TIS (traffic information service)
Old August 28th 06, 03:31 PM posted to rec.aviation.owning,rec.aviation.piloting
Default TIS (traffic information service)
We have had TIS in three of the planes in our partnership for a while
now. I consider it a safety of flight issue. When it is working the
number of unseen planes around you it displays is amazing. I really
don't want to fly without it at this point. Unfortunately is seems
that the data is not being sent more then 25% of the time, if that, in
the Seattle area. I'm aware of the issues of reception, and it's not
an equipment issue with three identical systems (GNS 430/GTX330) having
the same problems. I have spoken with the Center manager and he says
that if the radar is working, mode S and TIS data are working. I am
beginning to think that this is not true. Are you seeing the same
poor TIS data broadcast in your area? Does anyone have additional
information on the issue? I have spoken to AOPA and they are looking
into it. I've spoken with the avionics shop and they hear similar
complaints from other pilots. I've spoken with Garmin and they say
sales of the GTX 330 have fallen to nothing compared with what they had
been. There is no plan to replace our ASR 9 for a decade or so. We
should be able to count on TIS information being available in the
Seattle area for a long time to come. I'd like to see it working
reliably...
Thanks for the help,
Dave
Old August 28th 06, 05:10 PM posted to rec.aviation.owning,rec.aviation.piloting
john smith
In article .com,
reliably...
With the current high fuel prices, less people are flying, hence you are
seeing less traffic. :-))
Old August 28th 06, 10:34 PM posted to rec.aviation.owning,rec.aviation.piloting
Montblack[_1_]
("john smith" wrote)
Hey, that's not funny!
We bought into our gateless community in 1998. We are less than two miles
from the end of 9/27. Small planes used to fly over the house all-the-time
.....it was WONDERFUL!
These days, we regularly have beautiful weekends, and --- nothing! We've
been "watching" this trend for a few years.
Montblack
Old August 28th 06, 06:19 PM posted to rec.aviation.owning,rec.aviation.piloting
Larry Dighera
On 28 Aug 2006 07:31:54 -0700, wrote in
.com:
I didn't realize this was service was provided by the FAA:
http://www.tc.faa.gov/act310/projects/modes/tis.htm
AIM 4-4-16. Traffic Information Service (TIS)
a. TIS provides proximity warning only, to assist the pilot in the
visual acquisition of intruder aircraft. No recommended avoidance
maneuvers are provided nor authorized as a direct result of a TIS
intruder display or TIS alert. It is intended for use by aircraft
in which TCAS is not required.
b. TIS does not alter or diminish the pilot's basic authority and
responsibility to ensure safe flight. Since TIS does not respond
to aircraft which are not transponder equipped, aircraft with a
transponder failure, or aircraft out of radar coverage, TIS alone
does not ensure safe separation in every case.
c. At this time, no air traffic service nor handling is predicated
on the availability of TIS equipment in the aircraft.
http://www.aopa.org/members/files/pi...ction0108.html
A traffic information service (TIS) feature is also available.
This uses Bendix/King's $5,000 KT 73 datalink transponder to hook
up with air traffic control radar to depict nearby air traffic on
the KMD 550 or 850. TIS shows position, altitude, altitude trend,
and course information on up to eight target airplanes within a
chunk of airspace seven miles horizontally and 3,500 feet
vertically of the TIS-equipped airplane. TIS is currently
available from 80 FAA sites throughout the United States.
http://www.forecastinternational.com...rs/rs12814.htm
It looks like these folks are in charge of TIS:
http://www.tc.faa.gov/act310/Welcome.html
You can contact them he
http://www.tc.faa.gov/act310/staff/staff2.htm
To find out more information about the Mode S Surveillance
Program, contact:
Communication/Navigation/Surveillance
Engineering and Test Division
Surveillance Branch
Federal Aviation Administration
William J. Hughes Technical Center
Atlantic City International Airport, NJ 08405
Phone: (609) 485-5392
Fax : (609) 485-5995
Old August 28th 06, 06:34 PM posted to rec.aviation.owning,rec.aviation.piloting
Robert M. Gary
I assume you are saying that your TIS goes into "coast mode" and stops
updating for a period of time. I've found the same to be the case in
the Sacramento area. Also, there are certainly holes in where coverage
is available. If I fly from Sacramento to the Bay Area I'll lose TIS
around Franklin Field and pick it up again near Concord. In general I
think my PCAS system is more reliable but it doesn't give direction.
-Robert
reliably...
Dave
Old August 29th 06, 03:19 PM posted to rec.aviation.owning,rec.aviation.piloting
No. The box recognizes that it's being interrogated by the radar and
it responds with altitude data. It's programmed to display when the
mode S data does not contain TIS. That's the issue. TIS information
has been unavailable for as long as months at a time in Seattle. It
has been my experience that it is "rarely" available currently. I
would be interested to know if this is isolated to the NW or if the
entire country experiences this?
I would love to have ADS-B (the current name appears to be TIS-2). It
cost us $1000 to put TIS in the plane since we had the 430 and were
going to purchase a new transponder anyway. The Feds are still
thrashing around with the specs for the new TIS but currently politics
seem to be pushing to use the current spectrum which is too congested
to handle all the data. Sad but true.
A flight in the Seattle area will routinely put you in conflict with
dozens of other aircraft. We have congested airspace and mountains
that put a lot of VFR traffic in a small space. If TIS was only useful
for a year or two I'd consider it worthwhile. The Feds have indicated
that deployment of ADS-B in our area is a decade away.
Dave
Old August 29th 06, 03:24 PM posted to rec.aviation.owning,rec.aviation.piloting
Peter R.
I routinely fly across NY state and all the class C airports from western
to central and onto eastern NY offer TIS. Two years ago I installed the
Garmin GTX330 transponder that displays TIS traffic on an MX20 and GNS430.
It is definitely worthwhile in these areas.
Peter
Old August 29th 06, 03:38 PM posted to rec.aviation.owning,rec.aviation.piloting
Gig 601XL Builder
Here's a good TIS map that includes the ones scheduled to be shut down.
http://www.garmin.com/aviation/tis.jsp
Old August 29th 06, 03:45 PM posted to rec.aviation.owning,rec.aviation.piloting
Peter R.
Yep, a lot of my flying is in that big blue blob over the northeast US so
TIS serves my well.
Peter
18 Oct 2005 - Today’s Military, Veteran, War and National Security News Otis Willie Naval Aviation 0 October 19th 05 02:19 AM
NTSB: USAF included? Larry Dighera Piloting 10 September 11th 05 10:33 AM
12 Dec 2003 - Today’s Military, Veteran, War and National Security News Otis Willie Naval Aviation 0 December 12th 03 11:01 PM
