwig
MrV wrote:
Hello Dan,
Of course you could work on a Lycoming. There's no high magic, you
need a few tools like cylinder base wrenches and so forth, but if you
have the brains to work on any engine you can work on a Lyc, a Ranger,
a Menasco, a Napier Lion, an OXX-6, or any other museum piece.
All these engines have a place, like antique airplane fly-ins and,
umm, museums. (The last running Napier Lion is in a car. Go figure.)
First off though, you haven't done your homework. You didn't study the
available literature, and the successful projects that have flown.
Second, you should build an existing design first with an existing
engine setup. Several are available in varying states of compleness.
After you succeed at that, the piece de resistance can come later.
Third, you have a few Olde Pharts here. Some of them have advanced WSE
and some have apparently died, like Backdoor BoB, or whatever his name
was.
Second,
  #35
Old November 13th 05, 03:02 AM
Smitty Two
In article .com,
You're going to put a radiator in a pusher? (Bret, wouldn't this qualify
as "clean sheet of paper" engineering? Or has this been done already?)
  #36
Old November 13th 05, 05:32 AM
MrV
okay now from listening to u guys i've done just a bit of research.
check out http://www.epi-eng.com took a bit but i read most of this
site.
From reading the epi site i've come up a couple new ideas.
instead of a single thrust bearing how about a double bearing system 1
for thrust and 1 to transfer gyro forces to frame and to isolate the
prop from the engine vibs . kinda like prop-|-|-engine. Also consider
the system will still have the flywheel in place.
actually i'd prob just buy a psru from epi considering they've already
created one specifically for the engine i plan to use.
  #37
Old November 13th 05, 07:49 PM
I'm a mechanic, and I'll tell you: the engine/transmission setup you
are proposing is far less reliable than an aircraft engine. Most
direct-drive engine problems are electrical, and that means ignition
failure. Many auto conversions are single-ignition, relying on the
battery/alternator setup for power, and there have been problems.
Adding a second similar system doesn't increse safety much, since it
relies on the same power source and usually fires the same set of
plugs. Aircraft magnetos are a little less reliable than the auto's
system, but there are two of them, and two sets of spark plugs, making
the engine MUCH more reliable from the ignition standpoint.
That transmission will be heavy and will fail. It can't take
the high power levels for extended periods. When I put a Chev 283 in my
boat, I used a Warner marine transmission; it weighed about twice what
the chevy car trans had, and had only forward-neutral-reverse. It also
had a big oil cooler to keep it alive.
Your weight will be higher than estimated. These things have a
way of doing that. I have heard of several projects that came off way
too heavy to ever fly. Even the standard kit or plans-built airplane
usually ends up havier than forecast.
Dan
  #38
Old November 13th 05, 08:45 PM
Bret Ludwig
Marine transmissions are much heavier for their complexity and power
than car transmissions, for good reasons, although most marine
transmissions are a little overdesigned-boats can handle the weight and
they are expensive, so no one minds.
Dual ignition is a good thing but compromising the integrity of
cylinder head castings for it isn't. Some car engines have two plug
heads but most of them are really heavy. The other thing is that most
combustion chambers in modern car engines are efficiently designed for
a single plug.
A serious IFR airplane using an autoderivative engine would have two
fully independent electrical systems withh two batteries and two
alternators, one of which would be a beltless type such as used on
MerCruiser Chevy IIs and sold to the circle track guys for years as an
"in the water pump pulley style", or some such. I think Rotax has such
a system on their "real aircraft engine", if that's still underway as a
project.
It's interesting to note Continental's FADEC engine-using a controller
far less sophisticated than MegaSquirt, the DIY FI system-which is
something like a $10K premium, gets rid of BOTH mags and gives you ai
internal one hour battery backup if the airframe electrics shoot craps
completely. My old spinster aunt ferried Bonanzas across the North
Atlantic in the early seventies and I'm sure she'd be glad to know that
if the electrics quit you had a whole hour!
  #39
Old November 13th 05, 09:31 PM
MrV
Hey Dan good info. Question what is considered "High Load"? My plan
is to run the system at a max of 65%. from personal exp i know running
my auto at 5k rpm will shorten its life but i also know that it'll run
damn near forever at 3500 rpm.
One thing i had planned on was creating a duplicate electrical system
atleast up to the engine managment comp maybe even duel comps with
isolated elect buss. I would like to maintain the chevy ems but have
contemplated an after market. one thing i really really like about
the chevy ems is that when something goes bad say u lose a coil it
adjust and keeps running. My car lost one of the coils at about 60k
miles the only way i knew it was a loss of power and the service engine
light being on. I drove around like that for about a month before the
service guy told me the problem and replaced it. (side note -- never
ever let midas do this 700$ repair for 10 mins of work and 100 bucks
in parts)
I guess it may be a possible to have duplicate coil packs but just from
the examination of my auto that may be a bit difficult.
  #40
Old November 13th 05, 10:00 PM
Jim Carriere
Question for you: What torque/rpm setting do you use to arrive at 65%?
Take a generic direct drive aero engine, and some ballpark figures for
the sake of an example to explain my question:
Let's say cruise flight is at 7,000 feet, wide open throttle, and near
max rpm. Max power is at sea level, wide open throttle, max rpm. More
numbers- let's say this cruise setting translates to 2,500rpm at 24".
Max power is 2700rpm and 29". Use some simple math and simplifying
assumptions (flat torque-rpm curve) about the engine to calculate
"percent" power...
2500/2700 x 24/29 = 77%
(pretty close to the popular definition of cruise power, 75%)
Anyway, just curious what numbers you use to get 65%. Note I don't have
any issue with the figure, I realize it's an arbitrary decision in
performance/reliability tradeoff.
By the way, the first hit on Google for keywords 'chevy ls2 rpm
horspower' gives 400hp at 5200rpm.
