#31
Jay Honeck wrote:
However, after 30 minutes in the air, she noticed that the METAR data had not updated. The NEXRAD radar and satellite data were updating every 6 minutes or so, but the METARs remained the same as when they initially uploaded. According to XM the update rate for the Metars is 12 minutes. In my experience using the system if the airport has an ATIS the weather info that is displayed will the the ATIS info and not the current conditions. I'm not sure if that is what you were seeing. This was one of the shortcomings I found with the system when it first came out. It's good for monitoring trends in the weather but not actual conditions. To answer the original question this is why I use it as a strategic tool and not tactical. |
#32
IIRC visible satellite images will show low clouds as very dark... the bright
clouds are higher. Are you sure it showed no cloud-cover? Both Mary and I looked at the same picture on the Weathermation computer at Racine's Batten Field, which showed clear skies from Michigan to Iowa, when, in fact, the entire area was under a relatively low (2500 - 3000 foot) thin (500 - 1000 foot thick) overcast. The info on the 496 displayed the same way. I suppose the low clouds happened to display in the same color as the ground, but that would seem to be less than helpful. ;-) -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
#33
![]() "Jay Honeck" wrote in message oups.com... For those of you who have XM weather integrated with your GPS. Do you use the weather information to paint a big picture of what's going on around you. I.E. "If I fly 50 miles thataway, it looks like I'll be able to circumvent this line of storms." The satellite image is an infrared image with all the limitations infrared has, but it works at night............thus a night image is still available. METAR is just that. A METAR only gets updated every hour unless there is a special. Complain to the FAA. Karl "Curator" N185KG |
#34
Michigan to Iowa, when, in fact, the entire area was under a relatively low (2500 - 3000 foot) thin (500 - 1000 foot thick) overcast. Maybe it was thin enough to be transparant when looked at from above, but not when looked at lengthwise. Jose -- The monkey turns the crank and thinks he's making the music. for Email, make the obvious change in the address. |
#35
![]() "Jay Honeck" wrote in message ps.com... Strike one for XM. Apparently with a thin-but-solid overcast, the satellite photo data is worse than useless. In fact, it shows perfectly clear skies where none exist. (Given the same faulty presentation on the airport's computer, I'm prepared to accept that this is not a flaw in XM weather -- but it *is* a flaw, nonetheless.) I'd say that's a pretty sure indication that the satellite imagery itself was defective. I don't know what might have caused that, but normally it should be reliable Actually, I've noticed this many times in the past. Satellite photos will show clear skies while we are actually beneath a solid overcast. I don't know if the operators can selectively set the sensitivity of the camera to not show thin layers, or what, but this isn't the first time that satellite imagery of cloud cover has been 100% wrong. Hi Jay and Mary, Without appearing to defend the XM Weather technology, here's my put on what you are seeing based on my experiences in another life working with some sophisticated and 'spooky' equipment. Satellite "images" used to construct Wx displays are generally collected with LWIR [Long Wavelength InfraRed -- 8 to 13 microns] imaging radiometers. Water vapor [cloud] is generally transparent in the LWIR while percipitation [rain, snow, etc.] is not. That's why the Wx images displayed can show rain but not the clouds that drop it. Same with the microwave displays, i.e. RADAR. Here's the first hint: you can get the same type of displays on a full dark night. What is Atlas' tail number again? I might be coming your way next month. Regards, Casey Wilson Freelance Writer and Photographer |
#36
As much as you fly you (or the little woman) should really think about
finally getting your Instrument Ratings. This way you won't have to worry about any overcast's and go happily on your way. Just a thought. As far as METARS go I believe that unless there is a significant change they only update once an hour. XM doesn't create METAR's they just display the information. Sounds a little bit like you were expecting the 496 to be a panacea for all things weather and it turns out to be just a system of displaying information you could get from other sources. Jon Kraus '79 Mooney 201 4443H @ UMP Jay Honeck wrote: For those of you who have XM weather integrated with your GPS. Do you use the weather information to paint a big picture of what's going on around you. I.E. "If I fly 50 miles thataway, it looks like I'll be able to circumvent this line of storms." Mary and I are very new to XM, but have already used it on several x-country flights, including one today that highlighted some weaknesses in the system. We flew from Racine, WI to Iowa City, IA, about a 1.5 hour flight, depending on winds. A cold front was approaching from the north, with a very juicy airmass in place to the south. Flight service indicated good VFR all the way, leaving Racine around 7 PM. This would put us on the ground right around sunset, which was our goal. Using the airport's computer, the satellite pic showed no cloud-cover over our route of flight at all. This, of course, was contradicted by our Mark V eyeballs, and METARs that indicated a broken to overcast layer at around 2800 feet, all the way from the Mississippi east to our position on the western shore of Lake Michigan. Visibilities ranged from 7 to 10 miles along the route of flight when we launched. The XM weather on the 496 takes around ten minutes to upload, which meant that we were already airborne by the time we were getting useful weather. Although this is something we will learn to work around, I find this time lag to be a bother. (I know, much wants more!) We're going to have to get in the habit of turning on the 496 before engine start, to allow time for downloading. We were soon buzzing along under the overcast in smooth air but really crappy visibility (especially when the sun would occasionally break through and hit that moist, tropical air), and we were really glad when the METARs finally downloaded into the Garmin. We've mounted the 496 on the co-pilot's yoke, so Mary was working the GPS for the first time, but had only minimal difficulties navigating Garmin's excellent menus. She laughed when she was able to look at the "live" satellite photo, which (like the one in the airport) showed nothing but clear, blue skies ahead, while we were obviously under a pretty thick overcast. Strike one for XM. Apparently with a thin-but-solid overcast, the satellite photo data is worse than useless. In fact, it shows perfectly clear skies where none exist. (Given the same faulty presentation on the airport's computer, I'm prepared to accept that this is not a flaw in XM weather -- but it *is* a flaw, nonetheless.) She then started checking METAR data ahead, to make sure that things weren't falling apart along our route of flight. Having this data on board is priceless, IMHO, and it showed that conditions were stable until the Mississippi, and then improved dramatically to the west. Obtaining this data is as easy as running your cursor over a little triangle next to each reporting station, and having it in the plane was a major reason for purchasing the 496. However, after 30 minutes in the air, she noticed that the METAR data had not updated. The NEXRAD radar and satellite data were updating every 6 minutes or so, but the METARs remained the same as when they initially uploaded. Obviously, in changing flight conditions this slow rate of change is simply unacceptable, and we quickly reverted to listening to AWOS's ahead on the radio. Strike two for XM. By the time we hit the Big Muddy, we were able to climb on top of the layer, which rapidly diminished to a thick haze layer. The rest of the flight was uneventful, and we didn't refer to the 496 again. IMHO, the jury is still out on the unit. It's wonderful for watching/avoiding precipitation and storms, to be sure, but it certainly proved to be less than useful on this flight. And I can assure you that we fly in these kinds of fuzzy VFR conditions FAR more often than we do when thunderstorms are threatening. I'm going to contact Garmin about the update rate on METARs, and hope there's some setting or software update I can install to improve the rate of change. If it can't be improved, the unit will end up being far less useful than expected. -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
#37
![]() "Jon Kraus" wrote: As much as you fly you (or the little woman) should really think about finally getting your Instrument Ratings. This way you won't have to worry about any overcast's and go happily on your way. Just a thought. Indeed. I've got the satellite image feature turned off because I don't need it; the clouds just get in the way of other stuff on the screen. -- Dan C-172RG at BFM |
#38
![]() "Peter Duniho" wrote in message ... : : As I already said, all that XM does for you is show you the data in a : friendlier way, and avoid the radio call to the FSS. Expecting more from : them is unreasonable and will guarantee disappointment on your part. : : Pete : : All said and done, I still consider the monthly ~$30 charge to be a user fee of sorts. You can call FSS on the radio or pay the fee and receive the same info. More convenient to use the GPS? Maybe for some... |
#39
..Blueskies. wrote:
"Peter Duniho" wrote in message ... : : As I already said, all that XM does for you is show you the data in a : friendlier way, and avoid the radio call to the FSS. Expecting more from : them is unreasonable and will guarantee disappointment on your part. : : Pete : : All said and done, I still consider the monthly ~$30 charge to be a user fee of sorts. You can call FSS on the radio or pay the fee and receive the same info. More convenient to use the GPS? Maybe for some... I dunno, I have much better luck loading weather on the MX20 than I have communicating with Flight Watch/FSS over the radio. And the graphical presentation is much easier. |
#40
![]() "Ron Natalie" wrote in message m... : .Blueskies. wrote: : "Peter Duniho" wrote in message ... : : : : : As I already said, all that XM does for you is show you the data in a : : friendlier way, and avoid the radio call to the FSS. Expecting more from : : them is unreasonable and will guarantee disappointment on your part. : : : : Pete : : : : : : All said and done, I still consider the monthly ~$30 charge to be a user fee of sorts. You can call FSS on the radio or : pay the fee and receive the same info. More convenient to use the GPS? Maybe for some... : : : : I dunno, I have much better luck loading weather on the MX20 than : I have communicating with Flight Watch/FSS over the radio. And : the graphical presentation is much easier. I agree about the graphical representation... picture says a thousand words... |
Cant save the downloaded real weather | Mikker | Simulators | 1 | September 16th 04 02:08 PM |
Ice meteors, climate, sceptics | Brian Sandle | General Aviation | 43 | February 24th 04 12:27 AM |
