Darrell S schrieb:
That said, most aircraft require a pilot input of rudder to coordinate a roll input. Little, if any, rudder is required once the roll stops and a constant bank is maintained. Ever flown a glider? You'd be surprized! A coordinated turn is *always* a turn around all three axis. If some powered airplanes don't require rudder, it's because a) the rudder is somehow coupled to the ailerons, b) the weight of the engine will cause the nose to drop enough without rudder or c) the pilot doesn't care enough about being coordinated. My experience says that power-only pilots tend to solution c). (Note: The ball is a pretty coarse instrument.) Stefan |
Darrell S schrieb:
That said, most aircraft require a pilot input of rudder to coordinate a roll input. Little, if any, rudder is required once the roll stops and a constant bank is maintained. Ever flown a glider? You'd be surprized! A coordinated turn is *always* a turn around all three axis. If some powered airplanes don't require rudder, it's because a) the rudder is somehow coupled to the ailerons, b) the weight of the engine will cause the nose to drop enough without rudder or c) the pilot doesn't care enough about being coordinated. My experience says that power-only pilots tend to solution c). (Note: The ball is a pretty coarse instrument.) Stefan I've only had one introductory flight in a glider and that was more than 20 years ago in a two place Blanick. The most memorable thing, aside from being about the most fun a person can have in daylight, is that turn cooridination is much more than rolling in and rolling out. Due to the combination of slow forward speed (when spiralling at minimum rate of descent) and long wing span, the wing toward the inside of the turn is much closer to the stall and a noticeable amount of cross control is required. Typically, powered aircraft are rarely flown in that portion of the flight envelope and many pilots regard turns at low airspeed as extremely dangerous and an invitation to an unintentional spin. Most of us were taught that the low end of the airspeed envelope is hazardous and to be avoided in flight, with the result that very few powered airplane pilots maintain proficiency in very slow flight. Also, since the wings are short and the stall speeds are generally higher, I doubt that the effect is ever really noticeable. As to "c", the yaw string is a lor more sensitive, but takes a little more practice than I was able to give it--since the doggoned thing works backward! Peter Just my $0.02 |
"Peter Dohm" wrote in message
... Most of us were taught that the low end of the airspeed envelope is hazardous and to be avoided in flight, with the result that very few powered airplane pilots maintain proficiency in very slow flight. Probably true, but (as with everything else in the PP PTS) we're taught that we *should* practice slow flight (just above stall speed) on occasion (if for no other reason than to be able to recognize and properly respond to very low airspeed should we inadvertently find ourselves in that situation during normal flight). --Gary |
low end of the airspeed envelope is hazardous and to be avoided in flight, with the result that very few powered airplane pilots maintain proficiency in very slow flight. Probably true, but (as with everything else in the PP PTS) we're taught that we *should* practice slow flight (just above stall speed) on occasion (if for no other reason than to be able to recognize and properly respond to very low airspeed should we inadvertently find ourselves in that situation during normal flight). --Gary Hangar flying is not statistically usefull, but annecdotal evidence suggests that more of us *should* practice slow flight, including turns and configuration changes, at a safe altitude. However, you're right and I was wrong to imply a statistic that can't be documented. Peter |
"Darrell S" wrote in message
news:60eQg.26$rS.9@fed1read05... That said, most aircraft require a pilot input of rudder to coordinate a roll input. Little, if any, rudder is required once the roll stops and a constant bank is maintained. Without rudder input, the yaw required to change the heading of the aircraft (as its flight path progresses around the turn) must come from the aircraft being in a slip. In an aircraft at high speed and/or with high directional stability, the yaw rate required is low and the slip angle required is small, almost unoticeable. The ball will be almost centered In an aircraft at low speed and/or with low directional stability, the yaw rate required is high and the slip angle required is therefore large. The ball will be way off to the side. Thus glider pilots learn to use their feet rather more than fast jet pilots. Julian |
On 2006-09-19, Mxsmanic wrote:
Is it always necessary to use the rudder to execute a coordinated turn? It depends on the aircraft. In something like a Piper Arrow, virtually no rudder is required for the kind of gentle turns you might do when flying IFR - you can practically fly it with your feet on the floor. At the other extreme is something like most gliders which need significant rudder input when initiating a turn. Somewhere in between are aircraft such as the Cessna 140, which needs some rudder when initiating any turn, but not boot loads of rudder. -- Yes, the Reply-To email address is valid. Oolite-Linux: an Elite tribute: http://oolite-linux.berlios.de |
| Thread Tools | |
| Display Modes | |
| AOPA Stall/Spin Study -- Stowell's Review (8,000 words) | Rich Stowell | Aerobatics | 28 | January 2nd 09 03:26 PM |
| Why is ADF or Radar Required on MFD ILS RWY 32 Approach Plate? | S. Ramirez | Instrument Flight Rules | 17 | April 2nd 04 12:13 PM |
| 1-34 Rudder | DGRTEK | Soaring | 23 | February 16th 04 05:36 AM |
| PC flight simulators | Bjørnar Bolsøy | Military Aviation | 178 | December 14th 03 01:14 PM |
| USAF = US Amphetamine Fools | RT | Military Aviation | 104 | September 25th 03 04:17 PM |
