OK, FAR Lawers we need your help!
Old August 29th 04, 03:46 PM
john smith
Consider this:
Lateral error limits for an ILS approach are +/- 60 feet.
This is 0.01 degrees (1 degree=6000 feet, 0.1 degree=600 feet)
Granted, most of us only see +/- 15 feet with our GPS's, but WAAS/LAAS
are suppose to guarantee the tolerance.
  #32
Old August 29th 04, 04:27 PM
john smith wrote:
Consider this:
Where did you come up with that?
  #34
Old August 29th 04, 09:16 PM
john smith wrote:
An FAA rep at a conference on LORAN approaches in 1985.
Well, he was full of it. Check the AIM for the LOC sensitivity and check
the TERPS chapter for ILS for the protected airspace.
  #36
Old August 29th 04, 10:51 PM
Mike Rapoport
What does this have to do with the discussion at hand?
MU-2
"john smith" wrote in message
check
Okay, I just took the dog for a walk and was pondering the subject.
To clarify...
An ILS is an "angled" approach, that is, each dot represents 2-degrees
of angle from the centerline. This is a converging cone.
A GPS approach (or LORAN) is a "parallel" approach. Each dot on the
display represents a line parallel to the centerline.
For example, a Garmin 430...
Outside 30 nm from the destination, the sensitivity is 5 nm per dot.
Inside 30 nm from the destination, the sensitivity changes to 1 nm per
dot.
Two miles from the final approach fix in the approach mode, the
sensitivity changes to 0.3 nm per dot. This is 1800 feet, hence the
reason the approach is a non-precision approach. This is also the
minimum runway separation for parallel approachs on ILS's at many
airports. (I believe this has been increased to 2400 feet.) See the
problem?
I probably should have said +/-60 feet for an ILS equivalent approach.
The discussion at that time was about how many decimal places a box need
to have and charts need to have printed.
I apologize for leaving out "details", you have to think about the
equipment and how it works.
  #37
Old August 29th 04, 10:54 PM
Bob Noel
In article , john smith
the +/-60 feet is approximately the tolerance for the ILS ground
system at the threshold. It would not include the tolerance for
the avionics nor the FTE.
Bob Noel
Seen on Kerry's campaign airplane: "the real deal"
oh yeah baby.
  #38
Old August 29th 04, 11:07 PM
john smith
It's just a twist it took based on a previous comment. :-)
  #39
Old August 29th 04, 11:08 PM
john smith
What is FTE?
(The only other usage I have seen for that acronym is Full Time Employee.)
  #40
Old August 30th 04, 12:51 AM
John R. Copeland
"john smith" wrote in message =
=20
=20
Inside 30 nm from the destination, the sensitivity changes to 1 nm per =
dot.
Two miles from the final approach fix in the approach mode, the=20
sensitivity changes to 0.3 nm per dot.=20
You must have confused full-scale sensitivity with "per dot" =
sensitivity.
Your numbers are wildly excessive, compared to my CNX80.
I could pull up the Garmin Simulator to check the 430, but so could you.
Let us know if the 430 really has that rotten sensitivity you mentioned.
---JRC---
