Percent power altitude
Old October 26th 06, 03:56 PM posted to rec.aviation.ifr
John R. Copeland
Default Percent power altitude
"Allen" wrote in message .. .
..... I was just
commenting to John that I have never seen RAM recommend any particular EGT,
only the 1650 degree max. I agree with the rest of your post.
Allen
I don't have RAM's newest engines, but their power charts for the RAM
Series II and RAM Series IV TSIO-520NBs had columns showing EGT's.
Typical row entries are "Takeoff (full rich) - 1450F to 1550F",
"Cruise Climb (85%) - 1450F Calibration Setting",
three different types of "Cruise - 1550F" entries,
"Normal Descent - 1300F min, 1400F ideal", and
"Approach and Landing - 1200F min, 1300 ideal".
  #32
Old October 26th 06, 05:01 PM posted to rec.aviation.ifr
Allen[_1_]
"John R. Copeland" wrote in message
..... I was just
EGT,
Allen
You may want to call their customer service and get an updated power card.
The one I have justs shows "1650 degrees maximum" for the cruise entries.
They are letting you determine what you want to run at. I think you are
operating them in the proper way limiting the EGT to 1525 or lower.
Allen
  #33
Old October 26th 06, 05:22 PM posted to rec.aviation.ifr
Jim Macklin
The airframe maker often modifies the engine and
accessories, thus the POH is the authority. STC'd systems
modify that. So, if you and I keep posting sound advice,
perhaps the rest of the group will develop a higher level of
learning.
| "Jim Macklin" wrote
in message
| Not exactly. It depends on whether the gauge is
calibrated
| to an exact temperature or whether the gauge is used
only to
| find relative peak and degrees above and below. It also
| depends on where the probe(s) are installed. EGT has
| probes about 4 inches past the exhaust valves,
| On single-probe EGT systems such as on John's Cessna 340
the probe is
| located toward the tail end of the exhaust riser, well
ahead of the turbo
| but past the 4" point. This was determined (by Cessna) to
be the point
| where the exhaust gas is hottest. Cessna POH for the 340
recommends running
| at peak for many power settings below about 62%. Cessna
designed their own
| exhaust systems on their twins, Beechcraft had TCM design
their exhaust as a
| unit with the engine.
| Allen
  #34
Old October 27th 06, 11:26 PM posted to rec.aviation.ifr
Blanche
Bob Moore wrote:
Bob Noel wrote
Bob Moore wrote:
Works out to 76% at 7,500' and 64% at 12,500', or thereabouts.
OK, I'm confused. Full throttle, 64%, is 12,500' for any engine?
How come my cherokee 140 couldn't even get to 12,500'?
What am I overlooking?
:-) The wing, of course. :-)
Bob Moore
Perhaps you need to pedal faster?
(*chortle*)
Backup Flight Data Recorder? Fox Two Soaring 14 August 27th 06 09:42 AM
The Deaf vs. The Colorblind Bret Ludwig Piloting 17 August 21st 06 02:08 AM
Catastrophic Decompression; Small Place Solo Aviation Piloting 193 January 13th 04 08:52 PM
Change in TAS with constant Power and increasing altitude. Big John Home Built 6 July 13th 03 03:29 PM
