Class B VFR
Old August 31st 06, 05:32 PM posted to rec.aviation.piloting
Matt Whiting
Default Class B VFR
I'm hoping to make my long VFR cross-country for my commercial license
this afternoon and evening (to get both day and night into one flight).
I'm tentatively planning to fly into CAK which is class bravo
airspace. As I was planning the flight today, I realized that I haven't
flown VFR into class B in I can't remember when. I've flow IFR almost
exclusively since getting the rating 14 years ago.
I know that clearance is required to enter class B, but IFR this was
taken care of. I assume that the approach controllers routinely issue
this clearance when your destination is field in their area, but I
wanted to be sure. My plan is to request the clearance if I have
received it prior to entering class B, but I'm wondering what the SOP is
these days for VFR into class B.
Matt
Old August 31st 06, 05:47 PM posted to rec.aviation.piloting
Jim Burns[_1_]
Default Class B VFR
If you are on a VFR flight following, you'll be transferred just as IFR and
should be issued a clearance before entering OR you may be told not to enter
Class B airspace. If you do not use flight following, it's the same as
entering class C airspace... listen to ATIS, call up on the correct
frequency before entering and tell them what you want to do. Listen for the
clearance and your N number as positive identification. Shouldn't be a
problem.
"Matt Whiting" wrote in message
Matt
Old August 31st 06, 05:54 PM posted to rec.aviation.piloting
pgbnh
Default Class B VFR
Not sure I would take the chance of waiting for, or assuming a clearance
into the B. It is YOUR responsibility to get it, not theirs to give it to
you. At an appropriate distance from the Class B make the request, including
the altitude and route you intend to transit the B at.
"Jim Burns" wrote in message
and
enter
problem.
Matt
Old August 31st 06, 07:47 PM posted to rec.aviation.piloting
Matt Whiting
Default Class B VFR
problem.
Yes, I'll utilize flight following. I wasn't sure if a clearance would
be explicitly given as part of the hand-off or if the hand-off itself
was sufficient. The AIM didn't seem to me to be completely clear on
this. I suspect an explicit clearance needs to be given, but wanted to
be sure.
Matt
Old August 31st 06, 07:57 PM posted to rec.aviation.piloting
Jim Burns[_1_]
Default Class B VFR
A simple hand off will not be sufficient. You most likely will not get the
clearance when handed off to the local approach control, remember they
control airspace well outside the Class B, but the same controller may be
working the outer ring of the Class B so don't assume just because you're
talking to the same controller that all is well and you can continue. Don't
enter the Class B without the clearance. You must receive the clearance and
as other's have said, you may wish to be proactive in obtaining the
clearance.
Old August 31st 06, 08:33 PM posted to rec.aviation.piloting
Jose[_1_]
Default Class B VFR
Don't enter the Class B without the clearance.
Let me amplify this a bit. Within the Bravo, cloud clearance
requirements are "clear of clouds". This requires positive control - an
IFR popping out of the clouds has no time to see a VFR who might be just
outside them.
Jose
The monkey turns the crank and thinks he's making the music.
Old August 31st 06, 09:56 PM posted to rec.aviation.piloting
Steven P. McNicoll[_1_]
Default Class B VFR
"Jose" wrote in message
news
Let me amplify this a bit. Within the Bravo, cloud clearance requirements
are "clear of clouds". This requires positive control - an IFR popping
out of the clouds has no time to see a VFR who might be just outside them.
True, so why doesn't Class C airspace have the same cloud clearance
requirement?
Old September 1st 06, 05:56 PM posted to rec.aviation.piloting
Chris G.
Default Class B VFR
Here is what I do with a Class B airspace clearance:
I asked for it. I will not enter the airspace unless I hear, "N12345,
You are cleared into the Class Bravo" AND I then repeat "N12345 Cleared
into the Class Bravo. Thank you."
It's a couple extra words and may take an extra second, but the benefit
severely outweighs the risks.
Chris
clearance.
Old August 31st 06, 10:46 PM posted to rec.aviation.piloting
Jim Macklin
Default Class B VFR
Just to cover yourself, even when getting radar service, you
should request the Class clearance and be sure you hear
"cleared to enter Class B, with an altitude assignment"
being radar vectors does not constitute a clearance.
it's the same as
the correct
do. Listen for the
Shouldn't be a
| problem.
clearance would
hand-off itself
completely clear on
but wanted to
| be sure.
| Matt
Old August 31st 06, 06:18 PM posted to rec.aviation.piloting
john smith
Default Class B VFR
Is KCAK CBAS?
Better check your charts and AFD.
You may want to restate your question after looking up the appropriate
information. :-))
SPORTS CLASS/CLUB CLASS 5 ugly Soaring 0 July 2nd 06 11:14 PM
Carrying flight gear on the airlines Peter MacPherson Piloting 20 November 25th 04 12:29 AM
