Amateur night at the field
Old May 13th 06, 12:55 AM posted to rec.aviation.piloting
Default Amateur night at the field
"Bela P. Havasreti" wrote in message
On Fri, 12 May 2006 19:11:52 GMT, Orval Fairbairn
Reality check: Even if everybody were to use the 45 entry, they wouldn't
all be usinf the same set of references. Some would be a mile away on
downwind, while others would be 1/4 mile away. Then you have a problem!
There is simply no excuse for a three mile "final" in a light aircraft!
There have been two mid-air collisions near my home-base airport
over the last several decades. Both occurred at the "convergence"
of the entry to the 45 (a popular reporting point for said 45 entry).
My one close call to a mid-air (in 29+ years of flying) also occurred
at the entry to a 45 at a near-by un-controlled field.
http://www.avweb.com/news/columns/182100-1.html Pelican's Perch #30:
The 45-Degree Zealots
  #32
Old May 13th 06, 04:42 AM posted to rec.aviation.piloting
Orval F wrote:
If you had read my posting completely
I did.
you would have noticed that you ALWAYS check for traffic in the pattern.
I do.
After re-reading Deakin's article on pattern ops (thanks Matt) I've had
to rethink the upwind entry idea. I know the 45 isn't always the best
way, as often times I'll enter on a base or straight in, but always
after announcing my position & intent on CTAF.
Agreed, unless you're in a very busy pattern (been there) or you're
extending downwind for someone 'cause you're a nice guy )
  #33
Old May 13th 06, 05:30 AM posted to rec.aviation.piloting
"Kingfish" wrote in message
I did.
I do.
aircraft
....or the tower says, "...extend your downwind, I'll call your base."
  #34
Old May 13th 06, 06:28 PM posted to rec.aviation.piloting
That too, but the subject was uncontrolled fields
Campbell Field Fly-In (9VG)! Oct. 15-16, 2005. Weirwood, Virginia. [email protected] Home Built 0 October 7th 05 10:26 PM
Campbell Field Fly-In (9VG)! Oct. 15-16, 2005. Weirwood, Virginia. [email protected] General Aviation 0 October 7th 05 10:23 PM
Did the Germans have the Norden bombsight? Cub Driver Military Aviation 106 May 12th 04 07:18 AM
