You are kidding, of course? You are marking a line 40 mils wide and
expecting a piece to come out to 20 mils or better accuracy? Jim "DonMorrisey" wrote in message ups.com... At the risk of beating this subject to death, use a sharpie, however a Fine Point Sharpie is too thick. An Ultra-Fine Point Sharpie makes a line approx 1 MM in width. Don... |
("RST Engineering" wrote)
You are kidding, of course? You are marking a line 40 mils wide and expecting a piece to come out to 20 mils or better accuracy? If the line were 20 mils thick, where would you cut? The middle of the line? The edge of the line? But yes, a thin line is nicer. Montblack "Good enough. No one in the front row will ever notice it." Theater set construction motto! g |
![]() "Montblack" wrote in message ... ("RST Engineering" wrote) You are kidding, of course? You are marking a line 40 mils wide and expecting a piece to come out to 20 mils or better accuracy? If the line were 20 mils thick, where would you cut? The middle of the line? The edge of the line? But yes, a thin line is nicer. When I started building I made up my on rule so I'd know which side to cut. I always cut on the left edge of the mark. My reasoning is because I'm right handed I will be holding the straight edge with my left hand and marking with my right. With a very few exceptions this rule has served me well. If I think there will be a question I put a little on the right(as opposed to left) side. |
RST Engineering wrote:
You are kidding, of course? You are marking a line 40 mils wide and expecting a piece to come out to 20 mils or better accuracy? Jim "DonMorrisey" wrote in message ups.com... At the risk of beating this subject to death, use a sharpie, however a Fine Point Sharpie is too thick. An Ultra-Fine Point Sharpie makes a line approx 1 MM in width. Don... And if you could put the bend within 10 mils of where you intended every time, would anyone care? If the designer calls for that amount of accuracy in anything other than bearings, it's time to find a new designer. I was told by a old-time sheet metal worker that unless the plans state otherwise, standard accuracy requirements are 1/32". That's plus or minus .03125 in either direction for a .0625" window. On parts that I do want to cut straight because I want them to be pretty, I mark with a sharpie against a metal ruler, then aim for the side of the line. The metal ruler limits where the sponge on the tip of the marker can go. |
![]() "Ernest Christley" wrote in message m... RST Engineering wrote: You are kidding, of course? You are marking a line 40 mils wide and expecting a piece to come out to 20 mils or better accuracy? Jim And if you could put the bend within 10 mils of where you intended every time, would anyone care? I care very much. If you got a chassis from me and it had 20 mil gaps in the corners, you'd think I was the sloppiest designer in the world. All my freshman students bend within 10 mils on everything to pass the course. Most of them can hold 5 if they try. If the designer calls for that amount of accuracy in anything other than bearings, it's time to find a new designer. I *BEG* your pardon? In my part of the world, 0.0 is within 50 mils, 0.00 within 20 mils and 0.000 within 5 mils. Jim |
"Ernest Christley" wrote in message And if you could put the bend within 10 mils of where you intended every time, would anyone care? I care very much. If you got a chassis from me and it had 20 mil gaps in the corners, you'd think I was the sloppiest designer in the world. All my freshman students bend within 10 mils on everything to pass the course. Most of them can hold 5 if they try. Oh, no. Now you done gone and did it. First, I need to make sure we're talking apples to apples. A mil is 1/1000th inch. Consulted http://www.onlineconversion.com/length_all.htm just to make sure. 1 mil = 0.001 inch [international, U.S.] I have here in my hot little hands (queue paper rattling for the ditto heads) one gen-you-wine "RST-443 Panel Mount Intercom", the serial number being 1014, which went together perfectly and works wonderfully. I LIKE it, and you can't have it back. Starting at the front right corner and proceeding counter-clockwise, the gaps in the bends on the lower half of the chasis measure .020, .030, .032, .035. The bends in the upper half required a different technique. The edge of an envelope fit loosely in the gap of the rear corner bends, the envelope measuring ..010. We must be talking different measurements; either that, or I have extremely low expectations and you're headed out to chew some hides in your quality control department. 'Cause, I think this box is tighter than a cheerleaders butt. If the designer calls for that amount of accuracy in anything other than bearings, it's time to find a new designer. I *BEG* your pardon? In my part of the world, 0.0 is within 50 mils, 0.00 within 20 mils and 0.000 within 5 mils. I have only a couple measurements on my set of plans that call for a specific tolerance. One is for the pins locking the gear leg halves together. The other is for the wing lock pin. The rest are just measurements with the smallest being with 1/16". Everything broken down into feet, inches and fractional inches. But no "plus or minus" anywhere. So I asked a recently retired machine shopman and sheetmetal worker, because, heh, if you can't trust somebody that's been doing it 40yrs, who can you trust? He told me 1/32" if not specified. Does the difference come down to how the numbers are specified? Fractional inches resolve to 1/32, and decimal inches have the tolerances you state? |
Wire marking | Scott Vetter | Restoration | 1 | December 1st 04 03:23 AM |
