#31
![]() David Megginson wrote: Greg Esres writes: To comment that "if they fly the approach as published, they won't hit anything" is a very shallow analysis. Not every CFIT deviated intentionally from the published approach. The other question is what "as published" means for an NPA -- do you make a vertical descent at every stepdown fix? The whole point of an NPA is that there is no vertical profile published, only a series of minimum altitudes. Very well stated. |
#32
I was not advocating "dive and drive", whatever that means. The point I was
trying to make was that why stay above the published heights intentionally. My comment about "get down as fast as possible" is perhaps overzealous and was not meant to advocate go down really fast, but rather I meant get down to the published altitude, and not stay above it purposely. The protection is the same. If pilots can't stop a descent whether going 1000' per minute of 300' per minute is the real issue. Something else is wrong if the "safer" rate of descent is going to save you. Correcting the real problem is the solution, not making up rules for hiding the problem or adding a safety net. Busting the stepdown fixes is the problem - not the descent rate. I will concede that the net effect of slower descent rates would be less accidents, however I am more concerned that pilots use that as a crutch rather than ensuring they execute approaches appropriately (not descending below minimums). wrote in message ... Tim J wrote: So what are you saying? The approach chart is/was wrong or the pilots made an error? The pilots made an error under lots of pressure and adverse weather conditions. The list of fatal accident reports where stepdown fixes are busted in G/A during IMC is a very long list indeed. The protection offerred by dive-and-drive is substantially less than with a constant angle or even a constant rate descent. I guess this word hasn't gotten very far in the light aircraft world. |
#33
Again, I am not advocating "dive and drive" - my point was that staying
above the published altitudes was questionable. wrote in message ... Tim J wrote: I was just trying to point out the obstacle clearances that the approach charts provide. I would like to see an accident report that found that the approach chart was incorrect and caused a crash. Does anyone have an example? I think rather it is the (improper) execution of the approach that is the cause of the supposed huge set of examples of crashes. If you all find it easier to make up your own descent profiles, go right ahead. I will not try to convince you otherwise. I will continue to fly them as published. What makes you think "as published" means dive and drive any more than it means constant angle or constant rate? |
#34
It really does not matter if the CFIT deviated intentionally or not. Most
likely if CFIT implies that they descended below the minimum published altitudes for that segment. Perhaps I am wrong (as so many of you are pointing out) but if I make a descent rate to arrive at a step down higher than published, it seems as though my descent rate has a good chance to not get me to the MDA when the time is up (or distance) and I have to go missed. So eventually I would have to do the dreaded "dive and drive" later anyway. wrote in message ... David Megginson wrote: Greg Esres writes: To comment that "if they fly the approach as published, they won't hit anything" is a very shallow analysis. Not every CFIT deviated intentionally from the published approach. The other question is what "as published" means for an NPA -- do you make a vertical descent at every stepdown fix? The whole point of an NPA is that there is no vertical profile published, only a series of minimum altitudes. Very well stated. |
#35
Do restrict your altitude to the MEAs enroute too? The stepdowns depict the
minimum altitudes for each segment of the approach. There is nothing regulatory about flying at those minimums. What you are advocating is what others have called 'dive and drive', ie decending quickly at each crossing then leveling at the mda for that segment until hitting the next stepdown fix. This certainly does increase the workload (you have less time to react to the altitude if it is decreasing at 1000 fpm instead of 3-500 fpm), as well as the consequences for being a little bit behind the airplane. It also gives you fewer options (altitude) should the engine start coughing. Just from the ergonomics standpoint, it is more stressful to you and your passengers, not to mention to the engine (shock cooling) and airframe. Most of the time, you've got plenty of room between the fixes to do a gentle descent and still get you at the final MDA in plenty of time to find the airport. -- --Ray Andraka, P.E. President, the Andraka Consulting Group, Inc. 401/884-7930 Fax 401/884-7950 http://www.andraka.com "They that give up essential liberty to obtain a little temporary safety deserve neither liberty nor safety." -Benjamin Franklin, 1759 |
#36
It's probably about time for someone to bring up the Aspen approach =
again. Be a little high and/or fast there, and you won't get down in time to = land. ---JRC--- "Ray Andraka" wrote in message = ... Do restrict your altitude to the MEAs enroute too? The stepdowns = depict the minimum altitudes for each segment of the approach. There is nothing = regulatory about flying at those minimums. What you are advocating is what = others have called 'dive and drive', ie decending quickly at each crossing then = leveling at the mda for that segment until hitting the next stepdown fix. This = certainly does increase the workload (you have less time to react to the = altitude if it is decreasing at 1000 fpm instead of 3-500 fpm), as well as the = consequences for being a little bit behind the airplane. It also gives you fewer = options (altitude) should the engine start coughing. Just from the ergonomics standpoint, it is more stressful to you and your passengers, not to = mention to the engine (shock cooling) and airframe. Most of the time, you've got = plenty of room between the fixes to do a gentle descent and still get you at the = final MDA in plenty of time to find the airport. -- --Ray Andraka, P.E. |
#37
"Tim J" wrote in
. net: Again, I am not advocating "dive and drive" - my point was that staying above the published altitudes was questionable. I'm beginning to think your judgment is questionable. The stepdown fixes give only minimum altitudes, no maximum. That means you can't go below, but can safely and legally be above, the altitude. There is no requirement at all to be at a stepdown altitude immediately, unless there is a line *above* the altitude. -- Regards, Stan |
#38
"John R. Copeland" wrote in
: It's probably about time for someone to bring up the Aspen approach again. Be a little high and/or fast there, and you won't get down in time to land. ---JRC--- I haven't flown that approach, but I've studied the approach plate. The stepdown fixes aren't that much - you don't have to hurry, because there isn't that much altitude change. The big change is the final descent, after the stepdown fixes, and if you get too low or a little off course, you'll land much more quickly than you intended. -- Regards, Stan |
#39
![]() "Stan Gosnell" me@work wrote in message = ... "John R. Copeland" wrote in :=20 =20 It's probably about time for someone to bring up the Aspen approach again. Be a little high and/or fast there, and you won't get down in time to land. ---JRC--- =20 I haven't flown that approach, but I've studied the approach=20 plate. The stepdown fixes aren't that much - you don't have to=20 hurry, because there isn't that much altitude change. The big=20 change is the final descent, after the stepdown fixes, and if=20 you get too low or a little off course, you'll land much more=20 quickly than you intended. =20 --=20 Regards, =20 Stan Roger that, too, Stan! My wife dislikes that valley. BTW, Aspen approach is pretty understanding if you tell them you need to make a 360 to lose some altitude after you get the field in = sight. (Of course, we're talking fixed-wing performance here.) ---JRC--- |
#40
![]() "Tim J" wrote in message . net... I was not advocating "dive and drive", whatever that means. The point I was trying to make was that why stay above the published heights intentionally. My comment about "get down as fast as possible" is perhaps overzealous and was not meant to advocate go down really fast, but rather I meant get down to the published altitude, and not stay above it purposely. The protection is the same. If pilots can't stop a descent whether going 1000' per minute of 300' per minute is the real issue. Something else is wrong if the "safer" rate of descent is going to save you. Correcting the real problem is the solution, not making up rules for hiding the problem or adding a safety net. Busting the stepdown fixes is the problem - not the descent rate. I will concede that the net effect of slower descent rates would be less accidents, however I am more concerned that pilots use that as a crutch rather than ensuring they execute approaches appropriately (not descending below minimums). Whoa! I had to get in here on this one... A crutch? Using something that will result in less accidents is a crutch? I think NOT! A stabilized approach will always be safer than step-downs. Just my 2cents. I'll sit back down now. Harvey |
High Price of Flying Wires? | PWK | Home Built | 34 | October 8th 17 08:24 PM |
Fwd: [BD4] Source of HIGH CHTs on O-320 and O-360 FOUND! | Bruce A. Frank | Home Built | 1 | July 4th 04 07:28 PM |
high impedance, low impedance? | JFLEISC | Home Built | 5 | April 11th 04 06:53 AM |
MT. DIABLO HIGH SCHOOL CONCORD, CA PHOTOS | MT. DIABLO HIGH SCHOOL PHOTOS | Home Built | 1 | October 13th 03 03:35 AM |
High performance homebuilt in the UK | NigelPocock | Home Built | 0 | August 18th 03 08:35 PM |
