#31
"Jeff" wrote in message ... because if its going to be bad I like being on a route flown by other aircraft just in case something happens. Well, since we are talking about flying through congested areas, I think it likely there'll be other aircraft on your route. |
#32
there are places out here where you dont get radar coverage. You follow the airways, your good to go. Not all airways are covered by radar. Jose -- (for Email, make the obvious changes in my address) |
#33
"O. Sami Saydjari" wrote in message ...
So, would it be poor form to get an ifr clearance to get above whatever cloud layer at your departure airport....fly VFR when you are on top....then pickup an on-the-fly IFR again 100 miles or so before your destinatation airport if you needed to descend back down through a cloud layer? I am not saying this is a particularly good idea, or particularly "polite"...I am just asking a question here. Sami, As long as you file the IFR flight plans with flight service before requesting 'em, it's no problem at all nor is it impolite AFAIK -- it's your right to use the system as best suits you. Another alternative can be to request the IFR clearance "VFR on top" once you're above the clouds at your departure airport. This keeps you in the IFR system but, since ATC no longer has to separate you, they may be able to allow more direct routing. We used to fly from the midwest to Buffalo NY regularly. Direct routing is right through the Cleveland Class B and IFR would result in the wide-around to the south. We used both the above techniques. In general my pref. would be try VFR-on-top first, cancel if I can't get direct routing I want. One time after we canceled IFR I flew into an unforecast cloud layer. It wasn't a big deal but it would have been easier and more straightforward to just say "unable to maintain VFR-on-top, request IFR altitude" than to have to file and obtain a new IFR clearance. FWIW, Sydney |
#34
Well, I used the route planning software available at the duats website. I picked the low-level victor airway that it recommended....and thats the one that had the conflicts. Sami, While I use DUATS once my route is planned, the victor routing options of Flight Planner aren't always the best airway routing. They may send you to VORs or intersections which add miles to your trip or keep you on airways when a direct VOR segment or two would shorten it. To get great circle routing which is easy to put on a chart out of DUATS, select the "direct routing for GPS/Loran". I recommend purchasing a "low altitude enroute planning chart" (or something like that) from your favorite chart shop. You can sanity check any routing and easily see where picking a fuel stop a bit off to the west would add little but steer you clear, or where going direct between VORs would make a shorter route. It's also a great aid for any replanning which might be necessary enroute due to weather. In truth, for longer trips, we file VOR routing (not necessarily airways) more and more often, because with judicious use of direct segments it usually adds very little (maybe 1%) to the trip and makes filing flight plans easier. Cheers, Sydney |
#35
Jeff wrote: I live in the desert, If you go down there is not alot of places to land I fly frequently to (for example) Laughlin, Lancaster WJF, and Palm Springs. Also been to Tucson on occasion. Where out there in the desert is NOT a place to land? It looks just like the pictures I've been seeing from Mars. Jeff, you ought to get in on the 2004 Hayward Air Race. The 2004 entry packet just came out. http://www.hwdairrace.org/ |
#36
To get great circle routing which is easy to put on a chart out of DUATS, select the "direct routing for GPS/Loran". Must have missed this option. Thanks. I recommend purchasing a "low altitude enroute planning chart" (or something like that) from your favorite chart shop. Great idea. In truth, for longer trips, we file VOR routing (not necessarily airways) more and more often, because with judicious use of direct segments it usually adds very little (maybe 1%) to the trip and makes filing flight plans easier. It makes filing flight plans easier than what? vivtor airway routes? Seems a direct file is the easiest. I assume I can just file my route as "KISW direct KHEF" (Wisconsin Rapids, WI to Manassas, VA). |
#37
do you think so
"Steven P. McNicoll" wrote: "Jeff" wrote in message ... because if its going to be bad I like being on a route flown by other aircraft just in case something happens. Well, since we are talking about flying through congested areas, I think it likely there'll be other aircraft on your route. |
#38
there is very few areas around there to land.
If its not a road or a dry lake bed, chances are its not going to be place to land. The desert here is nowhere near flat or smooth. Craig Prouse wrote: In article , Jeff wrote: I live in the desert, If you go down there is not alot of places to land I fly frequently to (for example) Laughlin, Lancaster WJF, and Palm Springs. Also been to Tucson on occasion. Where out there in the desert is NOT a place to land? It looks just like the pictures I've been seeing from Mars. Jeff, you ought to get in on the 2004 Hayward Air Race. The 2004 entry packet just came out. http://www.hwdairrace.org/ |
#39
that race looks like it would be kinda fun, anyone here ever enter these?
Craig Prouse wrote: In article , Jeff wrote: Jeff, you ought to get in on the 2004 Hayward Air Race. The 2004 entry packet just came out. http://www.hwdairrace.org/ |
#40
correct but you can also get into all the other little tidbits - but in
general Teacherjh wrote: there are places out here where you dont get radar coverage. You follow the airways, your good to go. Not all airways are covered by radar. Jose -- (for Email, make the obvious changes in my address) |
| Thread Tools | |
| Display Modes | |
| Marske Flying Wing discussion Group | mat Redsell | Home Built | 0 | September 19th 04 02:58 PM |
| Ultralight Club Bylaws - Warning Long Post | MrHabilis | Home Built | 0 | June 11th 04 06:07 PM |
| Flying Wing Design workshop in july 04 | mat Redsell | Home Built | 1 | May 5th 04 02:53 PM |
| Flying Magazine's Instrument Flying 1973 | Steven P. McNicoll | Instrument Flight Rules | 16 | January 12th 04 04:50 PM |
| seeking info from NW Ontario/ Upper Midwest Pilots flying intoAtikokan | David Megginson | Instrument Flight Rules | 0 | July 9th 03 04:04 PM |
