#31
T o d d P a t t i s t wrote: I would venture that the captain on that AA flights' first thought would be, "we're turning now", then he would ask the center about the accuracy of the gliders' altimeter. Why would he question that when he'd just received a report that the glider was at FL 190 and presumably on an IFR flight plan and in communication with ATC? Todd, welcome aboard. Thanks for your input. To answer your question I would have to say, given the altitudes in Chriss' scenario, there would be cause for alarm due to the small difference in the altitudes, and closure rate. Not knowing the accuracy of the story gliders altimeter, I would, if I were driving the large aircraft tell myself that a thirty degree turn off this heading won't hurt anyone . Is the glider pilot flying off of an altimeter set at zero, or is he flying GPS altitude, and if he is flying with his altimeter set at 29.92, how far out of tune is his old altimeter that may not have seen the bench since it was new? Don't know, food for thought, I hope. What I do know is that altimeters that have not been bench checked in a while can be waaay off. I just came from our club, where I talked with one of our members who has a beautifully installed xponder, with encoder, and all the paper work to go with it. We also looked at the poh list of approved equipment. Going back to Chris's scenario, if the controller had told me that the glider traffic had an encoder and they had verified his altitude during his climb, I might feel better, but I cant see this guy, unless he has a xponder, so I'm still going to make a nice little deviation around the traffic. I think the more realistic scenario is yours where your in a window and the possibility of ever coming closer than five miles is far fetched. Todd, with regard to your flight where you had 10,000ft separation, I'm guessing you were flying in a wave window. Would also like to ask if you use a transponder. Thanks for your input. -- |
#32
Oh, for God's sake, snoop. You're really beginning to annoy me. If you fly IFR as much as you say you do, you hear that every day. Aircraft A receives a hold down clearance until he is clear of traffic B above. American was thousands of feet below me, climbing to an altitude two thousand feet below me. He saw me on his TCAS. There was no conflict. ATC was providing separation. Everybody was happy. Geez. Chris, I'm getting annoyed with this thread too. I've got a note into Shawn, will give a report after he briefs us. Let's put someone else in charge of stirring this pot. Todd your in charge. F2 if your in the Big D look us up at TSA. And the 135/121 comment really cut deep! Later, snoop Going out to the glider club? That's sounds good. I'll join you. Chris Fleming, F2 |
#33
Is the glider pilot flying off of an altimeter set at zero, or is he flying GPS altitude, and if he is flying with his altimeter set at 29.92, Come on Snoop you should know the answers to these. The pilot is instrument rated and as a result has been trained to fly in IFR airspace. He will set it to 29.92 as he is supposed to. how far out of tune is his old altimeter that may not have seen the bench since it was new? IF flying in Class A airspace (diffenent from Cloud Flying) he will have a Mode C Transponder that has been checked with in the last 24 months. Don't know, food for thought, I hope. What I do know is that altimeters that have not been bench checked in a while can be waaay off. Also as is standard procedure the Controll will confirm that Transponder and the Altimeter coorsponde within a reasonable tolerance. Brian CFIIG/ASEL |
#34
snoop wrote:
Chris, I'm getting annoyed with this thread too. I've got a note into Shawn, will give a report after he briefs us. Let's put someone else in charge of stirring this pot. Todd your in charge. F2 if your in the Big D look us up at TSA. And the 135/121 comment really cut deep! Later, snoop Snoop, I don't know where the Region 10 competition is going to be next year, but maybe I'll see you there. I can understand your frustration with all of this stuff, but the point of this forum is to be able to exchange ideas. Don't take any of it as gospel. You're putting a lot of faith into what Shawn has to say, but he's not perfect, either. He has repeatedly said that § 61.57 doesn't apply to single-pilot operations, but it absolutely does. CFAR § 61.57(c)(2)(i) clearly specifies that in order to act as PIC in a glider under IFR while solo, you need to log at least 3 hours of instrument time in the last 6 months, of which 1 1/2 must be in gliders (the other 1 1/2 may be in either airplanes or gliders): § 61.57 Recent flight experience: Pilot in command. (c) Instrument experience. Except as provided in paragraph (e) of this section, no person may act as pilot in command under IFR or in weather conditions less than the minimums prescribed for VFR, unless within the preceding 6 calendar months, that person has: (2) For the purpose of obtaining instrument experience in a glider, performed and logged under actual or simulated instrument conditions- (i) At least 3 hours of instrument time in flight, of which 1 1/2 hours may be acquired in an airplane or a glider if no passengers are to be carried. Also, don't take everything you read in Soaring Magazine to be gospel either. In last month's thread on this topic, we discussed Tom Reesor's letter in the August SOARING magazine. He confidently claimed that to fly a glider IFR one requires: 1. "The pilot to be instrument rated in single-engine airplanes and also have a glider rating ... to fly a glider in clouds," and 2. "Gliders flying on instruments are required to have a full gyro panel." Neither of which is true. CFAR § 61.3(e)(3) states that a glider pilot must have an airplane instrument rating to fly a glider IFR, but it doesn't specify that it needs to be a single-engine class rating: § 61.3 Requirement for certificates, ratings, and authorizations. (e) Instrument rating. No person may act as pilot in command of a civil aircraft under IFR or in weather conditions less than the minimums prescribed for VFR flight unless that person holds: 3) For a glider, a pilot certificate with a glider category rating and an airplane instrument rating. And there is no FAR whatsoever that requires a glider to have a "full gyro panel." The only gyroscopic instrument that most glider manufacturers require for cloud flying is a "Turn & Bank Indicator with Slip Ball." So what do you do? Read the regs for yourself. I've referenced the exact FARs to back up everything that I have said. Read your glider's manual. Is your glider approved for cloud flying? If your glider has an experimental certificate, read your operating limitations. Did the FAA approve your glider for cloud flying? And, has your glider received all of its required inspections? If, after all of this you have determined that you meet all of the requirements to fly your glider IFR, you're legal to do so. So how do you do it? Personally, I don't file a flight plan. I only use IFR as a tool to climb into the Class A airspace, and I never know if the mountain wave above El Paso is good enough until I'm airborne. My climb to 17,000 feet is VFR with El Paso Approach Control, and if I'm still climbing strong, I'll request a handoff to Albuquerque Center and request an IFR climb with them. They first verify my transponder code, position and altitude, then ask for my intentions. I request altitude blocks in 4,000 foot increments, so the first clearance that I receive is from 16,000 to FL 200. As I climb and descend, ABQ shifts the block up and down. My mountain wave flights have all been local in nature, so my lateral clearance is defined by radials and distances from El Paso VOR, which I have programmed into my GPS. When I descend through 17,000 after my wave flight, I cancel IFR. I have never had any difficulties. In fact, the controllers have always been more than helpful. As a side note, I have never, nor do I ever intend, to fly a pure glider in a cloud. I'll wait for my Nimbus-4DM to arrive before I do that. Now where's that lottery ticket? Chris Fleming, F2 |
#35
snoop wrote:
Chris I would love to turn on a t&b and climb into the cloud, but I want to know that my bases are covered! I want the blessing of the people who would otherwise fry me, and you! It would be fun just to be the celebrity kind of pilot, and forge ahead, but I've found in my world it's been more enjoyable, to find out the facts, do it right, and let the feds go after the uninformed. Chris sounds pretty informed to me and you sound like you're a natural bureaucrat with a check pilot background. Thank God you weren't on my seniority list. You're not looking for information - you want to stop HIM doing it! If you don't want to do it - DON'T DO IT! Now let it go. GC |
#36
snoop wrote:
...Let's put someone else in charge of stirring this pot. Todd your in charge. Nobody's in charge here!!! Geez! I thought I'd left management pilots behind years ago! GC |
#37
snoop wrote: Chris, this is the exact reason I'm still looking for the technical answers. You just made about every working pilot reading your celebrity dialouge, pass out. "11o'clock 15 miles", your descending out of who knows what exact altitude, and the big boy is climbing toward you, this would wake everyone up. I would venture that the captain on that AA flights' first thought would be, "we're turning now", then he would ask the center about the accuracy of the gliders' altimeter. So Snoop, just by replacing the word "glider" in the above exchange with "your favorite trustworthy aircraft", your whole attitude would change? Explain exactly why hearing the work "Lear" for example would make you feel better? I'm sure there's a few rotting away at airports that are marginally airworthy, and might even have an owner who flew IFR 20 years ago, and is just itchin' to go fly...... Bottom line - if the glider is on a clearance we MUST assume the glider will behave just as any other aircraft. Because if we don't, then how on earth can we assume any one of the other aircraft will behave as well? This whole discussion is about SOARING in clouds. Except in the mountains, this means there WILL be a decent clearance between ground, VMC, and cloudbase. The glider pilot is not concerned with terrain, because in this situation it IS NOT AN ISSUE. If it were, the glider pilot likely would not fly. You are clouding the issue by insisting the glider operation take place at 500' AGL in fog directly over the tower at DFW. What we are talking about is operation at say, 6,000' AGL and above in the middle of Kansas. The only issues are about what is required to be legal to continue circling up into that nice towering cu. And once topped out at FL200, the glider pops out the side, then continues on to the next nice cloud in VMC. The glider pilot has, at all times, the option to change course and descend if asked by ATC. The controller and glider pilot COMMUNICATE, and establish an understanding that it may be possible that the glider will hit sink, but in that case, there is always the option to change course to stay clear of any traffic below the glider. As others have posted, flight in IMC without an autopilot can be difficult and tiring. The glider is only using the cloud to thermal up, then glide out the side in order to spend as little time in cloud as possible. This XC flight has no need of any fancy navigational equipment beyond a compass, as the pilot is planning to be VMC 95% of the time. -Tom CFIG, PVT ASEL with about 150 hours in airplanes, no instrument experience, and not planning to fly into clouds anytime soon. |
#38
5Z wrote:
.... -Tom CFIG, PVT ASEL with about 150 hours in airplanes, no instrument experience, and not planning to fly into clouds anytime soon. Funny that despite your non existing experience and intention, you seem to be the only one who actually understands what cloud flying in gliders is all about. Stefan |
#39
snoop wrote: Chris I would love to turn on a t&b and climb into the cloud, but I want to know that my bases are covered! Graeme Cant wrote: You're not looking for information - you want to stop HIM doing it! If you don't want to do it - DON'T DO IT! Now let it go. Come on Graeme - ease off. For U.S. glider pilots the interface between IFR flights and gliders is a tricky thing to get right and there are a lot of pitfalls. I agree with Graeme, in that the negative attitudes expressed in this thread have consisted primarily of vague warnings, half-informed scare tactics, and bluster from those who appear to think their ATP's give them special insight into cloud flying in gliders, while the constructive posts have tended to come from glider pilots, some of whom also have a lot of varied flight experience but lack the arrogance. It's the holier-than-thou attitude that is the most annoying and the least informative. Cloud flying in gliders in the US is poorly understood and grossly under appreciated. The sport could benefit significantly from cloud flying when properly trained and flown, but as it is the FAA and the SSA have paid far too little attention. As a result, I must agree with Todd that the legal pitfalls are substantial. This thread is a small part of beginning to change USA soaring for the better. Jack |
#40
Jack wrote: Cloud flying in gliders in the US is poorly understood and grossly under appreciated. The sport could benefit significantly from cloud flying when properly trained and flown, but as it is the FAA and the SSA have paid far too little attention. As a result, I must agree with Todd that the legal pitfalls are substantial. This thread is a small part of beginning to change USA soaring for the better. Jack, where have you been. Jack has summed up the point of this thread in his last paragraph. "The legal pitfalls are substantial". Bingo. This was a good walk through the problem. Like we've done many times over beers at TSA, right Jack. I love you man! Are you bringing the PIK for Labor Day? One thing I have to dispell, and disagree with my old friend Jack, and a couple others. I'm the furthest thing from a "bureacrat". I've never been a check airman, other than flying with guys doing their first crossing, or introduction to a new plane. I am the other items described, an atp, instrument, all that other stuff. So are the four other working atp/mechanic/pilot types at my club working in the hangar as we speak on rebuilding another tow plane, or the two very busy atp/cfig's who do the most instructing at our club. But this conversation was'nt about who's resume is bigger. This was about the search for facts. I know what Jack means by some pilots and their 'holier than thou attitude". But that wasn't didn't figure in the equation here. Learjet, 757, who cares, we need to look at the numbers. Chris gave us a scenario to look at. Put Clutch Cargo and his pals Spinner and Paddle Foot in what ever aircraft is in the scenario, it doesn't matter. Uh, oh, I think I just gave away my age. I'm now visiting with Shawn, on the email. Look forward to visiting with him when he gets back to the states. He's currently putting it on the line over in Iraq. Weekends here, let's fly! snoop(mick) |
| Thread Tools | |
| Display Modes | |
| Kid day at the airport... | Jay Honeck | Piloting | 92 | September 20th 05 05:42 AM |
| Passing of Richard Miller | [email protected] | Soaring | 5 | April 5th 05 02:54 AM |
| Mountain Flying Course: Colorado, Apr, Jun, Aug 2005 | [email protected] | Piloting | 0 | April 3rd 05 09:48 PM |
| Four States and the Grand Canyon | Mary Daniel or David Grah | Soaring | 6 | December 6th 04 11:36 AM |
| ADV: CPA Mountain Flying Course 2004 Dates | [email protected] | Piloting | 0 | February 13th 04 05:30 AM |
