ANNUAL, 2005 Redux...
Old January 12th 06, 04:35 PM posted to rec.aviation.owning
Default Engine technology. Was: ANNUAL, 2005 Redux...
Aaron Coolidge wrote:
A 6-liter IO-360 can make 200 HP all day long as well.
Really? What engine is that? Lycoming's 6 liter engines are rated at 180 hp
(some less than that), and it's generally considered a bad idea to try to run
one at 100% for long periods of time.
George Patterson
Coffee is only a way of stealing time that should by rights belong to
your slightly older self.
  #32
Old January 12th 06, 06:05 PM posted to rec.aviation.owning
In defense of aircraft engines, the 6 L car engine has to do 200 hp at
2700 RPM & go thru a weight reduction program so severe that it ends up
being aircooled with no thermal inertia. Then it has to have its
design frozen by certification by the bureaucracy after which it is
second guessed by a ruthless legal system. Then its users expect it to
last 2000 hrs at say 70% power.
Then for some reason, only a few engines get built since the demand is
so low.
  #33
Old January 12th 06, 07:09 PM posted to rec.aviation.owning
And, in fact, that 6 liter car engine probably won't put out 200 hp at 2700 rpm.
Slow an auto engine down that much, and it usually puts out about 60% of it's
claimed maximum power. Or you can add reduction gearing that also robs power. So
you're really looking for a 6 liter auto engine that puts out about 330 hp.
George Patterson
  #34
Old January 12th 06, 08:14 PM posted to rec.aviation.owning
George Patterson wrote:
: Aaron Coolidge wrote:
: A 6-liter IO-360 can make 200 HP all day long as well.
: Really? What engine is that? Lycoming's 6 liter engines are rated at 180 hp
: (some less than that), and it's generally considered a bad idea to try to run
: one at 100% for long periods of time.
IO-360-A3B6D in a Mooney 201, among many others. Lyc claims their engines
can be run at 100% power continuously in the TCDS. See TCDS 1E10, first page.
"Max Continuous Horsepower/RPM full throttle at Sea Level pressure altitude:
200-2700".
The HIO-360-C1A (among others) is rated 205HP @ 2900 RPM continuously
Aaron C.
  #35
Old January 12th 06, 10:03 PM posted to rec.aviation.owning
No such thing as a 6 liter IO-360.
  #36
Old January 12th 06, 11:05 PM posted to rec.aviation.owning
Newps wrote:
: : A 6-liter IO-360 can make 200 HP all day long as well.
: No such thing as a 6 liter IO-360.
OK, you got me: 5.88295598 liter IO-360, which is actually 359 cubic inches.
Kind of like Ford's "5.0" liter 302 V8, which is actually 4.94889333 liters.
Or, are you objecting to "liter" instead of "litre"? I actually prefer
"litre", but the USA spelling is supposed to be "liter". If I use "litre"
I will have to start using "aeroplane" as well, I suppose...
Aaron C.
  #37
Old January 13th 06, 02:01 PM posted to rec.aviation.owning
Matt Whiting wrote:
Eduardo K. wrote:
an 6 liter automotive V8 can make 200hp all day long...
And what is the maximum HP of this engine that you have in mind?
300? 350?
thing is, aircraft engines are actually good and so are automotive
engines... the difference in advertised power is just that aircraft
engines are designed to be run at 75% power all day long and car
engines for short peaks of a very high number....
just different design objectives.
Eduardo K. |
http://www.carfun.cl | "World domination, now"
http://e.nn.cl | Linus Torvalds
  #38
Old January 31st 06, 03:22 AM posted to rec.aviation.owning
Default ANNUAL, 2005 Redux... (Aztec heater)
Speaking of being toasty warm, the last trip I made in my Aztec was at the
first
of January at night with the OAT around 20 degs F. The heater was not
working.
After a 6 hour round trip in that, even with heavy clothes, jackets, gloves
and blankets,
we were miserable. It is hard to tune the radios with ski gloves, so my
right hand was in
and out of the glove a lot, and the result was numb fingers.
That finally provided the motivation needed to get the heater working. It
is a Southwind
Model 940DB12, which is rated at 15,500 BTU/hr on low and 27,500 BTU/hr on
high. I used to wonder if it were even capable of keeping the cabin warm,
but after
looking at my old thermo book and doing a little calculation, I determined
that if a heater
that size can't keep the Aztec cabin warm, something is really, bad wrong.
Anyway, after studying the service manual on the heater for a while to
understand how it
was supposed to worked and doing a little trouble shooting, it was revealed
that the heater
overhaul shop had incorrectly wired the heater. I don't know how it ever
passed a burn
test. I'll bet it didn't. It would light from the prime fuel charge, open
both fuel
values, burn very rich and smoke migthly until the high temperature
thermostat opened which
closed both fuel values. Only the high heat fuel value was suppoed to be
controlled
by the thermostat. Controlling both fuel values with the thermostat caused
combustion
to stop once the heater exceeded the 240 deg F outlet temperature. Once the
flame was
out, the heater had to be turned off, allowed to cool, and reprimed before
it would ignite again.
It was supposed to ignite, burn on low, and only open the second fuel value
if the operator
selected high heat. In high heat, the increased fuel flow requires
additional combustion air
for the proper mixture. Proper combustion airflow depends on an increased
pressure head
from the slipstream. The airplane needs to be flying to provide this 1" to
2" of water pressure
head in the intake. There is a very small ram air scoop on the air intake
for this purpose, which
has been "calibrated" with a couple of small holes drilled into the flage,
at least I'm guessing that what
the small holes are for. This is why the airplane's Approved Flight Manual
advices against using
high heat during ground operatiions and cautions that doing so will result
in excessive smoking
from the heater exhaust.
Once it was wired to match the wiring diagram in the service manual, it
works like a champ.
We have heat!!!!!!!
I'm still thankful for you guys educating me about C&D and I will use them
for
parts and/or a rebuilt should the old Southwind hang it up, but for now, it
is going
strong. Now I need to add a CO detector in the cabin to warn is the heat
exchanger
springs a leak.
I also need to get motivated to relace the side windows like. I need Jim
Burns for
my partner :-)
Ronnie
"Denny" wrote in message
That's true Jim... I am toasty warm and heven't even run the heater on
the highest setting yet. Subzero wx is comin so I will have the chance
I'm sure... The carb seems to be running just fine, now that we put
all the parts inside that the designer intended...
denny
  #39
Old January 31st 06, 02:32 PM posted to rec.aviation.owning
We have heat!!!!!!!
Congrats!! Although we have a Janitrol, both heaters are fairly simple,
it just takes some patience to figure out what's going on. Am I remembering
correctly that you are in TX? There's also a well known heater shop in
Dothan AL, http://www.haroldhaskinsinc.com/pages/1/index.htm
Burns for
my partner :-)
The side windows are easy and you can trim them to fit with a belt sander.
Just clean everything up real good before installing so you get a good bond
if you use silicone. Clean up the excess while it's wet, you'll never get
it off without damage if you let it dry. You can also use the original black
window seal goo. We bought LP Aero windows, 1/4 which required a 337, or
you can go with 3/16 or 1/8" and thermopanes from Great Lakes without a 337.
  #40
Old February 1st 06, 04:16 AM posted to rec.aviation.owning
Yes, I'm Austin, TX.
Matter of fact, I didn't want to mention any names, but since you
brought it up, that heater shop in Dothan, AL is the one who's
sticker is on the heater and who's signature is in the log books
as having done the last overhaul. Hopefully their work on testing
the heat exchanger for leaks was better than their work on the wiring.
Maybe the tech who did the wiring was having a bad hair day.
Everybody makes mistakes, but I would have expected those errors
to be caught during the burn and post installation test. But who knows,
maybe the heater left their shop propely wired and adjusted and the
mechanic in the field who reinstalled the heater decided he needed to
move a few wires around to make it work better.
I saved your original post about installing the side windows. I need to
tack that project. One of our windows has a crack in the inside pane.
Maybe when the weather gets too bad to fly here in Texas, I'll tackle that
project :-)
Ronnie
"Jim Burns" wrote in message
We have heat!!!!!!!
simple,
remembering
Burns for
my partner :-)
bond
black
337.
20 Nov 2005 - Today's Military, Veteran, War and National Security News Otis Willie Naval Aviation 0 November 20th 05 09:43 PM
2005 ANNUAL PASCO SEMINARS, BANQUET AND AWARDS PRESENTATIONS Marc Ramsey Soaring 0 November 8th 05 02:36 AM
Oshkosh 2005 Redux Jay Honeck Piloting 17 August 6th 05 07:14 AM
Oshkosh 2005 Redux Jay Honeck Home Built 13 August 5th 05 04:35 AM
Oshkosh 2005 Redux Jay Honeck Owning 13 August 5th 05 04:35 AM
