wonders of VFR on top
Old October 22nd 04, 10:49 PM
Matt Whiting
Newps wrote:
Matt Whiting wrote:
Robert M. Gary wrote:
Newps wrote in message
If that happens again just ask for a local IFR clearance like you
were going to do practice approaches while IFR. As soon as you get
on top you cancel.
I told him I only needed the clearance for 10 miles until I got on
top. He said he still needed to wait for Oakland center unless I just
wanted a clearance to VFR-on-top.
He then issued me the typical to VFR-OT clearance. Climb maint...if
not on top by...etc.
I've never used an IFR to VFR on top clearance. What are the
subleties of this?
You just ask for an "IFR to VFR on top". This way we know that once in
VFR you will advise us and we will cancel your IFR and you will motor on
as a regular VFR flight.
OK. Although, I assume you could just stay on the IFR flight plan,
though, right? If you plan to cancel, wouldn't asking for IFR to VFR
"over" the top be a more appropriate request? That clearly implies that
you plan to complete the flight under VFR.
Matt
  #32
Old October 22nd 04, 11:23 PM
zatatime
On Fri, 22 Oct 2004 20:36:32 GMT, zatatime
On Fri, 22 Oct 2004 14:03:36 -0600, Newps
I think you're confusing VFR Over the Top with VFR On Top. VFR Over
the top is just like VFR - no IFR flight plan. On Top as I understand
it keeps your IFR flight plan in tact while operating in VFR
conditions. Basically the pilot is bound by both IFR and VFR regs but
must remain VFR.
I need to read up on this more, but this is what I remeber.
z
I now see a difference between a "climb to VFR on top" and a request
for VFR on top while flying an already filed IFR flight. (Reading is
a good thing.)
The Climb to...would call for cancellation once on top since the
flighjt originated VFR and will continue VFR once through the layer.
Receiving a clearance for ...on top while on an IFR flight would not
cancel the already filed IFR flight plan since the flight is to be
conducted under IFR rules (just on top).
I hope I worded this well enough to make sense to someone other than
myself.
z
  #33
Old October 23rd 04, 02:06 AM
Newps
No, I'm not.
VFR Over
Right, but in the case we are discussing you need an IFR clearance to
get to the VFR conditions. That clearance is IFR to VFR on top.
conditions.
Yes but the poster wants a clearance to get thru the clouds and then
cancel IFR altogether. Very common in coastal areas or areas where fog
is common. Rare in other places.
must remain VFR.
Among other rules.
We do a lot of VFR on Top here. They use it as a way to stay low
westbound into the winter winds.
  #34
Old October 23rd 04, 02:10 AM
Newps
though, right?
Sure, you will be given an altitude to maintain if you don't break out.
Here at BIL we just use the top of our airspace, 12,000.
Not technically although it will probably get your point across.
  #35
Old October 23rd 04, 05:25 AM
Howard Nelson
"zatatime" wrote in message
a good thing.)
No. When you get the Clearance you are IFR and bound by all IFR rules. At
our airport (WVI) when we ask for clearance to the SNS VOR stating that it
is for "climb to VFR conditions" we will be able to get that clearance as a
"pop up" clearance since NorCal (Sierra, Monterey ?) approach will keep us
in their airspace. They will expect us to cancel IFR when we break through
the tops. If we want a clearance to our destination and it is outside the
sector then we can expect to wait 15-30mins while the request is processed.
myself.
z
Howard
C182P
Outgoing mail is certified Virus Free.
Checked by AVG anti-virus system (http://www.grisoft.com).
Version: 6.0.778 / Virus Database: 525 - Release Date: 10/15/2004
  #36
Old October 23rd 04, 06:04 AM
zatatime
On Sat, 23 Oct 2004 04:25:21 GMT, "Howard Nelson"
This was for a clearance to a VFR flight in progress wanting a
clearance through a layer and continued flight VFR. Your statements
are true for ground initiation, but this is for somethong already in
progress, therefore the flight will be bound by IFR rules from the
time cleared 'till the time on top.
I was trying to correct a previous statement. This may help sort it
out:
z
  #37
Old October 23rd 04, 03:47 PM
John Clonts
"Howard Nelson" wrote in message
m...
a good thing.)
What are you supposed to do if you don't break out of the clouds, and you lose comm?
  #38
Old October 23rd 04, 03:56 PM
Howard Nelson
"John Clonts" wrote in message
m...
a good thing.)
At
it
as a
us
through
processed.
lose comm?
See earlier posts. Here at WVI I am talking about a summer fog layer with
the tops always below 3000 ft and usually the nearest clouds in afternoon
convective activity over the Sierras 150NM away. As another poster mentioned
this (almost daily) fog from June to Oct. must be somewhat an anomaly. I
jokingly refer to my IFR ticket as my "fog license". The nice thing about
fog is the smooth, predictable tops. The bad thing is the irregular,
unpredictable ceiling.
Howard
  #39
Old October 23rd 04, 04:02 PM
Steven P. McNicoll
lose comm?
Whatever you think is best.
http://www.faa.gov/atpubs/AIM/Chap6/aim0604.html
  #40
Old October 23rd 04, 05:47 PM
Matt Whiting
lose comm?
That brings up the age old question about following procedure vs. using
judgment. For example, if I've just departed ELM for say BOS and lose
comm on climbout, procedure would have me fly to BOS, assuming I don't
encounter VMC along the way. However, if I know that I have minimums or
better at ELM, I'd be inclined to shoot an approach there and get back
on the ground at my home drome and not be in the system for 1.5 hours
and flying into a fairly busy airport NORDO. I'd also think you ATC
folks would rather I do that as well, but I suspect that if anything at
all went wrong while doing this, the FAA would be likely to bust me for
not following the prescribed procedure.
I'm assuming that a successful outcome could be justified using the
"good judgment" clause referenced above, however, it does suggest that
good judgment only comes into play for cases NOT covered by the procedures.
Matt
