why is intercept altitude labeled "LOC only"?
Old September 22nd 06, 02:44 AM posted to rec.aviation.ifr
Gary Drescher
Default why is intercept altitude labeled "LOC only"?
In the NACO plate for ASH ILS 14, the GS intercept altitude (1800') is
labeled "LOC only". How can a GS intercept altitude apply to the LOC
approach and not to the ILS approach? Is this a charting error?
http://www.naco.faa.gov/d-tpp/0610/05036I14.PDF
--Gary
Old September 22nd 06, 03:42 AM posted to rec.aviation.ifr
John R. Copeland
"Gary Drescher" wrote in message ...
--Gary
Maybe a little ambiguous, instead of a full-blown error.
The note applies to the "1800 ft", not to the glide-slope intercept.
Jeppesen clearly shows 1800 ft to the marker for the LOC approach,
whereas the ILS intercepts the glide path well outside the marker.
Without GS, you won't go below 1800 ft until reaching the marker.
Old September 22nd 06, 04:19 AM posted to rec.aviation.ifr
Gary Drescher
"John R. Copeland" wrote in message
But on the NACO plate, 1800' *is* the glide slope intercept altitude (it's
so designated by the zig-zag arrow from the "1800" to the intercept point).
Right, but if NACO wants to say "LOC only" it should be for a separate
specification of 1800', not for the (sole) one that's designated as the
intercept altitude. For example, in SWF ILS 9, there's a 2100' intercept
altitude, and separately from that there's a minimum altitude of 2100'
specified for the approach segment leading up to the OM; the latter altitude
is marked "LOC only".
http://www.naco.faa.gov/d-tpp/0610/00450I9.PDF
So the SWF chart seems right, but not the ASH chart.
--Gary
Old September 22nd 06, 10:32 PM posted to rec.aviation.ifr
Sam Spade
--Gary
That chart is wrong, too.
Old September 23rd 06, 12:42 PM posted to rec.aviation.ifr
Gary Drescher
"Sam Spade" wrote in message
altitude is marked "LOC only".
Ok, but at the SWF chart makes sense. It's wrong only in that the extra,
LOC-only altitude is superfluous.
--Gary
Old September 23rd 06, 01:23 PM posted to rec.aviation.ifr
Sam Spade
--Gary
Why does it make sense?
Old September 23rd 06, 01:12 PM posted to rec.aviation.ifr
Gary Drescher
Ok, but at least the SWF chart makes sense. It's wrong only in that the
extra, LOC-only altitude is superfluous.
--Gary
Old September 23rd 06, 03:26 AM posted to rec.aviation.ifr
JPH
--Gary
You're correct.
It appears that at the last time the procedures had a major revision,
the criteria in effect at the time (FAAO 8260.19 previous amendment)
required both the GS INTCP altitude AND the LOC altitude to be
published, even if they were the same altitude (one for GS INTCP and
another for LOC ONLY). The SWF chart is correct for that time period.
The ASH chart had both altitudes listed on the form that was submitted
for publication, but they were incorrectly combined on the plate into
one altitude entry, instead of 2 separate altitude entries, which could
be confusing. (The SWF altitudes don't cause the same confusion since
both altitudes are depicted). Since both altitudes are not depicted on
the ASH chart, there will be a NOTAM next week to remove the annotation
"* LOC ONLY". This will put it in compliance with the newer criteria
that only calls for 2 altitudes when the altitudes differ.
Any newer procedures will only have "LOC ONLY" altitude shown if it
differs from the GS INTCP altitude.
JPH
Old September 23rd 06, 01:29 PM posted to rec.aviation.ifr
Sam Spade
the intercept altitude. For example, in SWF ILS 9, there's a 2100'
intercept altitude, and separately from that there's a minimum
altitude of 2100' specified for the approach segment leading up to the
OM; the latter altitude is marked "LOC only".
--Gary
You're correct.
JPH
It never made sense to publish two altitudes when they are both the
same. My recollection was the policy used to be the same as it now is.
There may have been an interim period where it was changed to publish
both, even though they are the same, and now it has been corrected to
what it was for many years.
It is very confusing to have 2100 and 2100, for example.
Old September 23rd 06, 01:47 PM posted to rec.aviation.ifr
Sam Spade
--Gary
You're correct.
JPH
Here is what is said in the original issuance of 8260.19C, dated 9/16/93
( Page 8-11, Paragraph 811 d.):
(1) Fix altitudes established on ILS for LOC-only should be coincident
with the glide slope when possible. Where the stepdown fix altitude is
not within 20 feet of the glide slope, annotate it for LOC use as follows:
MIN ALT CAROL 1600^
*LOC ONLY
This is the same as it reads today, for all practical purposes.
Can you cite the language that changed this for some period between late
1993 and today?
Pressure Altitude and Terminology Icebound Piloting 0 November 27th 04 09:14 PM
GPS Altitude with WAAS Phil Verghese Instrument Flight Rules 42 October 5th 03 12:39 AM
GPS Altitude with WAAS Phil Verghese Piloting 38 October 5th 03 12:39 AM
