Flight plan equipment suffix
Old November 29th 05, 01:15 PM posted to rec.aviation.piloting
Default Flight plan equipment suffix
"Michael Ware" wrote in message
You're right, substitute the word 'sole' for 'primary'.
He cannot use the GPS for his sole means of navigation, regardless of the
make/model of the GPS, the status of the database, or what equipment suffix
he uses when he files, because he's operating under Visual Flight Rules?
What are you basing that on?
  #32
Old November 30th 05, 03:23 AM posted to rec.aviation.piloting
Example 1: pilot may not be thoroughly familiar with the navigation
equipment
Example 2: pilot may be an old timer and may not like 'modern'
technology like GPS
Example 3: pilot may have found the equipment to be flaky in the past,
and is not comfortably using it
Example 4: Just because he doesn't feel like it.
Why does it matter what the reason is? My point was, if he chooses not
to use an equipment, he should not file it. Is there a rule that says
otherwise?
  #33
Old November 30th 05, 04:10 AM posted to rec.aviation.piloting
"Andrew Sarangan" wrote in message
equipment
technology like GPS
None of those examples answer the question.
Because being unable to explain why you believe what you believe tends to
indicate there's no reason to believe what you believe.
My point was, if he chooses not to use an equipment, he should not file
it.
But you have no idea why he shouldn't file that way.
NAS and associated computer system Newps Instrument Flight Rules 8 August 12th 04 05:12 AM
us air force us air force academy us air force bases air force museum us us air force rank us air force reserve adfunk Jehad Internet Military Aviation 0 February 7th 04 04:24 AM
Real World Specs for FS 2004 Paul H. Simulators 16 August 18th 03 09:25 AM
