#31
David Megginson wrote:
Jay Honeck wrote: Sounds like this Subra woman is a nut job. Even though I'm glad King Daley is going to be the target of her wrath, I don't want the good name of General Aviation -- already challenged on so many fronts -- to be associated with these environmental wackos in any way. I don't know anything about Subra and the specifics of what she said, but an airport apron is essentially the same as a gas station -- lots of fuel spills, oil spills, etc -- and former gas station sites can be very expensive to clean up and redevelop. We're also the last ones still using leaded gas, and lead levels can be a bit high even off away from the apron as a result. http://www.leanweb.org She helped us in getting the state permit revoked for a local power plant and forcing them to the bargaining table which they previously refused to do... CLECO nearly filed bankruptcy, I believe CALPINE is about to, they are partners in it... |
#32
"George Patterson" wrote in message
news:Gkslf.2251$Kg5.1072@trndny06... wrote: But those airports don't sit in the water supply for 7 million people. Chicago used to pull its water from the river and dump its sewage in the lake. This has changed? George Patterson Coffee is only a way of stealing time that should by rights belong to your slightly older self. Chicago gets its water from cribs a couple of miles out in the lake. During heavy rain they dump raw sewage into the river and open the locks to let it run into the lake. Many beaches are closed for extensive periods in the summer due to you know what. They call it some fancy name but the truth is it is crap in the water. |
#33
![]() Rachel wrote: wrote: Rachel wrote: wrote: snip Yeah, because what's underneath CGX is any worse than what's underneath ORD, LAX, MIA, etc. Get off our case. If Daley hadn't ripped the airport up, no one would have cared. But those airports don't sit in the water supply for 7 million people. Oh, I wasn't aware that I was landing in water at CGX. Check a map, water on all sides, and your benzo-xxx will ooze thru the soil and hit water eventually, nice job Wright Bros. ! yawn I can't believe some people find GA-bashing to be exciting. |
#34
![]() Dave Stadt wrote: "George Patterson" wrote in message news:Gkslf.2251$Kg5.1072@trndny06... wrote: But those airports don't sit in the water supply for 7 million people. Chicago used to pull its water from the river and dump its sewage in the lake. This has changed? George Patterson Coffee is only a way of stealing time that should by rights belong to your slightly older self. Chicago gets its water from cribs a couple of miles out in the lake. During heavy rain they dump raw sewage into the river and open the locks to let it run into the lake. The last opening was 3 years ago. The deep tunnel and reservoir project was built to halt this. Many beaches are closed for extensive periods in the summer due to you know what. They call it some fancy name but the truth is it is crap in the water. Mostly storm sewer overflow, little solid matter visible. |
#35
![]() Dave Stadt wrote: "George Patterson" wrote in message news:Gkslf.2251$Kg5.1072@trndny06... wrote: But those airports don't sit in the water supply for 7 million people. Chicago used to pull its water from the river and dump its sewage in the lake. This has changed? George Patterson Coffee is only a way of stealing time that should by rights belong to your slightly older self. Chicago gets its water from cribs a couple of miles out in the lake. During heavy rain they dump raw sewage into the river and open the locks to let it run into the lake. The last opening occured 3 years ago. The deep tunnel and reservoir system was built to halt this. Many beaches are closed for extensive periods in the summer due to you know what. They call it some fancy name but the truth is it is crap in the water. No solids visible, just storm sewer discharge. |
#36
#37
#38
#39
#40
![]() wrote in message ups.com... Dave Stadt wrote: "George Patterson" wrote in message news:Gkslf.2251$Kg5.1072@trndny06... wrote: But those airports don't sit in the water supply for 7 million people. Chicago used to pull its water from the river and dump its sewage in the lake. This has changed? George Patterson Coffee is only a way of stealing time that should by rights belong to your slightly older self. Chicago gets its water from cribs a couple of miles out in the lake. During heavy rain they dump raw sewage into the river and open the locks to let it run into the lake. The last opening was 3 years ago. The deep tunnel and reservoir project was built to halt this. Not much rain the last three years. The deep tunnel has reached saturation a time or two which resulted in raw sewage going into the lake. Many beaches are closed for extensive periods in the summer due to you know what. They call it some fancy name but the truth is it is crap in the water. Mostly storm sewer overflow, little solid matter visible. Storm water overflow does not cause beaches to be closed. Raw sewage does. You don't need to see solid matter for the sewage to be present. |
I want to build the most EVIL plane EVER !!! | Eliot Coweye | Home Built | 237 | February 13th 06 03:55 AM |
Most reliable homebuilt helicopter? | tom pettit | Home Built | 35 | September 29th 05 02:24 PM |
Mini-500 Accident Analysis | Dennis Fetters | Rotorcraft | 16 | September 3rd 05 11:35 AM |
Nearly had my life terminated today | Michelle P | Piloting | 11 | September 3rd 05 02:37 AM |
American nazi pond scum, version two | bushite kills bushite | Naval Aviation | 0 | December 21st 04 10:46 PM |
