#31
Deb
Well, there ya go! Pretty much what I tried to describe. Funny story about spot landings....I was flying near Marana, AZ back in the 70's and heard a spot landing contest going on via the Unicom. So, I called and asked if I could participate. The answer was affirmative, so I carefully did the approach, adjusted power, rate of descent, got an eagle eye on the spot, maintained the line and slope, did some careful adjustments, then landed exactly on the spot with zero forward movement....in my helicopter. gggg They didn't want to give me 1st Place for some reason. So I just continued on the ferry flight to SoCal. We all got a laugh out of it. About 30+years back I was hired to check out a group of M.D.'s in thier club C-195. Good group of pilots and a lot of fun. Great airplane and very capable. Does yours have the Geiss gear or is it rigid? Ol Shy & Bashful |
#32
But the big
(235hp) Pawnee at the glider club wanted to nose over if you just breathed on the brakes. Yeah, I remember that plane. It wasn't really a Pawnee 235 - it was a normal Pawnee (originally 150 hp) that had been re-engined. Sure flew nice. Landed nice too - the engine change moved the cg forward, so the mains were only slightly ahead of cg. Very little tendency to come around, and even at idle the prop blast from that big engine and seaplane prop kept the rudder effective at very low speeds. Never did use the brakes on it for anything other than holding it at runup or bringing it to a stop from taxi speed. It's gone now - crashed due to pilot incompetence, a total loss. On the other hand, I remember a Starduster that couldn't be put on its nose. You could hold the brakes, go full throttle on the IO-360 engine with CS prop, push the stick full forward, and the tail wouldn't come up. It wouldn't even get light. You had to be doing 45 kts at full throttle to lift the tail. You couldn't wheel land the thing either. Didn't matter what you did - you could touch down at 80 kts, and the tail would drop immediately even with the stick full forward. Using the brakes on landing was a routine thing - it was the only way. It was also the only way to maintain directional control below 40 kts or so - rudder was totally ineffective. Tina sold it, but I hear it's still flying. Different airplanes. I did my own groundloop once, on takeoff. Among tailwheel pilots, there are those who have and those who will. Groundloop, that is. Put a wingtip in the dirt. Whatever you want to call it. I always knew that, but when I changed groups, it was a surprise. I suppose it always is. The HP-11 is not really a tailwheel airplane. It's a tailwheel glider. For those not familiar with tailwheel gliders, there are usually only two wheels. The main wheel is on the centerline, somewhat ahead of the cg, and the tailwheel is on the tail. On most gliders, the main wheel is very close to the cg - close enough that if you put in a pilot substantially over the weight limit, the glider will sit on the nose. The HP is different. Like most powered taildraggers, it carries 5-10% of its weight on the tail. It also has other peculiarities. The designer, the late Richard Schreder was a mechanical engineer and retired naval aviator, and he could get the absolute most performance out of the available material. The particular glider I own, a T-tail HP-11 N821Z, was designed in 1962 but was still competitive in 1969, placing third at major contests. Truly the design must have been a wonder in its day. But to get the performance, some things had to be sacrificed. Since the design was for competition flying, something a novice pilot presumably would not do, the decision was made to sacrifice forgiving handling characteristics. These days, the HP's are no longer competitive but aren't really suitable for low time pilots either. They have become, in many cases, the glider of choice for the transition power pilot. All metal so they can be tied down outside, with reasonable performance for a fraction of the cost of glass, they appeal to the budget conscious transition pilot who is used to the vagaries of flying taildraggers. The ailerons are weak. In a typical metal trainer, such as the ubiquitous L-23, the ailerons are so effective that the glider can be pointed into a 10 kt headwind and a pilot can practice low speed roll control by holding the wings level, balancing on the monowheel. In the HP-11, you can barely hold the wings level with 30 kts. Taking off is an interesting affair. A wing runner can, at best, hold the wing up until about 10 kts is reached. Then you're on your own. The ailerons are little help. You start out level, and if you notice a wing dropping, you go hard over on the ailerons IMMEDIATELY to keep it up - and add a helthy bootfull of rudder. The goal is to induce some yaw, get that wingtip moving quickly up - before it digs into the dirt. The ailerons alone will not be enough. As soon as you get the wing coming up, it's time to take some rudder out. You're not worrying too much about staying directly behind the towplane. It's all about keeping the wings out of the dirt while you are accelerating. Once you get about 30 kts, the ailerons come alive, and then all is well. You have to keep the wings from digging in until then. If the wing digs in, all you can do is release and stay aboard for the ride. You're moving slowly, so unless you hit something damage is unlikely. The right wingtip of the one I bought was damaged years ago. Minor dents and some riveting work in the aileron told the sad story. Someone stayed on too long, dug in too hard. The logbooks contained the terse entry "Right wingtip repaired after groundloop." Remember, it's experimental amateur built, so the recordkeeping rules and other requirements of 14CFR43 do not apply. My first few flights in the glider were interesting, but at least they were off a wide grass runway with little opportunity for the wing to dig in. Eventually, I got the hang of making the large, precise required control inputs quickly, of keeping it balanced without roll control until I was fast enough for the ailerons to come alive, and the takeoffs became routine. One day, after not flying a glider for over half a year, I got back in my HP-11. In retrospect, my first glider flight in half a year should have been in something much more docile - a trainer - or maybe a dual flight in a powered taildragger. What's worse, both were available to me, right there at the airport. I'm not sure what I was thinking - I had just gotten the condition inspection done and signed off, and I wanted to fly it. I was flying all the time - I just forgot how little glider or tailwheel flying I had done in the past year. It was poor decisionmaking. It did not help that this time, the tow would be off a paved runway only about four feet wider than my wingspan. I had flown off that runway before - but that was when I was current in gliders and taildraggers. Now I was current in neither. It had been over three months since I flew a taildragger of any kind, and that time, after over half a year of not flying tailwheel I needed help on the first attempt, though the second landing was safe if not pretty. If I had thought about that before flying, I might have made a different decision. Carefully I checked everything, strapped in, and gave the go. There was about 7-10 kts of wind, almost all cross from the right. As soon as I got going, I could see the right wing dropping. I put in full left aileron, some left rudder - then a lot of left rudder. But already I could see that it was too little, too late. I felt the wingtip bite, and fumbled for the release. A second - and then I was free. But I was sitting at nearly 90 degrees to the runway, pointing into the wind. I got out, rattled, and looked at the wingtip. I saw damage. "****. I bent it." My wing runner, a recently minted commercial glider pilot and FAA inspector, asked "Isn't that the wing that had the damage?" He ought to know - he had just looked the glider over carefully, in preparation for buying a half share in it. For a moment, I was so shaken I couldn't remember. Then I saw the rivets and realized he was right. I looked carefully at the wingtip. Were there new dents there, or had it always looked like that? In my state, the damage looked terrible, but stepping back I realized it was minor. The real danger in damaging the wingtip of a metal ship is not the skin - that's trivial, since almost no weight is carried there. The real risk is damage to the spar at the wing attach points or to the flight control system. Fortunately, on the HP-11 this is completely exposed to the eye, covered only by a plexi shell. I looked at the spar. The massive metal assembly stared back at me, and I realized how overbuilt that spar was, and how much force would be required to damage it. The skin then? I looked at the top and bottom surfaces of the wing. Smooth as glass. I checked the movement of the ailerons. Free and correct, smooth to full deflection. Maybe all I did was scratch the paint? We inspected the glider and came to the conclusion that all I did was drag a wingtip throught the tall grass and short brush - embarassing and rough on the paint but not actually dangerous. Then we restaged the glider and I got back in. This time, the wing runner decided to move to the upwind side. On the second launch, I was READY. The moment I saw the slightest dip in the right wing, I came in with full aileron and nearly full rudder. I stopped it dropping, and a second later it was coming up. Taking out most of the rudder, I waited. By the time the left wing began to dip, I had full right stick and only a little right rudder. It was enough. And then I was airborne. I took a tow to 4000 ft, not sure there would be any lift and wanting to practice stalls so I would be sure of not doing something this bad on landing. As it turned out, I got only 30 minutes out of that flight - I had quickly lost 1500 ft doing landing configuration (full flap) stalls and there was very little workable lift. The landing was uneventful though I used up almost 700 ft of runway - much too much for my tastes. I waited an hour, hoping the lift would improve, and took a normal tow the second time. The takeoff was a much more relaxed affair - I knew, once again, just how much rudder was enough. Doing it right once brought it all back. This time, in the weak and disorganized lift, I managed to scratch out an hour. The landing this time was perfect - full flaps, soft, on both wheels, and stopped in well under 500 ft without any significant braking, despite having to come in over power lines. I was back in tune with my ship. As I tied the glider down, I inspected it once more. Once more I could not be sure if I had added a couple of little dents to what was already there, but after a very careful inspection I was convinced it was in condition for safe operation. I had thought that seeing what I did would have scared off my potential buyer, but I was wrong. I guess you see a lot when you accumulate thousands of hours of taildragger time. He had seen many groundloops, including one from the inside of a Luscombe he was flying. He understood exactly what happened, knew it could well happen to him - and was not worried. I got into my airplane to fly home, and I realized that a year of flying almost exclusively tri-gear had indeed made me complacent, willing to wait just a second more to see what would happen before taking action. I resolved to either keep flying my HP year round, even when there was no lift, just to keep current, or get some powered tailwheel time on a regular basis. Skills will rust with disuse. Michael |
#33
oups.com... Funny story about spot landings....I was flying near Marana, AZ back in the 70's...then landed exactly on the spot with zero forward movement....in my helicopter. gggg :-). About 30+years back I was hired to check out a group of M.D.'s in their club C-195. Good group of pilots and a lot of fun. Great airplane and very capable. Does yours have the Geiss gear or is it rigid? 27charlie has the light crosswind gear. Deb -- 1946 Luscombe 8A (his) 1948 Luscombe 8E (hers) 1954 Cessna 195B, restoring (ours) |
#34
Some of it is tailwheel twin engine like Beech 18.
Ol Shy & Bashful Back when I was chief pilot of Be-18 operator, our POI opened the C-45 manual and pointed at the statement about 3-point landings being prefered. He grinned because he knew that no one did 3-point landings in a Twin Beech. What he didn't know is that I cut my baby teeth in the right seat of a Twin Beech. You should have seen the look on his face. D. |
#35
On Tue, 29 Nov 2005 18:09:02 -0500, "Capt. Geoffrey Thorpe" The Sea
Hawk at wowway d0t com wrote: Depends on the airplane, depends on the brakes. Yep. This is about a Clipper. z |
#36
Dave Doe wrote: In article , Cub Driver usenet AT danford DOT net says... 2,600' of runway - can't see how you could run out of room - short of performing 5 T&G's on it. How do you get on on 700' runways? Pay no attention to this comment, my friend. Actually... my apologies - over here in kiwiland RWY's are in *meters* - and even though I typed my reply in feet (') - my brain was engaged in meters. So sorry 'bout that - Reid and Julie. I'm fairly used to landing on 'shortish' fields - as we have many of 'em here. Hell.. even the grass strip at NZCH (international) is pretty short - and has caught many a student out trying touch and goes after landing halfway down it Further, there's a farmers fence at the endof it - it's caught a few planes in it over the years. :-) .. Last time I was down that way (crosscountry to Oamaru) I overflew the smog choked airfield. Solid clag. |
#37
Capt Doug:
So did you three-point the Twin? As a Navy aircraft mechanic and sometimes "plane captain" on the Twin--the Navy designation was "SNB"--I had to tend to hungover BOQ pilots, driving around the sky until it was time for the skipper, now well rested, to land the plane. I never saw a 3-point landing made by the SNB. But watching them land, level, on the mains, it always was a bit dicey to see those struts wobble fore and aft--almost as if the airplane was walking, not rolling, down the runway. So my next encounter with the Twin Beech was more satisfactory. As a smokejumper with the US Forest Service, I never had to land in one at all. CAVU to you, Cap. Dick Behan "Capt.Doug" wrote in message ... Some of it is tailwheel twin engine like Beech 18. Ol Shy & Bashful Back when I was chief pilot of Be-18 operator, our POI opened the C-45 manual and pointed at the statement about 3-point landings being prefered. He grinned because he knew that no one did 3-point landings in a Twin Beech. What he didn't know is that I cut my baby teeth in the right seat of a Twin Beech. You should have seen the look on his face. D. |
#38
On 2005-11-30, Michael wrote:
The particular glider I own, a T-tail HP-11 N821Z, was designed in 1962 but was still competitive in 1969, placing third at major contests. Truly the design must have been a wonder in its day. But to get the performance, some things had to be sacrificed. Since the design was for competition flying, something a novice pilot presumably would not do, the decision was made to sacrifice forgiving handling characteristics. :-) My third takeoff in that glider was at Coulter Field, in a crosswind (where they used the taxiway as a glider runway). I have *never ever* been busier on takeoff than on that takeoff. You'd be amazed at how having runway lights only three feet from each wingtip (of course, the lights on substantial short poles) and a 7-10 knot crosswind and bugger all aileron authority concentrates the mind. That takeoff is forever etched in my memory. I didn't groundloop though, but I'm sure my heart rate was through the roof until I got airborne. (What makes it worse in that ship is that the tow hook is a compromise hitch, rather than a nosehook, so the tow plane does not aid in directional control). I decided I'd had enough of that runway. As we climbed out I looked at the grass runway that was directly into the wind. I decided I would land on that. I scratched around for an hour, never getting much above 1200 feet. On return, I flew the pattern for the grass runway. On very short final (like 50 feet) - now too low to make the big main runway, too far to turn and make the normal glider runway or taxiway, I realised that I had something like an 18 meter wingspan and the grass runway was around half that width - surrounded by tall grass and a bit of brush. Oh no. Not long after touchdown, of course one of the wings starts to drag through the tall grass, and then I'm merely passenger. The glider shot off the side of the runway. I couldn't see anything except tall grass going by the canopy. It's a horrible feeling of having full opposite rudder in and absolutely nothing happening. Finally I came to a halt. I dragged the glider out of the tall grass, removing the tufts of grass it had picked up so to hide the evidence. But it was too late. The girl on the electric golf cart had already come to tow the glider back in. "Was anyone watching me land?" I asked. "Oh yes, we were ALL watching!" she said, with unnecessary glee I thought. Fortunately, the long grass stopped a wingtip from banging into the hard ground, so no damage was done, well, except to my ego. I'm sure if I turned up at Gary Gandy's place wanting to fly a glider, he'd remind me of that day. -- Dylan Smith, Port St Mary, Isle of Man Flying: http://www.dylansmith.net Oolite-Linux: an Elite tribute: http://oolite-linux.berlios.de Frontier Elite Universe: http://www.alioth.net |
#39
On 2005-11-30, Deborah McFarland wrote:
My husband won a spot landing contest this past October using a wheel landing. He can also land in 900 ft of grass with them. He practices flying down the runway just above a stall all the time. He pulls the power and gently drops on the mains. It's a joy to watch. Wheel landings are the tailwheel pilot's secret weapon in spot landing contests. If a spot landing contest is being run by a tailwheel pilot, you'll often find they are banned :-) -- Dylan Smith, Port St Mary, Isle of Man Flying: http://www.dylansmith.net Oolite-Linux: an Elite tribute: http://oolite-linux.berlios.de Frontier Elite Universe: http://www.alioth.net |
#40
Instead, while I was pulling the throttle back to idle, I was still carrying too much power for landing. A few extra rpms make a big difference in a light airplane. My rpms had to be adjusted twice before everything seated (or whatever it does). Especially a light plane with a bigger engine than normal fitted: the Auster we have here has a 160hp O-320 instead of the 90-ood horsepower Gipsy engine it originally had. Most planes need around 1900 RPM to maintain level flight. The Auster can maintain level flight with that engine at about 1450 RPM. So you definitely want to get it all the way to idle. The Auster also stalls power on, flaps down at 29 mph. (Without a glider in tow, the takeoff performance is rather good :-)) -- Dylan Smith, Port St Mary, Isle of Man Flying: http://www.dylansmith.net Oolite-Linux: an Elite tribute: http://oolite-linux.berlios.de Frontier Elite Universe: http://www.alioth.net |
| Thread Tools | |
| Display Modes | |
| Mini-500 Accident Analysis | Dennis Fetters | Rotorcraft | 16 | September 3rd 05 12:35 PM |
| Got my ground instructor ratings | Yossarian | Piloting | 7 | July 6th 05 03:21 AM |
| Switching to ground.... | David Rind | Piloting | 85 | April 16th 04 07:53 PM |
| ADV: CPA Mountain Flying Course 2004 Dates | [email protected] | Piloting | 0 | February 13th 04 05:30 AM |
| What is a ground loop? | Mike | Piloting | 34 | July 30th 03 07:19 PM |
