#31
but do you have an
official definition of "rating limitation" to use to properly understand 61.31(k)(2)(ii)? No, but the definition of rating is implicit in its use in that same section. 61.31.... (a) type rating required... (c) aircraft category, class, and type ratings... (d) aircraft category, class, and type ratings... and then (e), (f), and (g) specify "training", not "rating". Jose -- The price of freedom is... well... freedom. for Email, make the obvious change in the address. |
#32
Jose wrote
but do you have an official definition of "rating limitation" to use to properly understand 61.31(k)(2)(ii)? No, but the definition of rating is implicit in its use in that same section. 61.31.... (a) type rating required... (c) aircraft category, class, and type ratings... (d) aircraft category, class, and type ratings... and then (e), (f), and (g) specify "training", not "rating". Anything pertaining to "rating" is a certificate action accomplished by either an FAA Inspector or a Designated Examiner. Anything pertaining to "training" may be accomplished and endorsed by an Authorized Instructor. Bob Moore Authorized Instructor |
#33
"Bob Moore" wrote in message
. 121... Anything pertaining to "rating" is a certificate action accomplished by either an FAA Inspector or a Designated Examiner. Anything pertaining to "training" may be accomplished and endorsed by an Authorized Instructor. Agreed. But is required training (and in particular, training required by 61.31(i)) a "rating limitation"? |
#34
I think the endorsement has to reference 61.31 as well as
the other parts of 61. -- James H. Macklin ATP,CFI,A&P -- The people think the Constitution protects their rights; But government sees it as an obstacle to be overcome. some support http://www.usdoj.gov/olc/secondamendment2.htm See http://www.fija.org/ more about your rights and duties. "Jose" wrote in message ... | Still the student pilot must have a solo endorsement for | each make and model on the student pilot certificate and a | 90 day solo endorsement in the logbook to be qualified to | take the practical test. | | Ok, would this suffice as a (permanent) tailwheel endorsement? | | Jose | -- | The price of freedom is... well... freedom. | for Email, make the obvious change in the address. |
#35
Peter Duniho wrote
Agreed. But is required training (and in particular, training required by 61.31(i)) a "rating limitation"? No...Fist because it can be endorsed by an Authorized Instructor and second probably because it comes under the second part of the title of 61.31 which contains three distinct items: "Section 61.31: Type rating requirements, additional training, and authorization requirements". Since the tailwheel requirement is specifically labeled: "(i) Additional training required for operating tailwheel airplanes." This would seem to exclude it from the "Type Rating Requirements". Bob Moore |
#36
. 121... Agreed. But is required training (and in particular, training required by 61.31(i)) a "rating limitation"? No...Fist because it can be endorsed by an Authorized Instructor and second probably because it comes under the second part of the title of 61.31 which contains three distinct items: "Section 61.31: Type rating requirements, additional training, and authorization requirements". Well, if it's not a "rating limitation", then 61.31(k) doesn't apply. Got a different exception? So far, as near as I can tell, a student pilot DOES need the tailwheel endorsement for solo flight. Pete |
#37
Sounds to me that that clinches it. So a student pilot would need the endorsement before solo, and would therefore already have the endorsement by the time he took the checkride, and it would still be valid (since there is nothing to invalidate it). Jose -- The price of freedom is... well... freedom. for Email, make the obvious change in the address. |
#38
On Fri, 21 Apr 2006 21:39:28 GMT, Jose
wrote: If a student pilot takes all his training in a tailwheel aircraft (including solo), but takes his flight test in a nosedragger, does the newly minted private pilot need a separate tailwheel endorsement? He will get the endorsement as a matter of course. I thought it would have been given prior to solo, but I see that mine is dated *after* my flight test! Evidently the instructor overlooked it. So perhaps you should nudge the CFI. -- all the best, Dan Ford email: usenet AT danford DOT net Warbird's Forum: www.warbirdforum.com Piper Cub Forum: www.pipercubforum.com In Search of Lost Time: www.readingproust.com |
#39
On Sat, 22 Apr 2006 23:09:37 -0700, "Peter Duniho"
wrote: Got a different exception? So far, as near as I can tell, a student pilot DOES need the tailwheel endorsement for solo flight. As I just posted (sorry! I'm late to this thread), I didn't have it until after I'd gotten my certificate. But I suspect this was an oversight. If you-all like, I'll ask the instructors at the airport, which does all its primary training in Cubs. Note however that even when flying solo, the student is under the supervision of the instructor, so that may obviate the need for the endorsement. In my case, the instructor (now a friend) actually drove up from the neighboring state on each of my cross-country solo flights and sat around the airport for hours at no pay; he was that meticulous about supervising. -- all the best, Dan Ford email: usenet AT danford DOT net Warbird's Forum: www.warbirdforum.com Piper Cub Forum: www.pipercubforum.com In Search of Lost Time: www.readingproust.com |
#40
Peter Duniho wrote
"Bob Moore" wrote in message . 121... Agreed. But is required training (and in particular, training required by 61.31(i)) a "rating limitation"? No...Fist because it can be endorsed by an Authorized Instructor and second probably because it comes under the second part of the title of 61.31 which contains three distinct items: "Section 61.31: Type rating requirements, additional training, and authorization requirements". Well, if it's not a "rating limitation", then 61.31(k) doesn't apply. (k) Exceptions. (2) The rating limitations of this section do not apply to— (ii) The holder of a student pilot certificate; They can't apply since a student pilot certificate contains no ratings, only training endorsements. In addition, any 61.31(i)requirement for student pilots is more than covered by 61.87c and 61.87n Section 61.87n: Solo requirements for student pilots. (n) Limitations on student pilots operating an aircraft in solo flight. A student pilot may not operate an aircraft in solo flight unless that student pilot has received: (1) An endorsement from an authorized instructor on his or her student pilot certificate for the specific make and model aircraft to be flown; and (2) An endorsement in the student's logbook for the specific make and model aircraft to be flown by an authorized instructor, who gave the training within the 90 days preceding the date of the flight. Bob Moore |
| Thread Tools | |
| Display Modes | |
| Tailwheel units on ebay | Victor Bravo | Home Built | 1 | July 24th 05 10:47 AM |
| Tailwheel Crosswind Landing | Piloting | 32 | December 6th 04 03:42 AM | |
| Advice on flying Pitts with Haigh Locking Tailwheel | Ditch | Home Built | 19 | January 4th 04 11:18 PM |
| Tailwheel endorsement | John Harper | Piloting | 58 | December 12th 03 02:48 PM |
