Newbie holding questions
Old January 5th 06, 05:59 AM posted to rec.aviation.ifr
Default Newbie holding questions
It's a moot point anyway,
whatever caused my comm radios to go belly up will affect my nav radios the
same way and I won't be able to identify the holding fix.
How does a blown speaker affect my ability to identify the holding fix?
I may not be able to ID the station, but I can check the frequency and
see the needles move. If this agrees with my time estimate, and I can
ID the problem as a blown speaker, under the circumstances I'd be
confident in identifying the fix.
Steve, you have a lot of knowledge of controller issues, which I
respect. However, you do not know why a hypothetical aircraft goes
NORDO unless it's your hypothetical.
Back to the paper stop - the following aircraft gets a hold, and goes
NORDO, reaching the fix eight minutes after the first aircraft has gone
past the fix. You elect not to hold, which puts you eight minutes in
trail where the minimum separation is ten minutes.
This is acceptable and expected under the circumstances? (neutral question)
Jose
You can choose whom to befriend, but you cannot choose whom to love.
  #32
Old January 5th 06, 06:05 AM posted to rec.aviation.ifr
I got cleared to an intermediate fix, "expect no delay."
To me this means your EFC time =is= the time you reach the intermediate fix.
Jose
  #33
Old January 5th 06, 01:39 PM posted to rec.aviation.ifr
"Jim Macklin" wrote in message
news:022vf.40587$QW2.6269@dukeread08...
A hold, by definition is a delay.
But if you don't enter the hold you are not delayed.
  #34
Old January 5th 06, 02:16 PM posted to rec.aviation.ifr
A Lieberman wrote:
What light? You have not seen my radios? There are no lights anywhere.
Are you serious? I don't think I've ever seen a tranceiver of any kind
(not just limited to aviation) which didn't have some sort of visual "Tx"
indication.
  #35
Old January 5th 06, 02:56 PM posted to rec.aviation.ifr
Steven P. McNicoll wrote:
Without an EFC I wouldn't enter the hold. It's a moot point anyway,
Although that is certainly a likely result in a light aircraft, it may
not be in an aircraft with more sophisticated avionics busses.
91.185 is written with the premise that comm capability fails but nav
capability continues to exist.
Your scenerio is not a 91.185 situation; it's a major emergency if in IMC.
  #36
Old January 5th 06, 03:09 PM posted to rec.aviation.ifr
Yes, but I said if you are holding and don't have the EFC
time and your comm fails, when do you leave the fix. ATC
issues a clearance to a fix as a limit, expecting to have
their problem resolved before you get there and to issue a
further clearance. The pilot may lose 2way comm before he
enters the hold and not know it, since a radio report is not
required when in radar contact, in any case, he might not
know he has lost comm until he is in the hold.
The issue is those 2way comm failures in conditions not
covered by 91.185.
The PIC is always told to clarify any clearance that is not
clear or fully understood... asking for an EFC time is just
that.
James H. Macklin
ATP,CFI,A&P
some support
"Steven P. McNicoll" wrote in
message
news |
| "Jim Macklin" wrote
in message
  #38
Old January 5th 06, 03:56 PM posted to rec.aviation.ifr
indication.
KX-170? ...for one example.
  #40
Old January 5th 06, 04:46 PM posted to rec.aviation.ifr
Peter R. wrote:
At some locations timed approaches permit more than one approach at a
time, provided the holding pattern meets criteria and the missed
approach does not conflict with the inbound tracks.
Timed approaches were once used a lot, then over time diminished in
their use, and now they are on the increase again.
Thanks, Tim.
What are some example of airports where timed approaches are in use?
Cheyenne (Sp?) WY (non-radar approach control)
Eagle, CO
San Luis Obispo, CA
Questions from a newbie. Andrew Tubbiolo Home Built 9 September 14th 04 01:40 AM
Newbie with questions... Mike \(Remove X's to reply\) Piloting 10 February 14th 04 01:16 AM
Newbie questions Rail / Ejector launchers AL Military Aviation 19 November 14th 03 07:47 PM
Basic Stupid Newbie Questions... John Penta Military Aviation 5 September 19th 03 05:23 PM
