#31
Steven P. McNicoll wrote:
"Jose" wrote in message y.net... To comply with the notation on the chart "ADF required". Notes like this are not regulatory, they're just reminders. That is incorrect. |
#32
"Jose" wrote in message .net... I suppose this would be true, as the actual regulations are in part something-or-other, and it is not required that one even have the chart, just the textual description of the approach. Nonetheless, I would expect pilots not to second-guess government publications in that manner; after all part something-or-other might also have a misprint. If it is an error, it should be NOTAM'd until it is reprinted. Absent a NOTAM, I would expect pilots to rely on the government publication that contained the putative error. In what manner would you expect pilots to rely on the note "ADF REQUIRED" on the SAC ILS or LOC RWY 2? When ADF is actually required on non-NDB approaches the note "ADF REQUIRED" adds nothing to the approach, it simply states a fact. When the note appears on an approach that can be flown without ADF it only creates confusion. FAA Order 8260.19C Flight Procedures and Airspace CHAPTER 8. INSTRUMENT APPROACH PROCEDURES DATA TRANSMITTAL SYSTEM SECTION 3. COMPLETION OF FAA FORMS 8260-3/5 814. NOTES. h. Equipment Requirement Notes. Determine the need for equipment notes after evaluating all SIAP segments, including missed approach. To avoid proliferation of equipment requirement notes, all IFR aircraft are assumed to have at least one VOR receiver. Therefore, the note "VOR required" is not appropriate. VOR, ILS, or other non-ADF approaches may require ADF for procedure entry or missed approach. Use standard Note: "ADF required." If radar vectoring is available, use standard Note: "ADF or radar required." You have just proven yourself wrong. The note that results from application of Paragraph 814 h. goes on the applicable 8260.3 or 8260.5 which is an amendment to FAR 97. |
#33
Robert M. Gary wrote:
Steven P. McNicoll wrote: There's a feeder route from the VOR to EXECC. There's no need for ADF on this approach, the note "ADF REQUIRED" is an error. Steven, if you have any push with the FAA, any help getting this notation removed would be very, very appreciated. This is causing headaches for many pilots who don't have IFR GPSs (and of course most of us put the ADF in the dumpster long ago). I was talking to a local DE who used to be a big wig at the FSDO. He didn't even believe me until I pulled out the charge. He said he was going to make some calls to the FAA and thought perhaps he could help get this fixed as well. -Robert It has already been mentioned to the proceddures folks. They will "get around to it when they can." AOPA has a lot more juice than Steve but they are overwhelmed fighting user fees. |
#34
![]() "Robert M. Gary" wrote in message oups.com... Steven, if you have any push with the FAA, any help getting this notation removed would be very, very appreciated. This is causing headaches for many pilots who don't have IFR GPSs (and of course most of us put the ADF in the dumpster long ago). I was talking to a local DE who used to be a big wig at the FSDO. He didn't even believe me until I pulled out the charge. He said he was going to make some calls to the FAA and thought perhaps he could help get this fixed as well. I have no push with the FAA. The TPP has an email address for notification of charting errors on the inside front cover. I sent the following message: I found an error on the SAC ILS or LOC RWY 2 SIAP chart. The note "ADF REQUIRED" appears on the approach plate, but ADF is not required for procedure entry or missed approach. Since this approach can be flown without ADF or GPS in lieu of ADF the note is in error and must be removed. |
#35
![]() "Sam Spade" wrote in message news:0Nxlg.179313$bm6.96676@fed1read04... That is incorrect. As they can be nothing else, that is entirely correct. |
#36
![]() "Sam Spade" wrote in message news:sOxlg.179314$bm6.172001@fed1read04... You have just proven yourself wrong. The note that results from application of Paragraph 814 h. goes on the applicable 8260.3 or 8260.5 which is an amendment to FAR 97. You've just demonstrated your inability to use simple logic. |
#37
the SAC ILS or LOC RWY 2? When ADF is actually required on non-NDB approaches the note "ADF REQUIRED" adds nothing to the approach, it simply states a fact. When the note appears on an approach that can be flown without ADF it only creates confusion. .... in the same manner that pilots would deal with being given a clearance to fly an ILS when they did not have an ILS receiver aboard. I expect pilots to rely on the publication as accurately reflecting facts, and the presence of "ADF Required" (which as stated upthread was actually initiated by NOTAM) would be relied upon as reflecting the fact that ADF is required. I would not expect pilots to second-guess NOTAMS or approach procedures. If it says ADF required, then an ADF is required. So, if cleared for the approach, and no ADF is aboard, the word "unable" or some equivalent would be legally required. As you note, when the note is "in error", confusion results. Jose -- The monkey turns the crank and thinks he's making the music. for Email, make the obvious change in the address. |
#38
of charting errors on the inside front cover. I sent the following message: I found an error on the SAC ILS or LOC RWY 2 SIAP chart. The note "ADF REQUIRED" appears on the approach plate, but ADF is not required for procedure entry or missed approach. Since this approach can be flown without ADF or GPS in lieu of ADF the note is in error and must be removed. It would be interesting to hear the response. Jose -- The monkey turns the crank and thinks he's making the music. for Email, make the obvious change in the address. |
#39
"Sam Spade" wrote in message news:sOxlg.179314$bm6.172001@fed1read04... You have just proven yourself wrong. The note that results from application of Paragraph 814 h. goes on the applicable 8260.3 or 8260.5 which is an amendment to FAR 97. You've just demonstrated your inability to use simple logic. When you are out of ideas then, in your typical fine fashion, you resort to personal attacks. Shoot the messenger as you so love to do, Steve. That does not change the FACT that the note is an FAR. |
#40
"Sam Spade" wrote in message news:0Nxlg.179313$bm6.96676@fed1read04... That is incorrect. As they can be nothing else, that is entirely correct. Why can they be "nothing else?" |
Help! - Wooden prop - any info? | G0MRL | Aviation Marketplace | 1 | February 13th 06 03:14 PM |
Seeking Northrop Gamma info | Dillon | Restoration | 3 | December 12th 05 04:45 AM |
Helicopter Physics info online anywhere?? | [email protected] | Rotorcraft | 4 | April 24th 04 04:18 PM |
POSA Carb Info and HAPI Engine Info | Bill | Home Built | 0 | March 8th 04 08:23 PM |
Starting new info site need info from the pros | MRQB | Piloting | 7 | January 5th 04 03:20 AM |
