Which of these is cheating?
Old October 10th 06, 03:32 AM posted to rec.aviation.piloting
Dana M. Hague
Default Which of these is cheating?
Mxsmanic wrote in
Is maintaining a specific altitude important under VFR, or is it okay
to drift over a broad range? I admit that I don't necessarily see a
compelling reason to fly at 6000 rather than 4000 (or vice versa) in
most cases, or anywhere in between.
For the most part, when flying VFR, it doesn't matter all that much.
However, constantly climbing and descending is inefficient, uses more
fuel, and it's just plain unprofessional. There are indeed situations
where the pilot's ability to precisely hold altitude WILL be
important; if you don't fly that way all the time then how can you
expect to do it when it's *really* necessary?
Most [good] pilots pride themselves in being able to handle their
aircraft efficiently and precisely... which means holding to the
chosen altitude... and also (per another part of this thread) not
turning with just rudder. On your flight simulator you can't feel
it... but in a real plane, if you turn with just the rudder, it plain
feels (and is) sloppy. It's also dangerous... a skidding turn at low
altitudes (often a pilot who's afraid to bank to much at low altitude,
while he's too low and slow on approach) can turn a relatively simple
stall into a spin, which have claimed many lives.
-Dana
If replying by email, please make the obvious changes.
If people behaved like governments, you'd call the cops.
  #32
Old October 10th 06, 06:53 PM posted to rec.aviation.piloting
Mxsmanic
Dana M. Hague d(dash)m(dash)hague(at)comcast(dot)net writes:
I will continue practicing.
All of the aircraft I've tried seem to exhibit phugoid oscillations in
altitude. I guess it's just a matter of knowing exactly how to lead
the oscillations in your control adjustments so that they gradually
cancel out. I'm not sure whether it's better to deal with them by
changing pitch or by changing throttle settings (or perhaps both).
Something I've tried in the sim is watching the horizon out the
window. If it remains on the same straight line throughout a turn,
the turn is coordinated (I think). If it doesn't, I'm doing something
wrong. For slips and skids, the horizon changes position; in a
coordinated turn, the scenery moves parallel to the horizon, but the
horizon itself stays steady.
  #33
Old October 10th 06, 06:54 PM posted to rec.aviation.piloting,rec.aviation.students
Mxsmanic
vincent p. norris writes:
That is the way the U.S. Navy teaches it.
Well, if they can teach pilots to land on a carrier at night in fog,
they probably know what they are talking about.
  #34
Old October 10th 06, 07:14 PM posted to rec.aviation.piloting,rec.aviation.student
Ron Natalie
John Gaquin wrote:
"Mxsmanic" wrote in message
OK, thanks. So this is true in all configurations, or only during
certain phases of flight like an approach?
Very few things are true in all configurations. Every time you want to
change an aircraft's configuration, you are adjusting a fine balance between
pitch and power. Usually, what you're seeking is stability. In general, a
more lasting, stable outcome will be achieved if you think of altitude
change in terms of power, and airspeed change in terms of pitch.
As we say in the software engineering biz: Everything is deeply
intertwingled.
I actually worked with a group of human engineering experts at an
Army lab that designed a fly-by-wire helicopter control which
decoupled all the interactions between the controls (essentially
the collective just made you go up and down, the cyclic translated
you and the pedals spun you). It made the real helicopter pilots
a bit unnerved when they flew it as they were used to putting
in the compensations.
By the way, this intertwingling nature is largely poorly implemented
in PC games.
  #35
Old October 10th 06, 07:17 PM posted to rec.aviation.piloting,rec.aviation.student
Ron Natalie
Mxsmanic wrote:
John Gaquin writes:
When setting up in cruise, do not drive the plane like most people drive a
car. You should start with a preplanned setting in mind: "I am going to
cruise at 2200 rpm and 21 inches". After you attain your altitude and
reduce to this power setting, you would then gradually trim the airplane so
it is flying level at that setting. Your speed will be what it is, plus or
minus a few knots indicated.
Unless you are within 3000 feet of the ground you shouldn't be at
either altitude VFR. Try reading some of the books we recommended
to you.
Generally, if you were a real pilot, you'd be required to demostrate
control to within 100'.
  #36
Ron Natalie
Doug wrote:
IFR standards are approx -+100'. Most of try for -+50'. Not easy at
first. Gets easier after a while. You have to keep glancing at the
altimeter.
VFR standards are +-100' as well.
  #37
Old October 10th 06, 07:18 PM posted to rec.aviation.piloting
Ron Natalie
Mxsmanic wrote:
Doug writes:
altimeter.
Thus far I find it pretty difficult. Phugoid movements and stuff like
that mean that I have to constantly adjust. I'm not sure at what
point it's better to trim or use control movements, but I'm not having
much success either way.
Try flight instruction.
  #38
Old October 10th 06, 07:19 PM posted to rec.aviation.piloting
Ron Natalie
It is also unsafe. The cruise altitude rules can get separation down
to 500'. In addition, altimeters (even if set correctly) might be
off by 75 feet, ... there are a lot of things that add up.
  #39
Old October 10th 06, 07:21 PM posted to rec.aviation.piloting
Ron Natalie
Thomas Borchert wrote:
John,
Power is altitude; pitch is
airspeed.
Hah! Let the religious wars begin.
When taking off, shove the stick forward and when you get to Vr
put in the throttle and climb!
Frankly, I have never quite understood the distinction, same as with "forward" and "side" slips.
That one always confused me too. I'm not sure I remember to this day.
  #40
Old October 10th 06, 07:45 PM posted to rec.aviation.piloting,rec.aviation.student
Mxsmanic
Ron Natalie writes:
in PC games.
Which part is missing?
Cheating the ILS [email protected] Instrument Flight Rules 6 September 3rd 06 04:22 PM
Cheating the Reaper! JJS Piloting 7 July 19th 06 03:34 PM
Blair Manipulated Intelligence to Justify War, says BBC film [email protected] Naval Aviation 4 March 22nd 05 06:45 PM
Date of effect now 1 April 2004 for revised IGC-approval for certain legacy types of GNSS flight recorder Ian Strachan Soaring 56 December 2nd 03 08:08 AM
