#31
Steven P. McNicoll wrote:
While "cancel previous approach clearance" is probably a good idea for clarity, it is not required. What instructions/clearances can ATC issue to a flight after issuing an approach clearance which wouldn't automatically cancel the approach clearance? Some instructions obviously don't: "Contact tower 123.45", for example. I would think that any instruction which included an altitude restriction, or a heading/route to fly, would. Any other cases which I haven't thought of? |
#32
![]() "Peter R." wrote in message ... KP (nospam@please) wrote: What class of airspace were you in? Class E airspace making a GPS approach while VFR into a class C airport (we were still several miles outside the class C ring). If Class B or C the answer is probably "Yes, he should have cancelled approach clearance to be 'book correct." But maybe he decided ensuring separation was a higher priority task. Or has the view that if he told you to maintain 3000 it should be obvious to you you're no longer authorized descend on the approach (not saying it is; saying he thinks it should be -/ ) . The other issue that prompted my confusion was the controller change. One controller cleared me, the next issued an altitude restriction. Was the second's altitude restriction due in part to the fact that he was not familiar with the GPS approach? http://www.myairplane.com/databases/.../00411RY15.PDF On the chart above, we were still outside of PAGER, approaching from the east, when this occurred. The approach required at least another 5 miles west at 3,000, then 12 more southwest-bound at 3,000 before descending - with strong headwinds that day I had at least another thirteen minutes at 3,000 without the altitude restriction. The other VFR aircraft was 500 feet below us crossing our path at a 90 degree right to left direction and was well south of us a minute or so after the restriction. This is getting flaky. The controller used 500' vertical separation so it is logical to conclude that one of the concerned aircraft was VFR and the other IFR. Since the other aircraft was below your altitude and in an area where it's stated 2500' altitude appears to be below the minimum altitude for IFR operations I assumed you were IFR and the other aircraft was VFR. Do you know if the other aircraft was IFR or VFR? If he was IFR, do you know if he was on another approach? If you were both VFR no separation was required, just traffic advisories. |
#33
Steven P. McNicoll ) wrote:
If you were both VFR no separation was required, just traffic advisories. We were both VFR. -- Peter |
#34
![]() "KP" nospam@please wrote in message ... VFR aircraft making practice approaches are supposed to be provided standard IFR separation from the time clearance is issued until the MAP. Only if the aircraft is a heavy or a Boeing 757. However, sometimes full IFR separation not worth the effort so there are provisions to let VFR aircraft do the approaches pure VFR with no separation provided. The phraseology for that is "Practice approach approved..." See FAAO 7110.65 4-8-11a(3) Actually, it's the other way around. VFR aircraft practicing approaches are provided separation where procedures are established for it. Where no procedures have been established no separation is provided. |
#35
![]() "Peter R." wrote in message ... Steven P. McNicoll ) wrote: A little more information would be helpful. From your description it appears you were enroute to ELESE from PAGER, is that correct? Do you know if the VFR aircraft was also inbound to SYR? Here's the chart, Steven: http://204.108.4.16/d-tpp/0412/00411RY15.PDF I was actually 5 miles east of PAGER, heading west towards that waypoint. The other VFR aircraft was southbound direct to SYR airport and crossing at 500 feet below us. In hindsight and with the help of the more respectable answers previously, I see now that there really was no reason for me to get concerned about the altitude restriction, especially given the fact that I still had 13 more minutes there. Make no mistake that I had no problem adhering to the instruction, but I was simply curious about the wording in which it was given. It appears there was also no need for the altitude restriction at all. The procedure didn't allow a descent below 3000' until ELESE anyway, so the restriction was superfluous even if you had been IFR. Since you were both VFR there was no need for the restriction since no VFR/VFR separation is provided in that airspace. |
#36
![]() "Roy Smith" wrote in message ... Steven P. McNicoll wrote: While "cancel previous approach clearance" is probably a good idea for clarity, it is not required. What instructions/clearances can ATC issue to a flight after issuing an approach clearance which wouldn't automatically cancel the approach clearance? Some instructions obviously don't: "Contact tower 123.45", for example. I would think that any instruction which included an altitude restriction, or a heading/route to fly, would. Any other cases which I haven't thought of? Speed restrictions. An altitude restriction can also be issued that wouldn't prevent the completion of the approach. For example, let's say an aircraft was issued clearance for the approach under discussion here with "cross PAGER at or above 3000, cleared RNAV RWY 15 approach." Then a VFR aircraft east of PAGER requests an IFR popup, so the aircraft on the approach is instructed to cross PAGER at or above 4000. 3000 feet is now available for the popup clearance, and the arrival aircraft can still complete it's approach. |
#37
![]() "Peter R." wrote in message ... Steven P. McNicoll ) wrote: If you were both VFR no separation was required, just traffic advisories. We were both VFR. Then the controller erred when he told you to maintain 3000. |
#38
"Roy Smith" wrote in message ... Steven P. McNicoll wrote: While "cancel previous approach clearance" is probably a good idea for clarity, it is not required. What instructions/clearances can ATC issue to a flight after issuing an approach clearance which wouldn't automatically cancel the approach clearance? Some instructions obviously don't: "Contact tower 123.45", for example. I would think that any instruction which included an altitude restriction, or a heading/route to fly, would. Any other cases which I haven't thought of? Speed restrictions. An altitude restriction can also be issued that wouldn't prevent the completion of the approach. For example, let's say an aircraft was issued clearance for the approach under discussion here with "cross PAGER at or above 3000, cleared RNAV RWY 15 approach." Then a VFR aircraft east of PAGER requests an IFR popup, so the aircraft on the approach is instructed to cross PAGER at or above 4000. 3000 feet is now available for the popup clearance, and the arrival aircraft can still complete it's approach. But, how do I tell, just from what the controller says, if it will prevent the completion of the approach or not? It seems reasonable in the scenario under discussion, that "cross PAGAR at or above 4000" should not be a problem. But what about "Cross ELESE at or above 4000", or "Cross NADSY at or above 4000", or "Cross PAGER at or above 15,000"? Do any of those imply "cancel previous approach clearance?" |
#39
![]() "Roy Smith" wrote in message ... Steven P. McNicoll wrote: "Roy Smith" wrote in message ... Steven P. McNicoll wrote: While "cancel previous approach clearance" is probably a good idea for clarity, it is not required. What instructions/clearances can ATC issue to a flight after issuing an approach clearance which wouldn't automatically cancel the approach clearance? Some instructions obviously don't: "Contact tower 123.45", for example. I would think that any instruction which included an altitude restriction, or a heading/route to fly, would. Any other cases which I haven't thought of? Speed restrictions. An altitude restriction can also be issued that wouldn't prevent the completion of the approach. For example, let's say an aircraft was issued clearance for the approach under discussion here with "cross PAGER at or above 3000, cleared RNAV RWY 15 approach." Then a VFR aircraft east of PAGER requests an IFR popup, so the aircraft on the approach is instructed to cross PAGER at or above 4000. 3000 feet is now available for the popup clearance, and the arrival aircraft can still complete it's approach. But, how do I tell, just from what the controller says, if it will prevent the completion of the approach or not? It seems reasonable in the scenario under discussion, that "cross PAGAR at or above 4000" should not be a problem. But what about "Cross ELESE at or above 4000", or "Cross NADSY at or above 4000", or "Cross PAGER at or above 15,000"? Do any of those imply "cancel previous approach clearance?" You use your knowledge and experience as a pilot. |
#40
In article . net,
Steven P. McNicoll wrote: "Roy Smith" wrote in message ... Steven P. McNicoll wrote: "Roy Smith" wrote in message ... Steven P. McNicoll wrote: While "cancel previous approach clearance" is probably a good idea for clarity, it is not required. What instructions/clearances can ATC issue to a flight after issuing an approach clearance which wouldn't automatically cancel the approach clearance? Some instructions obviously don't: "Contact tower 123.45", for example. I would think that any instruction which included an altitude restriction, or a heading/route to fly, would. Any other cases which I haven't thought of? Speed restrictions. An altitude restriction can also be issued that wouldn't prevent the completion of the approach. For example, let's say an aircraft was issued clearance for the approach under discussion here with "cross PAGER at or above 3000, cleared RNAV RWY 15 approach." Then a VFR aircraft east of PAGER requests an IFR popup, so the aircraft on the approach is instructed to cross PAGER at or above 4000. 3000 feet is now available for the popup clearance, and the arrival aircraft can still complete it's approach. But, how do I tell, just from what the controller says, if it will prevent the completion of the approach or not? It seems reasonable in the scenario under discussion, that "cross PAGAR at or above 4000" should not be a problem. But what about "Cross ELESE at or above 4000", or "Cross NADSY at or above 4000", or "Cross PAGER at or above 15,000"? Do any of those imply "cancel previous approach clearance?" You use your knowledge and experience as a pilot. My knowledge and experience as a pilot can tell me whether *I* think I can safely complete the approach or not. They cannot tell me whether my clearance to do so has been revoked. |
VOR/DME Approach Question | Chip Jones | Instrument Flight Rules | 47 | August 29th 04 05:03 AM |
Approach Question- Published Missed Can't be flown? | Brad Z | Instrument Flight Rules | 8 | May 6th 04 04:19 AM |
Procedure Turn | Bravo8500 | Instrument Flight Rules | 65 | April 22nd 04 03:27 AM |
Why is ADF or Radar Required on MFD ILS RWY 32 Approach Plate? | S. Ramirez | Instrument Flight Rules | 17 | April 2nd 04 11:13 AM |
IR checkride story! | Guy Elden Jr. | Instrument Flight Rules | 16 | August 1st 03 09:03 PM |
