"Morgans" wrote in message
... Clue - Look at fleet size, then adjust for that, and come back with some more meaningful statistics. The fleet size isn't nearly as relevant as total flight hours for the flight over a span of time. And yes, I agree that the data is missing. However, none of you have provided alternate data to support the claim that the Cirrus is actually worse. And at first glance, the total number of Cirrus accidents is MUCH lower than for Cessna accidents, which is exactly what one would expect given the difference in fleet sizes. Clue: when you are making accusations, the burden of proof is on YOU. If you're going to claim that the accident rate is abnormally high, you need to provide data to support that claim. Suggesting that the defense has insufficient data isn't meaningful. Pete |
![]() Morgans wrote: "Peter Duniho" wrote A quick NTSB database search shows in the last six months 4 accidents (2 fatal) involving a Cirrus SR20, and 52 (5 fatal) involving a Cessna 172. The SR22 was involved in 7 accidents (2 fatal), while the Cessna 182 was involved in 36 (6 fatal). Clue - Look at fleet size, then adjust for that, and come back with some more meaningful statistics. How many bazillion C172's are there out there, vs. Cirrus? One thing these figures seem to say is that 50% of SR20 accidents are fatal, but only 10% of 172 accidents are. It is only a bit better if you compare both Cirrus and Cessna types. The parachute should make Cirrus accidents more survivable, not less. John Halpenny |
On 31 Oct 2006 17:28:21 -0800, "John Halpenny"
wrote in .com: One thing these figures seem to say is that 50% of SR20 accidents are fatal, but only 10% of 172 accidents are. It is only a bit better if you compare both Cirrus and Cessna types. The parachute should make Cirrus accidents more survivable, not less. What's the SR20's stall speed compared to the C-172? The kinetic energy expended in a mishap increases exponentially with the square of the velocity. |
"John Halpenny" wrote in message
oups.com... One thing these figures seem to say is that 50% of SR20 accidents are fatal, but only 10% of 172 accidents are. As I pointed out previously, there aren't enough SR20 accidents (or even SR20 and SR22 combined) to make any valid statistical conclusions. The statistical error on the sample size exceeds the number of samples. Pete |
Recently, Peter Duniho posted:
A quick NTSB database search shows in the last six months 4 accidents (2 fatal) involving a Cirrus SR20, and 52 (5 fatal) involving a Cessna 172. The SR22 was involved in 7 accidents (2 fatal), while the Cessna 182 was involved in 36 (6 fatal). One might say that the fatal accident rate seems disproportionate (50% of the SR20, 25% for the SR22 versus 10% for the 172 and 20% for the 182), but at the sample sizes present, there's absolutely no reasonable way to draw any valid statistical conclusion (and note that for the SR22 and the 182, the rates are actually similar). The fact is, none of these airplanes are actually involved in fatal accidents all that often, and the absolute numbers for overall accidents are significantly lower for the Cirrus types than for comparable Cessna types (of course, with a presumably much smaller fleet size, that's to be expected, even without accounting for differences in utilization). Without the total fleet numbers, it is difficult to establish a proportionate accident rate, but there is face validity to the notion that the Cessna accident rate is far lower than Cirrus', given other methods of comparison such as time flown per type or number of TOs & Landings. Looking only at the type of accidents, one may conclude that pilot error is the primary cause for either make of plane. Neil So, it seems to me that before we start throwing around statements like "the problem is with the pilots, not the airplanes", it ought to be established that there *is* a problem in the first place. Pete |
On Fri, 27 Oct 2006 18:26:33 -0400, "Kyle Boatright"
wrote: "john smith" wrote in message ... With the recent spate of Cirrus accidents, the question arises, "Is it time for a special certification review?" Any aircraft has a baseline accident rate. I think the Cirrus has a higher accident rate because a handful of pilots get themselves into a mindset where they are willing to enter conditions they would have not entered without the big round "insurance policy". Often they get away with pushing things. Sometimes they don't, and those accidents are the ones that are taking the Cirrus accident rate to higher than predicted levels. The problem is with the pilots, not the airplanes. I agree. This discussion has come up at least twice a year since the SR-20 and 22 came out. The SR-22 is a capable airplane. It has the BRS for "just in case", it has the weeping wing deice for "just in case". It's not for know icing, but just in case, it has the simple (er) set of engine and prop controls, and it has fixed gear. BUT it has high wing loading. A fair amount higher than most fixed gear pilots are used to and noticeable heavier than a Bo. SR-22 loading is about 23.5 while the Bo is on the order as about the same as a Cherokee at 17.2. The Bo wing loading covers a wide rage from about 16 to 19# per sq ft. It's one whale of a lot slipperier though than the Cherokee though. This is almost 32% heavier loading compared to the Cherokee and the lighter Bonanzas and Debonairs. That is not to be taken lightly and there is no pun intended. Over a 30% change in wing loading is a serious change particularly for low time pilots. I thought I'd take the easy way out and do a quick search instead of calculating a bunch of wing loadings. The first thing that came up was: http://www.aviation-pilots.com/construct/thread41.html Then I noted who did the calculations. Careful what you say as it's sometimes surprising as to where it shows up. :-)) At any rate, the SR-22 has all these whiz bang safety features AND it's fixed gear, but it has the performance of a Bonanza with up to 30% heavier wing loading. The safety features are great, but here we have an airplane that is meant for, or should be meant for experienced pilots used to high performance be it fixed or retract gear. Put all these features in a plane and then put the typical pilot with a fixed gear mentality behind the yoke and it could be a recipe for disaster. I mean no disrespect to fixed gear pilots. The typical fixed gear pilot moving to the SR-22 would be akin to me moving to a TBM-700 or 850 One is a pilot with a 130 MPH mind moving to a 200 MPH airplane while I'd be the pilot with a 200 MPH mind moving to a 360 MPH airplane. OTOH I do have at least a little experience with faster planes with much higher wing loading, but not enough to be safe though. My point is that even with all the training provided and *required* the pilots *appear* "to me" to be flying a 200 MPH high performance airplane as if it were a 130 MPH airplane. As a purely personal opinion, I think they should forget it has a fixed gear and fly it as if it were a retract. Actually I think the retract has an advantage. The SR-22 is slippery with a high wing loading. In a Bonanza if you get into trouble they tell you to put the gear down and forget the doors. When the gear goes down even at pattern speed it feels like some one put the brakes on although the brakes with those tires don't have that much authority on the runway. :-)) Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com |
"Roger (K8RI)" wrote: In a Bonanza if you get into trouble they tell you to put the gear down and forget the doors. When the gear goes down even at pattern speed it feels like some one put the brakes on although the brakes with those tires don't have that much authority on the runway. :-)) The best way to slow a retract down is to put the gear down in the air, and pick it up again in the flare. :-) |
On Sat, 28 Oct 2006 10:06:04 -0400, Roy Smith wrote:
In article , "Roger (K8RI)" wrote: In a Bonanza if you get into trouble they tell you to put the gear down and forget the doors. When the gear goes down even at pattern speed it feels like some one put the brakes on although the brakes with those tires don't have that much authority on the runway. :-)) The best way to slow a retract down is to put the gear down in the air, and pick it up again in the flare. :-) I know it works in the air, but I'd as soon pass on trying the other part:-)) A few years back we had a Mooney come in gear up. He said it collapsed, but I think it collapsed trying to jack the airplane back up:-)) At any rate that plane skidded about 2500 feed down the runway before sliding off into the grass where it quickly stopped. I don't normally use that much runway without ever touching the brakes. BTW it was their first flight after the annual. Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com |
With the recent spate of Cirrus accidents, the question arises, "Is it time for a special certification review?" Absolutely. Spending millions of dollars is justified whenever any idiot whines that there's an issue that can be resolved by political action. Answer your own question. moo |
john smith wrote:
With the recent spate of Cirrus accidents, the question arises, "Is it time for a special certification review?" For an unrelated project, I downloaded the FAA aircraft registration database a couple of weeks ago. (Available at: http://www.faa.gov/licenses_certific...raft_download/ ) I just did a couple of quick queries on it that might help answer the question of what the Cirrus fleet size is. Total Cirrus Design SR-20 entries in the master file: 597 Total Cirrus Design SR-22 entries in the master file: 2022 SR-20 entries in master file, listed by airworthiness date: 39 (blank) 1 1981 1 1997 5 1999 78 2000 46 2001 84 2002 96 2003 78 2004 86 2005 83 2006 If you assume that each aircraft went into service the year of its airworthiness date, you can get the fleet size by year: End Fleet of size 1997 2 1999 7 2000 85 2001 131 2002 215 2003 311 2004 389 2005 475 2006 558 (through early October) SR-22 entries in master file, listed by airworthiness date: 174 (blank) 121 2001 262 2002 304 2003 431 2004 442 2005 288 2006 Fleet size by year: End Fleet of size 2001 121 2002 383 2003 687 2004 1118 2005 1560 2006 1848 (through early October) As a comparison, I did the same queries for the Cessna 172, including the models 172, 172[ABCDEFGHIJKLMNPQRS], 172RG, P172D, R172[EGHJK], T172, and CE-172-R172. Because this covers a much longer period of time, some of the assumptions above are not as likely to be valid. Total Cessna 172 entries in the master file: 26697 Cessna 172 entries in master file, listed by airworthiness date: 1825 (blank) 13 (garbled) 79 1955 780 1956 540 1957 447 1958 517 1959 494 1960 457 1961 448 1962 608 1963 782 1964 901 1965 909 1966 507 1967 765 1968 721 1969 438 1970 463 1971 625 1972 979 1973 1065 1974 1202 1975 1387 1976 1430 1977 1289 1978 1294 1979 880 1980 725 1981 248 1982 163 1983 159 1984 157 1985 97 1986 23 1987 27 1988 41 1989 42 1990 21 1991 38 1992 49 1993 41 1994 48 1995 48 1996 228 1997 344 1998 381 1999 385 2000 295 2001 291 2002 277 2003 216 2004 312 2005 196 2006 Fleet size by year: End Fleet of size 1955 79 1956 859 1957 1399 1958 1846 1959 2363 1960 2857 1961 3314 1962 3762 1963 4370 1964 5152 1965 6053 1966 6962 1967 7469 1968 8234 1969 8955 1970 9393 1971 9856 1972 10481 1973 11460 1974 12525 1975 13727 1976 15114 1977 16544 1978 17833 1979 19127 1980 20007 1981 20732 1982 20980 1983 21143 1984 21302 1985 21459 1986 21556 1987 21579 1988 21606 1989 21647 1990 21689 1991 21710 1992 21748 1993 21797 1994 21838 1995 21886 1996 21934 1997 22162 1998 22506 1999 22887 2000 23272 2001 23567 2002 23858 2003 24135 2004 24351 2005 24663 2006 24859 (through early October) Matt Roberds |
AOPA Stall/Spin Study -- Stowell's Review (8,000 words) | Rich Stowell | Aerobatics | 28 | January 2nd 09 02:26 PM |
Trip report: Cirrus SR-22 demo flight | Jose | Piloting | 13 | September 22nd 06 11:08 PM |
UAV's and TFR's along the Mexico boarder | John Doe | Piloting | 145 | March 31st 06 06:58 PM |
Cirrus SR22 Purchase advice needed. | C J Campbell | Piloting | 122 | May 10th 04 11:30 PM |
AOPA Stall/Spin Study -- Stowell's Review (8,000 words) | Rich Stowell | Piloting | 25 | September 11th 03 01:27 PM |
