#31
![]() Peter wrote: .... I use the Aerox system. My only complaint about it is that the ball flowmeter obviously has to be somehow oriented vertically, and that means velcro-ing it to something (which is tacky and the plastic pipes just rip the velcro off) or hanging it off the cockpit ceiling (which is great but the pipe coming off the top of the flowmeter gets a kink in it which appears as if it might shut off the flow. They should have a flowmeter on which both input and output pipes attach at the bottom, and which has a hook or an eyelet of some sort at the top. But the DIY solution is simple enough... The ball in the flowmeter is only used to indicate the flow rate. The rate itself is controlled by the needle valve. This means you only need to hold the flowmeter vertically while you adjust the valve. After that it's fine to let it dangle in any orientation. You just need to hold it back up vertically to check occasionally that the flow rate hasn't changed. Rod |
The National Lake Eutrophication Survey 1971-1973 | Badwater Bill | Home Built | 18 | June 16th 04 02:27 AM |
Which sport/acro biplane from plans? | Mr.Twistair | Home Built | 15 | October 6th 03 04:53 AM |
