Would you fly this Aircraft?
Old March 19th 06, 05:29 AM posted to rec.aviation.piloting
Default Would you fly this Aircraft?
I'd be interested in "go/no-go" opinions of others, based solely on the
following information ...
"Naturally aspirated, carburated, light twin (C172 engines) - hasn't been
flown for 3 weeks - at the conclusion of last flight was fueled to the max.
Has since been observed to have fuel dripping from the right-hand engine
nacelle. Has been checkd by engineer who has put it down to "full tanks +
volume change due to temperature changes".
No other information available.
My initial thought was "why wouldn't the excess fuel get forced out through
the tank vents, rather than through "something" within the engine bay.
How many of you would / would not fly this aircraft based on the above info?
(I appreciate that more info would be nice, but it's all I have available).
Many thanks,
Cheers,
Old March 19th 06, 05:49 AM posted to rec.aviation.piloting
Based on that, I would NOT fly the aircraft UNTIL I had
personally inspected it to see what was leaking and from
where. If the float valve was leaking, the fuel level would
rise and over-flow from the vent on the carb. That is an
easy fix. If a fuel line is leaking, it is also an easy
fix. If a crack is in the float bowl, you replace the carb,
also easy but more expensive.
What is the history of the airplane before and on the last
flight? Was is parked with the fuel valves OFF or ON?
James H. Macklin
ATP,CFI,A&P
some support
"C J Southern" wrote in message
solely on the
fueled to the max.
right-hand engine
to "full tanks +
forced out through
engine bay.
on the above info?
have available).
| Many thanks,
| Cheers,
Old March 19th 06, 06:12 AM posted to rec.aviation.piloting
"Jim Macklin" wrote in message
newso6Tf.118036$QW2.75471@dukeread08...
Several years ago the aircraft showed the same symptoms - on that occasion
the leak was due to a fractured primer line.
Prior to the last flight there were no know issues.
Aircraft is always parked with fuel selectors ON, but following the leak the
right hand fuel selector has been turned off to stop any more leakage.
Personal investigation would be difficult - it would require removal of the
cowling (which presumably the engineer has done). If the cowling isn't
removed, then the only place you can see anything is via the oil filler
flap - which lets one see very very little.
Old March 19th 06, 07:23 AM posted to rec.aviation.piloting
Removal of the cowling is required and I would want to
either do it or be present. Fuel lines can leak due to
loose fittings, broken lines that crack from fatigue or
abrasion. I would want to visually inspect for any signs of
fuel stains and any damage.
The problem is not just possible engine failure, but fire
and explosion inside the wing or cowling.
Since mechanics {engineers} often won't fly in airplanes
they have performed maintenance upon, you, the PIC must be
able to inspect the airplane and satisfy yourself.
James H. Macklin
ATP,CFI,A&P
some support
| "Jim Macklin" wrote
in message
last
on that occasion
more leakage.
cowling isn't
the oil filler
Old March 19th 06, 02:41 PM posted to rec.aviation.piloting
"Jim Macklin" wrote in message newso6Tf.118036$QW2.75471@dukeread08...
James H. Macklin
ATP,CFI,A&P
Don't see how the carb float valve could be leaking; the mixture is at idle cutoff, right?
Old March 19th 06, 02:59 PM posted to rec.aviation.piloting
Idle cutoff stops flow of fuel to the venturi/throat, but
the float valve stops the flow of fuel into the carb float
bowl.
James H. Macklin
ATP,CFI,A&P
some support
".Blueskies." wrote in
message
would
an
carb,
last
| James H. Macklin
| ATP,CFI,A&P
Old March 19th 06, 04:16 PM posted to rec.aviation.piloting
"Jim Macklin" wrote in message news:eqeTf.118075$QW2.13026@dukeread08...
bowl.
James H. Macklin
ATP,CFI,A&P
OK, so the float bowl is always filled as far as the (good) float/needle allows it to be while the mixture control is
downstream of the float needle? Actually makes sense because the float is supposed to control the head pressure against
the carb jet, and putting a cutoff in front of the float would only cause the bowl level to lower with very slight
leaning due to the reduces head pressure. One of these days I'll get to mess around with one of these engines....
Thanks Jim...
Old March 19th 06, 04:28 PM posted to rec.aviation.piloting
I had a commercial pilots certificate for some time before I
attended A&P school [Spartan] and I learned that I didn't
know a lot of things about aircraft engines that I think a
pilot should know.
James H. Macklin
ATP,CFI,A&P
some support
message
t...
but
float
| bowl.
| James H. Macklin
| ATP,CFI,A&P
control is
against
| Thanks Jim...
Old March 19th 06, 04:43 PM posted to rec.aviation.piloting
.....If the float valve was leaking, the fuel level would
rise
Not likely to happen on a low-wing twin. Maybe a Cessna single.
Old March 19th 06, 05:28 PM posted to rec.aviation.piloting
Who said this was a low-wing twin?
"John Gaquin" wrote in message
| "Jim Macklin" wrote
in
would
| rise
single.
I want to build the most EVIL plane EVER !!! Eliot Coweye Home Built 237 February 13th 06 03:55 AM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 0 May 1st 04 07:29 PM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 0 April 5th 04 03:04 PM
