#31
On 02/10/06 09:47, three-eight-hotel wrote:
I think I'm clear now, but wanted to clarify a point from the last post - Pilot not flying is acting PIC (required because the pilot flying is not IMC current) and so logs PIC Was meant to be posted as a question to the Chief Counsel and not as a statement of understanding, right? Yes, this is the question I'm trying to get clear on myself. Acting PIC (not flying) may NOT log PIC, based on what I'm hearing and reading in other searches... From the following link (http://www.propilot.com/doc/logging2.html) I snipped a section regarding this specific situation... ========= Begin Snip ========== A non-instrument-rated private pilot (but rated in the aircraft category and class) flies with another private pilot who is instrument rated, on an IFR flight plan in IMC conditions. The non-IFR pilot manipulates the flight controls for the entire flight. The IFR pilot acts as PIC, and is required to be the PIC since he/she is the only pilot appropriately rated to act as PIC under IFR, but logs no flight time. Why? The instrument-rated pilot did not manipulate the flight controls and is not acting as PIC of an aircraft requiring more than one pilot. The non-IFR pilot may log PIC time for the entire flight since he/she was the sole manipulator of the flight controlsof an aircraft for whih he/she is rated. See legal opinion # 5 for details. This legal opinion is written to answer a question involving a CFII as the PIC, but the opinion later states "The other pilot must be the PIC, ...", and does not impose a requirement to hold an instructor certificate. Also, see legal opinion # 6 , under "TAB AERO Question # 2" which further clarifies the fact that a non-rated pilot can manipulate the controls under IFR. How do you find opinion #5 and #6? When I go to the FAA web site, I can search by keyword, and the results don't provide the opinion number. Thanks for digging this up, Todd. I've saved it off, and will read the complete article when I get a few minutes. This represents no change from the old rules. ========= End Snip ========== Best Regards, Todd -- Mark Hansen, PP-ASEL, Instrument Airplane Cal Aggie Flying Farmers Sacramento, CA |
#32
"Mark Hansen" wrote in message
... Nope, 61.51e1 clearly states the contrary (even though it's partially contradicted by the FAA's "interpretations"). 61.51(e)(iii) (what I think you meant above) Close--61.51e1iii is one of the three clauses of 61.51e1. ![]() states: "Except for a recreational pilot, is acting as pilot in command of an aircraft on which more than one pilot is required under the type certification of the aircraft or the regulations under which the flight is conducted." It would be possible for someone to interpret "... the regulations under which the flight is conducted" to indicate that because the pilot flying cannot legally fly in IMC, due to currency, that the pilot not flying is required. That's correct. The PIC (the pilot not flying) is indeed required. It's the other pilot (the sole manipulator) who's not required in that scenario. Now, you might reasonably ask why the hooded pilot flying with a safety pilot is considered a required pilot. And the FAA's answer is apparently that the specific regulations that pertain to flying with a safety pilot do mention two distinct pilots, so you need two pilots to conduct a flight *under those regulations* (otherwise, you'd be flying under different regulations instead). Whatever the merits of that interpretation may be, it doesn't carry over to the IMC/IFR scenario, since there is no particular regulation that speaks of two distinct pilots in that scenario. --Gary |
#33
I can search by keyword, and the results don't provide the opinion number. You can search for IMC, and it takes you right to the topic we are discussing... Here are the links, to save you time. (I haven't read them yet) http://www.propilot.com/doc/legal5.html http://www.propilot.com/doc/legal6.html Best Regards, Todd |
#34
On 02/10/06 10:09, Gary Drescher wrote:
"Mark Hansen" wrote in message ... Nope, 61.51e1 clearly states the contrary (even though it's partially contradicted by the FAA's "interpretations"). 61.51(e)(iii) (what I think you meant above) Close--61.51e1iii is one of the three clauses of 61.51e1. ![]() I'm reading from a form of the online regs that shows this as 61.51 (e) (iii) ... not 61.51 (e) (1) (iii). states: "Except for a recreational pilot, is acting as pilot in command of an aircraft on which more than one pilot is required under the type certification of the aircraft or the regulations under which the flight is conducted." It would be possible for someone to interpret "... the regulations under which the flight is conducted" to indicate that because the pilot flying cannot legally fly in IMC, due to currency, that the pilot not flying is required. That's correct. The PIC (the pilot not flying) is indeed required. It's the other pilot (the sole manipulator) who's not required in that scenario. Right, so the pilot not flying is required, so he can log PIC. The pilot flying is sole manipulator, so he can log PIC. See where I'm coming from? Now, you might reasonably ask why the hooded pilot flying with a safety pilot is considered a required pilot. And the FAA's answer is apparently that the specific regulations that pertain to flying with a safety pilot do mention two distinct pilots, so you need two pilots to conduct a flight *under those regulations* (otherwise, you'd be flying under different regulations instead). Whatever the merits of that interpretation may be, it doesn't carry over to the IMC/IFR scenario, since there is no particular regulation that speaks of two distinct pilots in that scenario. Except for the one I stated above... ;-) Given that you're flying in IMC conditions, the pilot in command is required to be IMC current. Because the pilot-flying is not, the IMC-current pilot-not-flying is required, and must act as pilot in command (and, I think, should be allowed to log PIC). However, the non-IMC-current pilot-flying is sole manipulator of the controls, and thus is entitled to log PIC according to 61.51 (e) (i). The stuff posted by Todd seems to indicate that the Chief Counsel did offer an opinion on this specific case, and states that the pilot-not-flying would not be entitled to log PIC even when acting as Pilot in Command if the pilot-flying is logging PIC as a result of 61.51 (e) (i). That just doesn't seem fair to me, and I would sure like to see those Chief Counsel opinions (#5 and #6). I hope I'm not coming across as argumentative. I'm really enjoying the discussion ;-) --Gary -- Mark Hansen, PP-ASEL, Instrument Airplane Cal Aggie Flying Farmers Sacramento, CA |
#35
... On 02/10/06 10:09, Gary Drescher wrote: Close--61.51e1iii is one of the three clauses of 61.51e1. ![]() I'm reading from a form of the online regs that shows this as 61.51 (e) (iii) ... not 61.51 (e) (1) (iii). No, if you look closely, you'll see there's a '1' between the 'e' and the 'iii', although it's obscured by the confusing formatting. (But there's always an Arabic numeral between the letter and the Roman numeral.) http://ecfr.gpoaccess.gov/cgi/t/text...4/14tab_02.tpl That's correct. The PIC (the pilot not flying) is indeed required. It's the other pilot (the sole manipulator) who's not required in that scenario. Right, so the pilot not flying is required, so he can log PIC. No. Being a required pilot is not one of the three specific conditions that allow you to log PIC time. Given that you're flying in IMC conditions, the pilot in command is required to be IMC current. Because the pilot-flying is not, the IMC-current pilot-not-flying is required, and must act as pilot in command So far, so good. (and, I think, should be allowed to log PIC). No, that's the part that's wrong. Neither being a required pilot nor being PIC allows you to log PIC time (unless multiple crew members are required). According to 61.51e1, the three specified conditions are the *only* conditions that allow you to log PIC time. What the FAA calls "logging PIC time" is simply a misnomer, since it has little to do with the concept of PIC. The terminology is needlessly confusing. The FAA should just call it something else, such as "logging primary-pilot time". I hope I'm not coming across as argumentative. I'm really enjoying the discussion ;-) Not argumentative at all--at least, not in a bad way. ![]() discussions are always fun. --Gary |
#36
"three-eight-hotel" wrote in message
oups.com... How do you find opinion #5 and #6? When I go to the FAA web site, I can search by keyword, and the results don't provide the opinion number. You can search for IMC, and it takes you right to the topic we are discussing... Here are the links, to save you time. (I haven't read them yet) http://www.propilot.com/doc/legal5.html http://www.propilot.com/doc/legal6.html I think what Mark was seeking is an official source of those opinions on the FAA's own web site; otherwise, it's just Internet chain mail. But unfortunately, the FAA doesn't publish the opinions, as far as I know. --Gary |
#37
On 02/10/06 10:59, Gary Drescher wrote:
"Mark Hansen" wrote in message ... On 02/10/06 10:09, Gary Drescher wrote: Close--61.51e1iii is one of the three clauses of 61.51e1. ![]() I'm reading from a form of the online regs that shows this as 61.51 (e) (iii) ... not 61.51 (e) (1) (iii). No, if you look closely, you'll see there's a '1' between the 'e' and the 'iii', although it's obscured by the confusing formatting. (But there's always an Arabic numeral between the letter and the Roman numeral.) http://ecfr.gpoaccess.gov/cgi/t/text...4/14tab_02.tpl Oh, I see. Here's how it looks in the view I'm looking at: (e) Logging pilot-in-command flight time. (1) A sport, recreational, private... The (1) is on the same line as the (e) ;-\ That's correct. The PIC (the pilot not flying) is indeed required. It's the other pilot (the sole manipulator) who's not required in that scenario. Right, so the pilot not flying is required, so he can log PIC. No. Being a required pilot is not one of the three specific conditions that allow you to log PIC time. I'm interpreting it differently (and, I guess, incorrectly)... Given that you're flying in IMC conditions, the pilot in command is required to be IMC current. Because the pilot-flying is not, the IMC-current pilot-not-flying is required, and must act as pilot in command So far, so good. (and, I think, should be allowed to log PIC). No, that's the part that's wrong. Neither being a required pilot nor being PIC allows you to log PIC time (unless multiple crew members are required). According to 61.51e1, the three specified conditions are the *only* conditions that allow you to log PIC time. And I think you're saying that 61.51(e)(1)(iii) is referring to aircraft which require multiple crew members, and not the case we're discussing here. The way I (incorrectly) interpreted it, it could apply to our case as well - but I hear you saying that it does not ... and I believe you, even if I don't agree with it ;-) By the way, if the pilot-not-flying was an active CFI, they *would* be able to log PIC in this case, due to 61.51(e)(3), right? Even if the pilot-flying was logging PIC due to 61.51(e)(1)(i). What the FAA calls "logging PIC time" is simply a misnomer, since it has little to do with the concept of PIC. The terminology is needlessly confusing. The FAA should just call it something else, such as "logging primary-pilot time". I realize the difference between acting and logging PIC - in fact, it is that different that I *thought* made it possible for both pilots in this situation to log PIC. I hope I'm not coming across as argumentative. I'm really enjoying the discussion ;-) Not argumentative at all--at least, not in a bad way. ![]() discussions are always fun. Thanks. I definitely learned something new today! --Gary -- Mark Hansen, PP-ASEL, Instrument Airplane Cal Aggie Flying Farmers Sacramento, CA |
#38
On 02/10/06 10:27, three-eight-hotel wrote:
How do you find opinion #5 and #6? When I go to the FAA web site, I can search by keyword, and the results don't provide the opinion number. You can search for IMC, and it takes you right to the topic we are discussing... Here are the links, to save you time. (I haven't read them yet) http://www.propilot.com/doc/legal5.html http://www.propilot.com/doc/legal6.html Great, Thanks. In fact, in looking at these, they don't seem to specifically say that the pilot acting as pilot in command cannot log the flight time as PIC during the time that the pilot flying is sole manipulator of the controls. They clearly say that the instrument-rated pilot is required to act as pilot in command. Here is an excerpt: An instrument student who holds at least a private pilot certificate and who is rated for the aircraft flown may log as pilot in command flight time under Section 61.51 (c)(2)(i), the time spent as sole manipulator of the controls regardless of the meteorological conditions of the flight. In situations where actual IFR meteorological conditions exist, as in the case presented in the above example, the safety pilot or flight instructor, as the case may be, must be pilot in command, as that term is defined under 1.1 of the FAR. However, I think the issue that's been confusing me, is that I was under the impression that if you acted as pilot in command, that gave you the right to log PIC. ... but I guess not. Best Regards, Todd -- Mark Hansen, PP-ASEL, Instrument Airplane Cal Aggie Flying Farmers Sacramento, CA |
#39
... And I think you're saying that 61.51(e)(1)(iii) is referring to aircraft which require multiple crew members, Yes, at least for a particular flight. FAR 61.51e1iii refers explicitly to "an aircraft on which *more than one pilot is required* under the type certification of the aircraft or the regulations under which the flight is conducted". The regulations that pertain to the IMC/IFR scenario do not require the plane to have "more than one pilot" for that flight. --Gary |
#40
... By the way, if the pilot-not-flying was an active CFI, they *would* be able to log PIC in this case, due to 61.51(e)(3), right? Even if the pilot-flying was logging PIC due to 61.51(e)(1)(i). Yup, the rules are different for a CFI giving instruction. --Gary |
OK, I'm off... | Simon Robbins | Rotorcraft | 15 | March 14th 05 12:44 AM |
Does FAA respond to FAQ questions? | Robert M. Gary | Piloting | 0 | July 6th 04 10:22 PM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 1 | January 2nd 04 09:02 PM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | October 2nd 03 03:07 AM |
Accelerated spin questions | John Harper | Aerobatics | 7 | August 15th 03 07:08 PM |
