NTSB prelim report out
Old September 10th 06, 02:54 AM posted to rec.aviation.soaring
Paul Buchanan
Default NTSB prelim report out
I have a question which the report doesn't clarify.
What type of airspace was the glider and bizjet flying
in at the time?
Controlled or VFR?
Paul Buchanan
http://www.glidingstuff.co.nz
Old September 10th 06, 03:31 AM posted to rec.aviation.soaring
Nyal Williams
Are you sure this is a possible reading? I would have
guessed that the aircraft could not be flown other
than with a ferrying permit to an inspection site.
At 20:48 09 September 2006, Doug Haluza wrote:
No, but the rules do require that the transponder must
have been tested
every 24 months, and cannot be operated unless it has.
So if it is
installed but not tested then it must be off.
Now, if you did not know the current status of the
test, you would be
in a tough spot. I would suggest that from a regulatory
standpoint the
most prudent thing to do would be to leave it off,
but from a safety
standpoint, it would probably be better if it was on.
A good lawyer
could probably argue either position.
I want to build the most EVIL plane EVER !!! Eliot Coweye Home Built 237 February 13th 06 03:55 AM
18 Oct 2005 - Today’s Military, Veteran, War and National Security News Otis Willie Naval Aviation 0 October 19th 05 02:19 AM
12 Dec 2003 - Today’s Military, Veteran, War and National Security News Otis Willie Naval Aviation 0 December 12th 03 11:01 PM
