Removing Ethanol from Gas?
Old August 9th 06, 08:24 PM posted to rec.aviation.piloting
Jim Macklin
Default Removing Ethanol from Gas?
MoGas could be used in gasoline powered vehicles and
equipment on the airport, to use the 8,000 gallons in a
reasonable time. Since many airports are city operated,
police cars and such could also use the fuel farm at the
airport.
"RST Engineering" wrote in message
| The problem is not getting gasoline without ethanol. I
can get as many tank
| cars as you wish and have it delivered to you by Friday
morning. The
| problem is exactly that, you get a tank car (or an 8000
gallon tanker) full,
| no less. Using 8000 gallons of a fuel that isn't quite as
stable over time
| as avgas is the corker.
| When we used to be able to go down to the local gas
station with a 55 gallon
| drum or tank, it was really quite easy. Getting a small
airport to burn
| 8000 gallons of auto fuel is not. Not to mention the
airport having to make
| a new storage tank (can we say permits and lots of time?)
and pay for the
| project out of "profits".
| Jim
| Ethanol is usually blended at the time of being loaded
on a tanker
| truck, so if the local or state law allows, it is very
easy to order a
| tanker full of auto fuel without ethanol. It's not added
at the
| refinery.
Old August 9th 06, 08:42 PM posted to rec.aviation.piloting
Peter Dohm
"Jim Macklin" wrote in message
news:7MqCg.34$SZ3.3@dukeread04...
airport.
That's actually a very promising solution; at least until the mandate
problem can be successfully addressed.
Peter
morning. The
stable over time
airport to burn
and pay for the
| Jim
on a tanker
easy to order a
at the
| refinery.
Old August 9th 06, 08:51 PM posted to rec.aviation.piloting
RST Engineering
I'm afraid you don't quite get the picture, Jim.
Actually, most "small" country airports are county owned and operated, but
your premise of municipal vehicles fueling up is still legitimate. Whether
you call them police cars or sheriff cruisers isn't the point.
What IS the point is that the airport (for it's own self-preservation) is
usually located a few miles from town. To tell every cop car, road grader,
utility vehicle that they are going to have to go out to the airport to fuel
isn't feasible.
Nor is it feasible to have civilians (airplane owners) go to a municipal
fuel farm in town and fill up tanks or jugs. First of all, municipalities
like counties aren't set up to sell anything to the general public, fuel
included. You'd have to generate such a hodge-podge of checks and balances
(yes, the treasurer is a real witch when it comes to accountability of
funds) that any savings on fuel just went down the dumper.
COuld we do it by patch and mend? Possibly. Would it pay for itself? Not
unless the mogas sold for approximately what avgas is selling for.
airport.
Old August 9th 06, 08:58 PM posted to rec.aviation.piloting
Jim Macklin
The point is that GOVERNMENT control of supply always screws
up the system. So, when it gets bad, the herd in the big
cities demand more government control. That will fix
everything, right, NOT.
and operated, but
legitimate. Whether
point.
car, road grader,
the airport to fuel
| isn't feasible.
to a municipal
all, municipalities
checks and balances
accountability of
for itself? Not
selling for.
| Jim
| "Jim Macklin" wrote
in message
| airport.
Old August 10th 06, 04:28 PM posted to rec.aviation.piloting
Jay Honeck
Although I would prefer that it be cheaper, if given a choice I would
buy mogas for my plane if it were available on the field, even if it
were the same price as avgas.
My O-540 simply runs better with it.
Jay Honeck
Iowa City, IA
Pathfinder N56993
www.AlexisParkInn.com
"Your Aviation Destination"
Old August 9th 06, 08:31 PM posted to rec.aviation.piloting
Peter Dohm
ps.com...
The best way to remove ethanol from gas is for us to affect legislation
that would otherwise mandate ethanol in all gasoline, even that used
for off-road use. Most congress people are completely unaware that auto
fuel is used successfully by a large number of aircraft owners and that
ethanol poses a significant safety risk. There are some very powerful
lobbying forces behind the new mandates. It's important that we be
heard, i.e., we participate. Boaters are also affected by ethanol
mandates so it may be helpful to join forces with that community.
-----snipped------
You've summed it up rather well.
The problem appears to be entirely one of mandates, and the solution is to
remove the mandates.
Peter
Old August 9th 06, 08:41 PM posted to rec.aviation.piloting
Gig 601XL Builder
"Peter Dohm" wrote in message
ps.com...
-----snipped------
I'd bet that 99.9% of Congress even knows it is an issue. The AOPA and EAA
better get a letter writing campaign going. It is a lot easier to stop
mandates before they are in place than it is to get one removed.
Old August 10th 06, 04:15 AM posted to rec.aviation.piloting
J. Severyn[_1_]
The biggest issue is the reduction in power. You can regain the power by
rejetting the carb or injectors and assuring sufficient intake airflow, but
then the fuel flow is much higher.....and your range is poor.
The fuel system might need modification to insure all components are
compatible with ethanol. One example is: the O-rings in your fuel tank
selector might not tolerate ethanol, swelling and making the fuel selector
tight or even locked in one position.
Regards,
John Severyn
@KLVK
"Jay Honeck" wrote in message
The adding of ethanol to gasoline has made the auto-gas STC unusable
for many aircraft owners, nationwide. So far, we're okay (in Iowa,
which is pretty funny) and are able to purchase untainted mogas -- but
the long-range situation seems untenable. We, as a nation, are
inexorably being forced toward the addition of alcohol into ALL
gasoline, so it seems...
On the Cherokee 235 user's group, there is a guy who's been
successfully using ethanol-gas in his aircraft. It's ruined his
fiberglass tip tanks, but he apparently expected this to happen.
Otherwise, the engine is running fine, or so he reports. (Personally,
I think he's crazy, ruining tip tanks that run close to $4K *apiece*,
but that's just me...)
His experience has led to a more interesting (to me) discussion about
the possibility of REMOVING ethanol from gasoline. Several ideas have
been postulated (evaporation; heating; adding water), but none of them
sound particularly safe or easy.
Any chemists out there? Anyone know a way to remove the ethanol from
mogas, so that we may safely use it in our aircraft?
Jay Honeck
Iowa City, IA
Pathfinder N56993
Old August 11th 06, 02:46 AM posted to rec.aviation.piloting
NW_Pilot
Jay Honeck
Iowa City, IA
Pathfinder N56993
Hey Jay,
I added your web site to my links page!
http://www.aircraftdelivery.net/links.htm
Old August 11th 06, 06:04 AM posted to rec.aviation.piloting
Roger (K8RI)
Then he's most likely doing it illegally as he's not using a know auto
gas which means no STC.
Crazy is not quite the word I'd use.
It's not just those fiberglass tips, seals and O-rings that are
attacked by ethanol. He's looking for far more problems than tip
tanks. BTW he might want to consider where the disolved resin and
some fiberglass went. I wonder what his fuel filter and gascolator
look like inside.
Or smart.
Alcohol, in addition to burning cleaner is also an octane booster.
That means even if you sucessfully remove it, you are left with a
lower octane gas and no STC which probably means no insurance.
And what do you do to raise the octane back up?
Yes there is a relatively easy way to remove alcohol from gas that
just takes a bit of filtering after the process. Remember Alcohol is
hydroscopic.
But I repeat, it's no longer car gas so no STC which probably means no
insurance and how much lower octane can the specific engine handle.
Have a problem and the FAA, Insurance company, and lawyers will not be
on your side.
www.rogerhalstead.com
Ethanol & capacitance fuel-level sensors Adam Aulick Home Built 4 May 20th 06 03:28 PM
The effects of Ethanol on... ventus2 Home Built 35 May 8th 06 05:45 AM
MoGas users: Ethanol replacing MTBE John Piloting 167 May 5th 06 08:31 PM
Ethanol Mandate for Iowa? Jay Honeck Piloting 155 October 4th 05 03:17 PM
Ethanol Powered Airplane Certified In Brazil Victor Owning 4 March 30th 05 09:10 PM
