Can I fly it at night?
Old January 4th 06, 03:06 PM posted to rec.aviation.piloting,rec.aviation.homebuilt
Default Can I fly it at night?
I have a 1941 Chief with lights on it. There's one light on
each wingtip and one on the top of the fin. There's no
anticollision light/strobe or landing light. There are
wires from the 3 position lights to the cockpit, where they
end. The engine has no alternator or generator and never
has had one. There's no battery, battery compartment,
starter or electrical system. I do have a portable sealed
lead acid battery that I charge between flights to power a
radio and intercom.
There's nothing in the paperwork about "day VFR only" and
there's no AFM or even any POH.
I've looked at 91.209 and 91.205 (c). I've got position
lights, I won't be operating for hire, so I suppose a
landing light is not legally required. I suppose a larger
battery would be an adequate source of electrical energy for
short flights. Can I fly at night if I install an
anticollision light? Anyone want to comment on what I need
to legally fly at night for short local flights? Does
anyone think the disconnected lights have made the aircraft
legally unairworthy for the last 65 years? Does anyone know
how these were originally powered (Dry cells?)
Thanks for any information.
Old January 4th 06, 03:49 PM posted to rec.aviation.piloting,rec.aviation.homebuilt
On 4 Jan 2006 09:06:03 -0600, bstanton null.com wrote in
I have a 1941 Chief with lights on it. [...] Does anyone know
The information should be in the aircraft's Type Certificate. You
should be able to find it he
http://www.airweb.faa.gov/Regulatory...e?OpenFrameSet
Old January 4th 06, 05:39 PM posted to rec.aviation.piloting,rec.aviation.homebuilt
In this case the type certificate doesn't make a difference. The FAA
current FARs seem to require a strobe for night flying. Its not like
college catalog rights, FAA FARs don't grant historic rights.
-Robert
Old January 7th 06, 07:58 AM posted to rec.aviation.piloting,rec.aviation.homebuilt
On 4 Jan 2006 09:39:41 -0800, "Robert M. Gary"
Welll... Kinda. I have wing tip position lights, but no rotating
beacon. Just top and bottom strobes which are legal in that old
airplane.
Never plan on a single landing light working.
www.rogerhalstead.com
-Robert
Old January 4th 06, 05:38 PM posted to rec.aviation.piloting,rec.aviation.homebuilt
I read it as you must have the anticollision light. We had to install
it on the Cessna 140 for this reason too. I think the only difference
is that you have more choice in color because of your age. I don't see
anything here that counters the statement "An approved aviation red or
aviation white anticollision light system".
91.205.(c)
(3) An approved aviation red or aviation white anticollision light
system^M
on all U.S.-registered civil aircraft. Anticollision light systems
initially^M
installed after August 11, 1971, on aircraft for which a type
certificate^M
was^M
issued or applied for before August 11, 1971, must at least meet
the^M
anticollision light standards of part 23, 25, 27, or 29 of this
chapter, as^M
applicable, that were in effect on August 10, 1971, except that the
color^M
may^M
be either aviation red or aviation white. In the event of failure of
any^M
light of the anticollision light system, operations with the aircraft
may be^M
continued to a stop where repairs or replacement can be made.^M
Old January 4th 06, 06:51 PM posted to rec.aviation.piloting,rec.aviation.homebuilt
That's how I read it too.
Old January 4th 06, 05:50 PM posted to rec.aviation.piloting,rec.aviation.homebuilt
I am very interested in the response to this question as well.
My clipper came with a full electrical system, nav lights and a panel light,
but no anti-collision.
The rules for anti-collision coverage don't go back as old as my plane, yet
I do not see any "grandfather" clause in the FARs.
I know there are rules that are not articulated in the FARs sometimes (like
shoulder harness rules).
Does anyone here know the whole story?
"bstanton" null.com wrote in message
radio and intercom.
Old January 4th 06, 05:56 PM posted to rec.aviation.piloting,rec.aviation.homebuilt
See an aircraft mechanic who will ...
install a legal anti-collision light (LED strobe uses the
least power)
fabricate a proper battery box for a battery,
perhaps install a voltmeter,
fabricate an electrical bus, circuit breaker and switch,
perhaps an external power connection for charging,
do the weight and balance and update the paperwork and
aircraft logs.
The airplane may have had an external wind-driven generator
originally, you could restore that with a modern alternator
at the cost of a 1 or 2 mph.
James H. Macklin
ATP,CFI,A&P
some support
on
they
sealed
| radio and intercom.
for
need
aircraft
know
Old January 4th 06, 06:28 PM posted to rec.aviation.piloting,rec.aviation.homebuilt
Is there room in a Chief to put an alternator? When I had my Chief we
thought about this for a minute and decided it was way too much work. I
did look at a Champ that had the wind generator thing but it seemed
that it put out very limited power. When you only have a few hundred
pounds of useful load adding a battery can seem overwhelming.
-Robert
Old January 4th 06, 08:21 PM posted to rec.aviation.piloting,rec.aviation.homebuilt
I'd call the local FSDO.
FAA PPL night flight requirement - does it have to be DUAL? Peter Clark Piloting 21 January 6th 05 12:38 AM
Night solo XC? G. Burkhart Piloting 51 October 14th 04 03:11 PM
Night of the bombers - the most daring special mission of Finnishbombers in WW2 Jukka O. Kauppinen Military Aviation 4 March 22nd 04 11:19 PM
