Another Botched use of runways
Old October 31st 06, 08:28 PM posted to rec.aviation.ifr
Skunk
Default Another Botched use of runways
Is it me or is the FAA about one incident away from a
disaster worse than Lexington?
http://www.cnn.com/2006/US/10/31/mis....ap/index.html
Notice the number of passengers on board
Now look what happens when you land or take off on the wrong
runway or use a taxi way
You hit **** sometimes
http://www.airdisaster.com/photos/sq006/photo.shtml
Where was ATCT? How can the tower not see a jet is lined up
for a taxiway landing?
I wonder if all the experienced white males over 40 have
been run off from this location also by the Anti-White male
racist FAA???
Old October 31st 06, 08:44 PM posted to rec.aviation.ifr
tscottme
"Skunk" wrote in message
Is it me or is the FAA about one incident away from a disaster worse than
Lexington?
Please explain how someone in the ATC cab, maybe a half-mile away and
off-axis, would be able to tell an aircraft is 100 feet left/right of final?
This is like blaming the mall security guard when someone dings your car
door in the parking lot.
Scott
Old October 31st 06, 09:28 PM posted to rec.aviation.ifr
Steven P. McNicoll[_1_]
"tscottme" wrote in message
final?
He doesn't know. He's an idiot.
Old October 31st 06, 09:47 PM posted to rec.aviation.ifr
Skunk
final?
You are the idiot sir
1. The ILS would be off in the cockpit
2. If the ATCT can't see an aircraft landing incorrectly on
the taxiway what good are they?
3. The pilot(s) should notice
4. The pilots on the ground should notice
5. The BRITE display in the cab should paint a weird picture
of a weird approach on radar
ALL of the above however requires a human being who gives a ****
In todays America nobody is at fault huh?
Just point blame don't accept fault or fix the problem. That
is the long term result of dumbing down and filling ATCT
cabs and the FAA and cockpits with unqualified minorities
and women.
A cluster **** in Air Traffic control
America is on her way marching toward a society like a
Banana Republic. One Politically Correct bite at a time.
Hold on it's going to be a bumpy ride
Go ahead. Shoot me I am the racist messenger. If it makes
you feel better.
Old October 31st 06, 10:11 PM posted to rec.aviation.ifr
Am I? What have I written that you believe to be idiotic?
Can the ILS in the cockpit be seen from the ATCT?
2. If the ATCT can't see an aircraft landing incorrectly on the taxiway
what good are they?
No good at all. And what good are pilots if they can't see the aircraft is
lined up with a taxiway instead of a runway. In the name of aviation safety
we must eliminate ATCTs and pilots.landing incorrectly on
Yes, but you didn't blame the pilots, you blamed the FAA.
What pilots on the ground should notice?
5. The BRITE display in the cab should paint a weird picture of a weird
approach on radar
Why? Have you ever seen BRITE radar? Have you ever been in an ATCT? Have
you been to an airport?
Just point blame don't accept fault or fix the problem. That is the long
term result of dumbing down and filling ATCT cabs and the FAA and cockpits
with unqualified minorities and women.
America is on her way marching toward a society like a Banana Republic.
Go ahead. Shoot me I am the racist messenger. If it makes you feel better.
No, you're not a messenger, you're just an idiot.
Old November 4th 06, 09:06 PM posted to rec.aviation.ifr
Roger (K8RI)
On Tue, 31 Oct 2006 22:11:07 GMT, "Steven P. McNicoll"
snip
The ones who mistakenly pulled out in front of the landing aircraft?
approach on radar
I do have to admit that on one training flight in actual to Pontiac
(PTK) as I was coming down the glide slope fighting a 90 degree cross
wind that seemed to counter every correction the tower did come on
and ask if I planned on landing on the taxiway, or was I going to use
the runway. I replied I was kinda hoping for the big one on the left
with all the marks painted on it if the wind would cooperate. When we
broke out pretty close to DH I was very close to being lined up. I had
to be with as sensitive as those needles get that low. :-))
OTOH that is more than a bit different than trying to see an airplane
100 feet left or right of centerline from the cab.
snip
Certainly a bit...aw...never mind.
www.rogerhalstead.com
Old November 1st 06, 10:40 AM posted to rec.aviation.ifr
Sam Spade
what good are they?
approach on radar
Obviously, you are not an aviation professional or, if you are, you are
incompetent. KEWR Runway 29 does not have a straight-in instrument
approach procedure of any type, much less an ILS.
As they say in court, you are assuming facts not in evidence.
I can understand why they replaced you.
Old November 1st 06, 12:44 PM posted to rec.aviation.ifr
B A R R Y[_2_]
um... The pilot that's flying? G
Old November 1st 06, 04:34 PM posted to rec.aviation.ifr
David Cartwright
Yes, and this is the PF's (Pilot Flying) problem. Only if the controller is
giving the pilot a SAR "talkdown" (very rare) would he be using any system
that allows him to see accurately where the aircraft is relative to the
runway centreline.
what good are they?
Remember the Tower is generally off to the side of the runway - often by
quite a way. Thus, until an aircraft is relatively close to the runway, it's
pretty hard to picture where an aircraft is relative to the centreline.
Yes, they should. Landing in the right place, in the right configuration,
and at the right speed is the job of the pilots.
They _might_ notice, but the priority of the pilots of any aircraft on the
ground is to make their way around the airport safely, down the right routes
and without banging into anything or anybody. Taxying, though apparently
easy, is actually one of the places where plenty of accidents occur through
complacency. And let's face it, if aircraft on the ground were having
accidents because their crew were too busy looking into the sky, you'd be
moaning about that too. It may well be that someone waiting on a taxiway
might have been gazing into the air and thought: "Hang about, his approach
looks a bit weird", but (a) at an airfield with multiple runways the
instinct might be that the landing aircraft is heading into a different
runway. And even if you do choose to say anything, it might take a while to
get a word in edgeways if the frequency is busy.
Errr, no. If a pilot is told which bit of ground to land on, and then lands
on the wrong bit, then it's his (or her) fault. Simple as that. Go surf the
NTSB incident report archive and you'll find plenty of reports where blame
is attributed - to engineers, to controllers, to pilots, to wherever it's
due.
DC
Old October 31st 06, 08:49 PM posted to rec.aviation.ifr
Gary Drescher
I wonder if all the experienced white males over 40 have been run off from
this location also by the Anti-White male racist FAA???
Your sentence, as you've punctuated it, is asking us if that's what you
wonder. So I suppose the answer is: yes, given your tediously obsessive
bigotry, you probably do wonder that.
Runway ID Lakeview Bill Piloting 55 October 18th 05 12:53 AM
Disappearing Runways Kyle Boatright Piloting 5 May 26th 05 03:19 AM
Winds on long runways Casey Wilson Piloting 15 July 17th 04 08:35 AM
Extreme Runways JohnMcGrew Piloting 9 October 25th 03 02:57 PM
fs2002 - increase intensity taxiway and runways' lights? Mark Cherry Simulators 0 September 23rd 03 01:08 AM
