Graeme Cant wrote:
Because the rule is that ALL powered aircraft ALWAYS give way to ALL gliders and, in uncontrolled airspace, There is NO SUCH RULE. they do this by seeing the other aircraft and avoiding it. Not by squawking. All aircraft are required to see and avoid regardless of the right of way rules. Unlike the nautical rules, there's no stand-on (priviliged) vessel. Your required to not hit the other aircraft regardless of the who has the right of way. Prima facie, the powered aircraft is at fault. Like when I hit another car from behind, prima facie it's my fault. If you flew a glider into another aircraft from behind it would be at fault. The overtaking rules do not have an exemption for class. |
Ron Natalie wrote: There is NO SUCH RULE. FAR 91.113 http://www.airweb.faa.gov/Regulatory...C?OpenDocument (d) Converging. When aircraft of the same category are converging at approximately the same altitude (except head-on, or nearly so), the aircraft to the other's right has the right-of-way. If the aircraft are of different categories-- (1) A balloon has the right-of-way over any other category of aircraft; [(2) A glider has the right-of-way over an airship, powered parachute, weight-shift-control aircraft, airplane, or rotorcraft. (3) An airship has the right-of-way over a powered parachute, weight-shift-control aircraft, airplane, or rotorcraft.] However, an aircraft towing or refueling other aircraft has the right-of-way over all other engine-driven aircraft. |
5Z wrote:
Ron Natalie wrote: There is NO SUCH RULE. FAR 91.113 http://www.airweb.faa.gov/Regulatory...C?OpenDocument (d) Converging. When aircraft of the same category are converging at approximately the same altitude (except head-on, or nearly so), the aircraft to the other's right has the right-of-way. If the aircraft are of different categories-- (1) A balloon has the right-of-way over any other category of aircraft; [(2) A glider has the right-of-way over an airship, powered parachute, weight-shift-control aircraft, airplane, or rotorcraft. (3) An airship has the right-of-way over a powered parachute, weight-shift-control aircraft, airplane, or rotorcraft.] However, an aircraft towing or refueling other aircraft has the right-of-way over all other engine-driven aircraft. THat clause applies only when coverging other than head-on or nearly so. Head-on (or nearly so) or overtaking operations has rules that are not affected by aircraft category. |
"5Z" wrote in message oups.com... Ron Natalie wrote: There is NO SUCH RULE. FAR 91.113 http://www.airweb.faa.gov/Regulatory...C?OpenDocument (d) Converging. When aircraft of the same category are converging at approximately the same altitude (except head-on, or nearly so), the aircraft to the other's right has the right-of-way. If the aircraft are of different categories-- (1) A balloon has the right-of-way over any other category of aircraft; [(2) A glider has the right-of-way over an airship, powered parachute, As long as the glider doesnt pull out in front of the other aircraft. There are no absolutes. If you are going the speed limit in a car and someone runs out in front of you its not always your fault. weight-shift-control aircraft, airplane, or rotorcraft. (3) An airship has the right-of-way over a powered parachute, weight-shift-control aircraft, airplane, or rotorcraft.] However, an aircraft towing or refueling other aircraft has the right-of-way over all other engine-driven aircraft. |
Ron Natalie wrote:
If you flew a glider into another aircraft from behind it would be at fault. The overtaking rules do not have an exemption for class. I think your second sentence is correct, and that you mis-stated the first. You would be at fault, not the powered plane you hit. -- Alex -- Replace "nospam" with "mail" to reply by email. Checked infrequently. |
alexy wrote:
Ron Natalie wrote: If you flew a glider into another aircraft from behind it would be at fault. The overtaking rules do not have an exemption for class. I think your second sentence is correct, and that you mis-stated the first. You would be at fault, not the powered plane you hit. Yes, that is what I meant. |
Ron Natalie wrote:
Because the rule is that ALL powered aircraft ALWAYS give way to ALL gliders and, in uncontrolled airspace, There is NO SUCH RULE. Well, there is in every country that adheres to the ICAO treaties and annexes and you'd better believe it if you ever fly outside the US. I know the US is the most non-compliant signatory but I'd be surprised if these fundamental rules don't apply in the US. They certainly apply to every US aircraft flying internationally. I could of course be wrong - I make a habit of it. ![]() All aircraft are required to see and avoid regardless of the right of way rules. Absolutely. But when they collide in spite of this, the powered aircraft is prima facie at fault. If you flew a glider into another aircraft from behind it would be at fault. The overtaking rules do not have an exemption for class. I'll stick to what I said. 1. In VMC, ALL aircraft are required to maintain a lookout so as to see and avoid ALL other aircraft. 2. When on converging courses, powered aircraft are required to give way to gliders. Powered aircraft give way to airships who give way to gliders who give way to balloons. There is, of course, a lot more to it than this but this is where the lawyers, insurance companies - and probably the FAA unless you're right - will start. GC |
"Graeme Cant" gcantinter@tnodedotnet wrote in message ... Kingfish wrote: Don't you have to *see* the other aircraft before you can give way? As has been mentioned by other posters in this thread, if the glider didn't have a transponder the jet's TCAS wouldn't have seen it, and the glider's profile might make it hard to spot. Why do you automatically assume the Hawker pilot is at fault? Because the rule is that ALL powered aircraft ALWAYS give way to ALL gliders and, in uncontrolled airspace, they do this by seeing the other aircraft and avoiding it. Not by squawking. Prima facie, the powered aircraft is at fault. How could the powered aircraft be at fault if the glider hit him from the side. There is no way to know who is at fault. If you cant see it you cant avoid it. I think the glider will end up at fault. Like when I hit another car from behind, prima facie it's my fault. Not always. GC |
Aluckyguess wrote:
How could the powered aircraft be at fault if the glider hit him from the side. 1. I love the concept of a 300kg, 60kt glider "hitting" a 10,000kg, 300kt bizjet - especially from the side! You'll notice in the photos that the glider's spar joiner is lodged in the radome, not the side window. It's physically impossible for a 60kt anything to hit a 300kt anything from the side. 2. Because he failed to see and avoid the glider. ALL aircraft in VMC are required to see and avoid other aircraft and they avoid them by following the right of way rules - the powered aircraft alters course to avoid the glider. There is no way to know who is at fault. That's true for you and me. But the courts and the insurance companies and the FAA will certainly find a way no matter how hard it is. They tend to work at these things more persistently than you and I do. If you cant see it you cant avoid it. I think the glider will end up at fault. You can see and avoid anything if you go slowly and carefully enough. Yes, I know that's not how powered aircraft are generally operated but the law says that's how they SHOULD be operated. It's no excuse to hitting a guy on a bike that you were in a big car travelling very fast even if you were under the speed limit. Like when I hit another car from behind, prima facie it's my fault. Not always. ALWAYS, prima facie. GC GC |
("Graeme Cant" wrote)
That's true for you and me. But the courts and the insurance companies and the FAA will certainly find a way no matter how hard it is. They tend to work at these things more persistently than you and I do. "Insurance companies are the most religious people in America - everything is an act of God." The 'big sky' (at 16,000 ft.) wasn't big enough. No fault to either pilot. (Under 12,000 ft. is a different matter, in my book) "Next case." Montblack |
| Thread Tools | |
| Display Modes | |
| Hawker vs. Glider Midair - with photo! | Darkwing | Piloting | 151 | September 5th 06 06:19 PM |
| Air Force One Had to Intercept Some Inadvertent Flyers / How? | Rick Umali | Piloting | 29 | February 15th 06 05:40 AM |
| NTSB: USAF included? | Larry Dighera | Piloting | 10 | September 11th 05 11:33 AM |
| Bad publicity | David Starer | Soaring | 18 | March 8th 04 04:57 PM |
| "I Want To FLY!"-(Youth) My store to raise funds for flying lessons | Curtl33 | General Aviation | 7 | January 10th 04 12:35 AM |
