#31
Maybe someone more acquainted than me in nuclear physics
can shed some light on this, but my understanding is that the Bohr model is false: The electrons revolving around the atom would spin into the core, for one. It is thus a model that could not sustain an atom in life. After all, this is one of the main paradoxes that lead to the creation of quantum mechanics. But I'm digressing. The point I want to make is that, just as the Bohr model is taught in school almost a century after it has been found to be false (and not just a bit inaccurate), there is an instructional role for models that are false, but useful as a stepping stone to the understanding of very complex phenomena. One has to state the model, make people understand it AND THEN exlpain why it is not correct. Otherwise, it is most often the case that complex phenomena tend to remain within the purview of the very few that will come to understand the very complex mathematics that describe the phenomenon in its full details. There is plenty of good understanding that can be gained by explanations that contain false premices. Should we be as purist as this to reject even a cursory mention of things that are not 100% accurate in the educational process? So, when trying to explain the world of physical matter, do we bring out the Bohr model, or should we skip this and directly introduce the fuzzy world of QED. In the same principle, when trying to explain the very complex phenomenon of wing lift, do we go from stating the Bernulli effect and Newton's 2nd law to diferential equations of fluid dynamics -- or possibly stop there, explaining that the actual phenomenon is too complex for 'common people' to understand? Or can we bring up a series of models, each more complicated, to ease in an understanding of the phenomenon by helping people visualize what is taking place. Of course this can only happen up to a point and then we are faced with the pure mathematics. I would like to know what this forum thinks in terms of this? In my experience, quite a few gliding instructors are either very much missinformed about the aerodynamics of lift (and keep on missinforming students), or offer explanations that while accurate fail to answer a student's question by advancing the understanding of what take places. This is very discouraging for most people and it is only the few who will then go back into the literature and try to sort things out. The funny thing about this is that, while it is not very important to know about aerodynamics to fly a glider, all sorts of misinformation eventually trickles into discussions and advice about such things as the best bank to turn in, or when a stall occurs etc. So what should we do about this? At 10:30 11 January 2006, Bert Willing wrote: Well, trying to explain something by starting with a statement which is completely wrong is a very strange educational twist... The Bohr model is not accurate enough to explain all details, but it is not wrong. Bert ASW20 'TW' 'Alexander Georgas' wrote in message ... OK OK, I said it was inaccurate to begin with! Good to see this has stirred up some debate, thought. While I agree this is more urban myth than fact, I do feel that it helps more in visualization than statements such as 'pressure builds below the wing' or 'it is the Bernulli effect above the wing' (some even refer to the Venturi effect). I feel that the equal transit time proposition is a good first step in helping people visualize what happens when lift is generated, i.e. people start to think about the flow fields over the entite wing section in a more visual manner. It is quite intuitive and easy to visualize. Once one has actually understood this, he can now accept that it is not true and move to the next level of understanding. So if you drop the wing geometry idea (which I do not aspise to begin with) and replace it with the concept of angle of attack and also do not get too stuck with the 'particles exit at exactly the same time' proposition, you are starting to visualize things more properly. Once you understand this, and the fact that the flow over the wing is much faster than what the equal transit time proposition must suggest and that the angle of attack has created a low pressure area which has accelerated the top flow field quite considerably, you can start visualizing things like the vortices that are generated once the two flows meet up behind the trailing edge etc. Now you are getting somewhere! Otherwise, jumping from the 'there must be a Bernulli effect somewhere' to the Euler equations is just too much of a leap for the imagination (at least my imagination). Now, concerning the Newtonian explanation, I consider this too much of a cop out. Ok we all know it is correct, and it is plain simple to understand. It just doesn't explain anything about the mechanics of flight. It is as saying (it is, in fact, saying) that the laws of energy conservation will be upheld and that the laws of thermodynamics will not be broken and that the universe will keep on working the same way as it was before. We sort knew this already. So where is the understanding that comes from this explanation? So I feel that while the equal transit time paradigm, while false, is a good starting point for introducing people to the aerodynamics of wing sections. They just need to be told, once they understand the concept, why it is false. It is as useful as the Bohr model of the Atom: extremelly inaccurate, but easy to visualize as a starting point to understanding a very complex phenonenon. Would you ever introduce particle physics to a student by writing down the Schroedinger equation and solving a few Hamiltonians? Alexander Georgas At 16:24 10 January 2006, T O D D P A T T I S T wrote: Alexander Georgas wrote: Ok, here is another way this can be explained (if just a bit inaccurate): Sorry, but this is a lot inaccurate (a.k.a 'wrong') The critical point to consider is angle of attack. You just need to think of the airflow meeting the wing at a specific angle. If you now imagine the airflow separating to move above and below the wing section as two particles, you have the following explanation: -The particles are going to separate at the leading edge and meet up together approximatelly at the wing's trailing edge. The particles do *not* meet up at the trailing edge. This is often referred to as the 'equal transit times' explanation of Bernoulli, which is thoroughly discredited. -Because of the angle of attack (and of the wing's thinkness), the air particle that will travel above the wing section will have a greater discance to cover, so it will have to run faster if it is to meet up with the other particle which is traveling below the wing section The particles do not have to meet up. -Particles traveling at greater speeds (compared to particles in neighboring areas) create areas of low pressure -- just think: because the particles are running faster over the wing compared to under the wing, there are fewer of them in a specific area. Alternativelly, you can take Bernoulli's word on this one. Bernoulli does not explain the flow pattern. Bernoulli explains the lift (pressure differentials given a specific flow pattern. You have to call in some other physics, namely that the air flows smoothly off the trailing edge, to establish the flow pattern. Once you have that, you apply Bernoulli. -Now let's examine the situation from the perspective of the wing. There is a low pressure above and a high pressure bellow. The resulting force is thus upwards (in relation to the angle of attack). The only presumption which remains to be explained is why the two particles have to meet at the back of the wing section. The easiest way to gloss over this Take a look at John Denker's start page: http://www.av8n.com/how/ See the graphic and the bands of red, orange green blue? The blue band air over the top hits the trailing edge before the blue band air at the bottom, even though they started out together. is to consider that if this is not approximatelly the case, an imbalance will be created whereby there will be more air crossing below the wing section and a low pressure area buildup at the top back end of the wing, created by the lack of air (teh air has just not had the time to reach there). This would probably invite air from below the wing to bleed back up towards the back top. Guess what, that 'low pressure buildup' causes the air on top to accelerate, and it does tend to cause the high pressure to flow around to the top (resisted by air's finite viscosity and the sharpness of the trailing edge). In this case, the airflow above the wing would separate from the wing section before the trailing edge (does this sound a bit like a stalled wing?) In a stalled wing, this does happen, but we're talking about a non-stalled wing and in that case the air flows faster over the top. I don't know how much science there is behind this explanation. I just find it a bit easier to swallow than the Newtonian explanation. In my view the action-reaction way of putting it (air is deflected downwards) is true, but unable to shed any light on the mechanism. I agree that the Newtonian explanation is hard, but so is the Bernoulli. That's the nature of lift. I think of it like this: When the wing starts forward at a positive angle of attack, the space behind the wing's upper surface is being swept clear of air molecules - at least that's what the wing is trying to do. However, in a fluid (air), sweeping the molecules clear would produce a vacuum behind the wing, so the instant that the pressure begins to fall behind the wing, air from on top and ahead of the wing and air above the wing begins to rush towards this region. The air from ahead and on top of the wing that rushes back towards this low pressure region is being accelerated - exactly what the Bernoulli explanation needs for its lower pressure due to faster flow. The air above the wing moving down, coupled with higher pressure air below the wing (also moving down to escape that higher pressure) produces downwash - exactly as the Newtonian explanation needs. In reality, these are just two faces of the same coin. There's no need to use the false 'equal transit times' explanation of Bernoulli. It is just an energy checks-and-balances way of explaining lift, which we already know occurs. Alexander Georgas -- T o d d P a t t i s t - 'WH' Ventus C (Remove DONTSPAMME from address to email reply.) |
#32
Alexander Georgas schreef:
There is plenty of good understanding that can be gained by explanations that contain false premices. Should we be as purist as this to reject even a cursory mention of things that are not 100% accurate in the educational process? Being an aerospace student myself I`m probally a bit of a purist as well. Nevertheless I think that the final goal of teaching aerodynamics (anything actually) is understanding, not perfectionism. In the same principle, when trying to explain the very complex phenomenon of wing lift, do we go from stating the Bernulli effect and Newton's 2nd law to diferential equations of fluid dynamics -- or possibly stop there, explaining that the actual phenomenon is too complex for 'common people' to understand? What`s wrong about only telling the short version of the theory, without complicated stuff: "An airfoil creates an flow which accelerates air downwards. This results in a pressure (and shear) field on you`re wing which causes both lift and drag. Nothing really complicated about that I guess, and no problem with applying it to reality at all. I would like to know what this forum thinks in terms of this? In my experience, quite a few gliding instructors are either very much missinformed about the aerodynamics of lift (and keep on missinforming students), or offer explanations that while accurate fail to answer a student's question by advancing the understanding of what take places. This is very discouraging for most people and it is only the few who will then go back into the literature and try to sort things out. About a year ago I was having a discussion with a couple of gliding instructors. None of them understood "anything" about aerodynamics and I heard the weirdest theories. Nevertheless they seem to teach flying quite well without any problems for their student. Not understanding flow completely doesn`t seems to be such a problem in flying a glider. The funny thing about this is that, while it is not very important to know about aerodynamics to fly a glider, all sorts of misinformation eventually trickles into discussions and advice about such things as the best bank to turn in, or when a stall occurs etc. So what should we do about this? Just skip the complicated theory? Real world aerodynamics is extremely complicated with a lot of issues (especially vortices) still beyond oure understanding. You can`t expect every glider pilot to understand complex differential equations or the navier-stokes equations. Instead of putting a lot of effort in explaining lift we maybe should concentrate a bit more in the relationship of weight, surface and so on, which is very usefull in normal flight operations. The square and squareroot equations seems to be complicated enough for most pilots. Jarno Nieuwenhuize, The Netherlands. |
#33
of this? In my experience, quite a few gliding instructors are either very much missinformed about the aerodynamics of lift (and keep on missinforming students), or offer explanations that while accurate fail to answer a student's question by advancing the understanding of what take places. This is very discouraging for most people and it is only the few who will then go back into the literature and try to sort things out. The funny thing about this is that, while it is not very important to know about aerodynamics to fly a glider, all sorts of misinformation eventually trickles into discussions and advice about such things as the best bank to turn in, or when a stall occurs etc. So what should we do about this? I agree with your statements. When do your instructions begin? I regularly abandon wrong assumption. Through this process I am learning. For example the lift equation CL * V^2 * area / density , how does it fit into the circulation equation? I assume it was a stripped down version that I have seen in an earlier post. I view the circulation as a 3D flow about the wing and glider structure. As this flow must effect every thing in one continues interaction, to express this in a formula and still have a visual understanding of the process must be nearly impossible. As a person interested in aerodynamics I find the incremental approach much more to my liking and I get results that are still within what I experience. Regards Udo |
#34
Do I have to go to the back of the class? I thought a propeller was a
screw. "J. N." wrote in message oups.com... You`re pushing air, water or whatever downwards. The result is a pressure and shear distribution on a plane which creates both lift and drag. In reality you can only apply bernoulli on a slow (200 kts), airfoil shaped device because of compressibility and possible detatchment of the boundary layer. When you start adding slats, fowler flaps or start flying fast or very slowly (model airplane`s) Bernoulli is far beside the thruth. A propellor or rotor is simply a rotating wing, and works exactly the same. It both sucks and pushes the air afterwards. The Blackbird would probally not fly at all if you use Bernoulli. That`s it... Jarno Nieuwenhuize, The Netherlands. |
#35
Schroedinger says yes! and no!
"Shawn" sdotherecurry@bresnannextdotnet wrote in message ... Don Johnstone wrote: I think you can also obtain books that prove the earth is flat and the Holocaust never happened. Oh and I forgot there are several that prove global warming :-) "Climate Change" C'mon don, get with the times. "Global Warming" is so 1997. ;-) BTW, was the Earth flat before Magellan sailed around it? Shawn |
#36
Ian Johnston a écrit :
What the unititaited don't realise is that forces can be transmitted by pressure or by momentum flux. At the surface of a wing, all the force comes from pressure. A long way away from the wing, all the force comes from momemntum transfer (there is effectively no pressure difference). As you go from one to the other the balance changes. Most people who "prove" theories of lift wrong simply forget to take account of momentum flux. Please explain us how momentum flux can be transmitted in a gas without pressure change. I think you will get at least a Nobel Price for such a revolutionary theory ;-) |
#37
On Fri, 13 Jan 2006 16:11:29 UTC, Denis
wrote: : Ian Johnston a écrit : : : What the unititaited don't realise is that forces can be transmitted : by pressure or by momentum flux. : Please explain us how momentum flux can be transmitted in a gas without pressure change. I think you will get at least a Nobel Price for such a revolutionary theory ;-) Eh? Any fluid crossing the boundary of a control volume takes momentum with it. That's a momentum flux. Elementary fluid mechanics. Ian |
#38
On Fri, 13 Jan 2006 17:14:46 UTC, T o d d P a t t i s t
wrote: : The point is that the sum (pressure plus MF) is always the : same, equal to the lift on the airfoil. The point of the : original post was that you have to account for *both* : pressure and momentum flux to figure out the force. Thanks - that was exactly my point. Peraps I was not terribly clear. Ian |
