Sounds like you might be complaining about the symptoms, not the
actual problem (i.e. multiple airports on the same frequency)... I always wondered why the FAA does this... There seems to be enough frequencies that they could spread them out a bit... I'm not sure which way I lean on this. Flying low through an area with several nontowered airports, it is useful to self-announce to all of them as I go by, and since they can be fairly close together, I may be relevant traffic for two or three at a time. A common frequency is useful for this. It does have its drawbacks though, as you can see. How far out do you (as a pilot in the pattern of a nontowered airport) want to hear from a low transiting pilot? Jose -- The monkey turns the crank and thinks he's making the music. for Email, make the obvious change in the address. |
On Sat, 26 Aug 2006 20:27:02 GMT, Jose
wrote: How far out do you (as a pilot in the pattern of a nontowered airport) want to hear from a low transiting pilot? The airport that I hear from the most while in the pattern at my home airport is about 13 nm away... They seem to have quite a bit more activity than our airport and quite often, it's difficult to get a word in edgewise when they have a few students or whatever in the pattern... There are airports closer than this one and they have different frequencies, so I have to assume that *someone* thought that this airport was far enough away that the transmissions would not intefere with each other... They were wrong, of course... If they're not within 5 nm of the airport or heading into the airport, I probably don't need to hear from them... Ideally, when I'm flying, I like to stay 5 nm away from any airport (or more depending upon the actual airspace restrictions)... I mapped this out for the Houston area once and that left with relatively few places to fly so I abandoned this notion rather quickly... |
Grumman-581 wrote:
Sounds like you might be complaining about the symptoms, not the actual problem (i.e. multiple airports on the same frequency)... I always wondered why the FAA does this... There seems to be enough frequencies that they could spread them out a bit... I really agree, but it's not the FAA who nominally does the "spreading." Unicom base stations apply to the FCC for the freq and most applied decades ago. FAA would have to adopt a rule (FAR), which states they now at its whim can order unicom base stations to apply for a new freq other than their present 122.8. Some fraction of airport operators then have the legal right (the Administrative Procedures Act, plus an Executive Order which gives the Office of Management and Budget the authority to weigh in as to the need for new rules on affected citizens, like unicom operators) to comment and oppose, stating (even if blowing smoke in many cases) that it will cost them too much, and then FAA must under law justify the cost-benefit to finally adopt the new rule. This legal reality is a door which can swing both ways. It tends also to prevent FAA from from just thinking about imposing rules on us pilots or owners in other seeming nuisance areas which will cost us too much re a cost-benefit analysis. Fred F. |
TxSrv wrote:
Some fraction of airport operators then have the legal right [...] to comment and oppose, stating (even if blowing smoke in many cases) that it will cost them too much How could it cost *any* money to switch frequencies. Are people really still using radios where changing the freq requires anything more than turning a knob? |
With a repost to r.a.student.
"BPH" == Bela P Havasreti writes: BPH CFIs, will you please, PLEASE stop teaching students this BPH stuff?!!! 8^) BPH On 122.75: Making 30+ second long position reports, 4500 feet BPH over some non-descript / podunk town. More annoying when the BPH broadcaster does so in broken english. Even more annoying BPH when the broadcaster does so every 5 minutes! BPH On CTAF: Announcing that you're taxiing from your parking BPH spot to "the active runway" at an airport that's the size of BPH an ex-WW2 air base. Who cares? BPH On CTAF: Announcing that you're "Clear of the active". You BPH might think anyone who is waiting to take off can *see* when BPH you're clear. The only exception I can think of is a BPH (severely) crowned runway where the other end can't be seen BPH from the departure end. BPH I'll think of some more later.... grins BPH Bela P. Havasreti |
And also please stop saying "active runway". Is there such as thing as
"inactive runway"? It might be more useful to say "clear of runway XX", that way someone listening might know which runway is being used. However, "clear of XX" is not entirely useless. At some airports you cannot see the other end of the runway. If you are departing behind a landing traffic, it would be helpful to know when the other airplane has left the runway so that you can start the takeoff roll. Bob Fry wrote: With a repost to r.a.student. "BPH" == Bela P Havasreti writes: BPH CFIs, will you please, PLEASE stop teaching students this BPH stuff?!!! 8^) BPH On 122.75: Making 30+ second long position reports, 4500 feet BPH over some non-descript / podunk town. More annoying when the BPH broadcaster does so in broken english. Even more annoying BPH when the broadcaster does so every 5 minutes! BPH On CTAF: Announcing that you're taxiing from your parking BPH spot to "the active runway" at an airport that's the size of BPH an ex-WW2 air base. Who cares? BPH On CTAF: Announcing that you're "Clear of the active". You BPH might think anyone who is waiting to take off can *see* when BPH you're clear. The only exception I can think of is a BPH (severely) crowned runway where the other end can't be seen BPH from the departure end. BPH I'll think of some more later.... grins BPH Bela P. Havasreti |
Bob Fry wrote in
: I'd have to respectfully disagree with your assessment on some of the calls. BPH On CTAF: Announcing that you're taxiing from your parking BPH spot to "the active runway" at an airport that's the size of BPH an ex-WW2 air base. Who cares? When I am ready to taxi, I say, Madison, 1943L ready to taxi, request advisories, Madison. This call is two fold. If somebody in the MBO is monitoring, they can give me a heads up that there is reported and when winds are calm, tell me what runway was last used. Helps me know my radio is working AND I work with the pattern. Plane could have called in before I flipped my avionics switch. Soooo. I do care..... BPH On CTAF: Announcing that you're "Clear of the active". You BPH might think anyone who is waiting to take off can *see* when BPH you're clear. The only exception I can think of is a BPH (severely) crowned runway where the other end can't be seen BPH from the departure end. Low wing planes are very hard to see on extra long runways, especially dark ones. So, if I am at the end of 17 and a plane lands, I fully appreciate when they report they are cleared the active. I then don't have to wait until I get a visual on them taxiing halfway up a 1 mile taxiway for me to take off. And as you stated, many runways I land on are rather hilly, and seeing a plane in the valley of a runway or the other end can be a rather difficult challenge. As far as cleared the active, if you are paying attention when you approach the airport, you know the active runway. You must not deal with uncontrolled airports that potentially have two active runways, such as intersecting runways, so yes, you can have an inactive runway. After landing, I try to say, Natchez, 43L, cleared the active 25, Natchez (or whatever runway it may be) so folks around me can know what runway I am indeed clearing. A few extra words for a bunch of safety sure is worth it to me. Allen |
A Lieberma wrote:
You must not deal with uncontrolled airports that potentially have two active runways, such as intersecting runways, so yes, you can have an inactive runway. You had me agreeing with you right up to this point. Both runways could very well be handling arriving and departing traffic, hence the concept that there is no one, true active runway at an uncontrolled airport. A pilot could very well choose to land or depart on the perpendicular runway to other traffic in the pattern and not be violating anything except the opinions of those who incorrectly believe there is only one active runway at an uncontrolled airport. Stick to "Podunk traffic, Cessna 123 clear of runway X," and you would be omitting the erroneous words such as "active" that have, at best, an ambiguous meaning at an uncontrolled airport. Oh, and where did the rest of your name go in your newsreader moniker? ![]() -- Peter |
"Peter R." wrote in
: A Lieberma wrote: You must not deal with uncontrolled airports that potentially have two active runways, such as intersecting runways, so yes, you can have an inactive runway. You had me agreeing with you right up to this point. Both runways could very well be handling arriving and departing traffic, hence the concept that there is no one, true active runway at an uncontrolled airport. Heck Peter, Just reading my own paragraph made me disagree with myself :-) Needless to say, you are right, at an uncontrolled airport, both runways should be treated as active since somebody just may be boning up on their crosswind techniques. Oh, and where did the rest of your name go in your newsreader moniker? ![]() on the inactive runway :-) Allen |
On CTAF:
Announcing that you're "Clear of the active". At our airport (which has only partial taxiways, and therefore often requires back-taxiing on other runways after landing) I always announce "Clear of all runways, Iowa City". That pretty much tells the tale to all concerned. -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
MX385 Radio removal | Marty from Florida | Owning | 3 | May 24th 13 08:26 AM |
terminology questions: turtledeck? cantilever wing? | Ric | Home Built | 2 | September 13th 05 09:39 PM |
I Hate Radios | Ron Wanttaja | Home Built | 9 | June 6th 05 05:39 PM |
1944 Aerial War Comes to Life in Radio Play | Otis Willie | Military Aviation | 0 | March 25th 04 10:57 PM |
Ham Radio In The Airplane | Cy Galley | Owning | 23 | July 8th 03 03:30 AM |
