Oh those CERTIFIED plane engines !!!!!!!!!!!!!!!!!
Old March 6th 06, 01:52 AM posted to rec.aviation.homebuilt
Default Oh those CERTIFIED plane engines !!!!!!!!!!!!!!!!!
If I may be forgiven (or not) for reading about the Corvair crank
failures with rectal vision, they should not have surprised anyone.
If you would read the site again, I think you will find that the breaking
problem is limited to higher speed airplanes, not stuff like aircampers,
right?
It is highly unlikely that any auto manufacturer is going to put
a crankshaft that is a whole lot stronger than needed into a
standard engine, don't you think?
Some manufacturers, at certain times in their lifespan, are less
comfortable
with cutting design strength margins too closely. GM is more likely to
build hell for stout, than are many of the imports, IMHO.
And even more than the "aircraft" manufacturers, where weight IS the
enemy, and where change for improvement's sake is very much frowned
upon. If you change or improve something, you are admitting something
was less than perfect, and leaving yourself vulnerable to that
"unwashed horde" known as the "legal proffesion".
I also love to pick. However, let's also remember that improvements and
vendor changes also have a way of restarting the entire field experience
process--as has been discussed earlier in this thread, and also in AvFlash,
with regard to Lycoming...
  #32
Old March 6th 06, 02:32 AM posted to rec.aviation.homebuilt
Morgans wrote:
Some manufacturers, at certain times in their lifespan, are less comfortable
There's a little difference. When the engine breaks in your car, you
can pull off the road and call a tow truck.
  #33
Old March 6th 06, 03:10 AM posted to rec.aviation.homebuilt
"Orval Fairbairn" wrote
I have also seen a few successes, too. One was the late George Morse's
Olds V-6 in his Skybolt and later in the Prowler. He found that you need
an AN water pump instead of the automotive one and that you also need a
coolant pressure indicator, in addition to temperature.
What do you mean by an AN water pump?
One of the common things people say about auto conversions, is that they are
not designed to run at the high power outputs that are needed for aircraft.
It seems, however, that most of the problems are in the stuff that is bolted
to the engine. PSRU's fail, water pumps go out, belts fly around, fuel
delivery is not up to the job, cooling is not good enough, whatever. The
engines are rarely the problem, though.
Good design and doing what other successful converters have done, looks to
be the key.
  #34
Old March 6th 06, 03:17 AM posted to rec.aviation.homebuilt
"Cal Vanize" wrote in message
comfortable
True ... but ...
Engines in cars rarely break. Possibly as rarely as _real_ airplane
engines. However, I have seen a broker crank in a 40 HP Volkswagen, which
my brother and I bought. We rebuilt another engine and installed it with no
further problems. I also used to know a truck mechanic who saw the
occasional broken crank; usually, or perhaps always, after seeing a failed
torsional harmonic dampened--and trying without success to convince the
owner to replace it.
I leave it to the reader to make the connection; as I have beaten that dead
horse far too much, and not only on this NG.
  #35
Old March 6th 06, 04:30 AM posted to rec.aviation.homebuilt
"Morgans" wrote in message
Humm, I don't know a single person that has had a broken crank, in his
car.
Can you say the same about your friend's airplanes?
When an auto engined airplane powerplant fails, it is almost always not
engine, but what has been bolted to it. It seems like airplane engines
are
always blowing jugs off, sticking valves, and breaking rods and cranks.
They are not confidence inspiring, to me.
True, auto engines in airplanes have a way to go, but if someone were to
put
the effort into making a standard package, and perfecting it, they would
really go far. Some are getting really close.
You've summed it up quite well, Jim.
Peter in FL
  #36
Old March 6th 06, 05:01 AM posted to rec.aviation.homebuilt
Humm, I don't know a single person that has had a broken crank, in his car.
When an auto engined airplane powerplant fails, it is almost always not the
engine, but what has been bolted to it. It seems like airplane engines are
True, auto engines in airplanes have a way to go, but if someone were to put
  #37
Old March 6th 06, 05:15 AM posted to rec.aviation.homebuilt
IIRC, George meant to use a water pump such as used on Merlins or
Allisons. he found the automotive pumps to be lacking.
True! If you isolate the engine from unintended stresses, it will work a
lot better, but those same stresses manifest themselves in other places,
unless you are really sharp anticipating them.
be the key.
True -- that is *ALWAYS* the case! Add in "good practices" also.
  #38
Old March 6th 06, 05:19 AM posted to rec.aviation.homebuilt
I had a broken crank in a 356C Porsche (rebuilt engine/chromed crank). I
think the real problem was that the shop that chromed the crank didn't
bake it properly to eliminate hydrogen embrittlement.
I had an E-225 swallow a valve in a Bonanza once -- shook like hell at
anything over 1500 RPM!
  #39
Old March 6th 06, 07:23 AM posted to rec.aviation.homebuilt
I was unaware that a water pump for a Merlin or an Allison would fit on an
American V-8! g
Really, though, I don't understand what he would be referring to. Is it
something like what is commonly used on racing (NASCAR) engines? What
companies make something compatible, in that design?
I had always thought that special design was needed to get the accessories
running at a slower than stock RPM, either by using a smaller than normal
drive pulley, or larger than normal accessory pulley. I would think that
better bearings would be good things for a water pump.
  #40
Old March 6th 06, 02:05 PM posted to rec.aviation.homebuilt
Many people ARE working on it, of course.
A friend in Hondo has been for several years.
He runs the local crop dusting service and flies Snows, AgTrucks, and a couple
of small Cessnas. There are a few Garret powered planes as well - sweet, but
pricey to purchase, and operate.
One season, he replaced 13 cylinders on ONE of his 1835s.
THAT'S a chunk of change, folks!
His idea is to use a large block V8 to power his fleet, and has had one up
and flying. That one used a belt driven PSRU, and actually flew a few hours
before it was lost in a hangar fire. Reliability was never fully explored,
but there were some doubts as to how long it would have lasted in service.
The next step was to have a gearbox designed - by a well known name in this
field. Several years, a lot of drawings, and planning - and money? before
this one was dropped.
The current plan is for a chain drive. Another well known name in the field,
but this guy says he can have it up and running in 60 days.
The FAA agrees that the duster fleet needs modernized power and is very
interested in the results. No dusters - no food - and an epidemic of RATS!
My own feeling is that the crop dusting fleet NEEDS this kind of power and
reduced operating costs! And the aircraft size makes it quite adaptable to
such engines. As opposed to very small, very light, very experimental
airframes.
Given enough time and money....
Richard
It sure makes a difference to own your own plane!! Marco Rispoli Piloting 9 June 29th 04 11:15 PM
Rental policy Robert Piloting 83 May 13th 04 05:29 PM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 0 April 5th 04 03:04 PM
Accident Statistics: Certified vs. Non-Certified Engines Ron Wanttaja Home Built 23 January 18th 04 05:36 PM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 0 October 2nd 03 03:07 AM
