#31
![]() "SR20GOER" wrote Slightly OT I know but can someone advise me (since we are talking airspace) - are transponders mandatory to carry and use in Class E airspace in the US? Transponders are required for all registered aircraft, if they were manufactured with an electrical system. -- Jim in NC |
#32
"Morgans" wrote in message
... "SR20GOER" wrote Slightly OT I know but can someone advise me (since we are talking airspace) - are transponders mandatory to carry and use in Class E airspace in the US? Transponders are required for all registered aircraft, if they were manufactured with an electrical system. They are??? Is this a 'new' rule, like aircraft (with electrical) manufactured after a certain year? My Ercoupe (now sold) didn't have a transponder. I could, and did, fly it in any airspace except B (and A :-) ). -Greg B. |
#33
... "SR20GOER" wrote Slightly OT I know but can someone advise me (since we are talking airspace) - are transponders mandatory to carry and use in Class E airspace in the US? Transponders are required for all registered aircraft, if they were manufactured with an electrical system. -- Jim in NC Not required in Class E, G, or D or C BT |
#34
![]() "BT" wrote Not required in Class E, G, or D or C Hmm. I guess I remembered that incorrectly. I wonder where I got that idea. -- Jim in NC |
#35
![]() "BT" wrote in message ... "Morgans" wrote in message ... "SR20GOER" wrote Slightly OT I know but can someone advise me (since we are talking airspace) - are transponders mandatory to carry and use in Class E airspace in the US? Transponders are required for all registered aircraft, if they were manufactured with an electrical system. -- Jim in NC Not required in Class E, G, or D or C BT Unless under the Mode C veil of a Class B airport... i.e. if in Class E, G, C, or D, but within 30 nm of a Class B Airport such as SEA, a transponder is required unless you call the controlling authority (usually by phone) ahead of time to make arrangements. |
#36
![]() "Mxsmanic" wrote in message ... Jarod writes: Newps wrote: Mxsmanic wrote: Newps writes: You can only be in one airspace at a time. At TTD notice the class D circle isn't a full cirlce. It gets cut off where the class C goes to the ground. Yeah, but look at the altitudes. The top of the Class D appears to be _above_ the floor of the Class C that it overlaps. The class C does not exist where the class D does. Are you sure about that? Providence Class C protrudes into Quonset Point class D airspace and the Quonset Tower is very adamant that the overlapping area is Class C and requires communication with Providence. I'm looking at the inset on the Seattle sectional right now. The dotted line of the TTD Class D doesn't extend into the central part of the PDX Class C (where the latter starts at the surface). However, in the two Class C sectors outside that, you see the dotted line of the Class D, and 25 in a box, indicating that the Class D extends up to 2500 feet inclusive. But those two Class C sectors start at 1700 and 2000 feet, both below the ceiling of the Class D. So is 2000 feet Class C, or Class D? -- Transpose mxsmanic and gmail to reach me by e-mail. Should be just like a Class B that has shelves over a Class D, i.e. SEA Class B over Boeing Field (BFI), Class D at BFI goes to 2500, but the Class B starts at 1100, 1800, 2000, and 3000 over various parts of BFI's Class D... In your example/situation from 2000', or where ever the Class C shelf starts, should be Class C. Speculating why they don't put the different Class D ceilings for the different "sectors" might be because then the chart would be more cluttered and more difficult to read, especially while flying. Class C is more "restrictive" than Class D, and thus "overrides" the Class D. You will typically find more IFR traffic and larger planes in Class C than you will in Class D, and typically just plain more traffic in Class C. I believe the person that said "Class C does not exist where the class D does" was only refering to the surface airspaces. |
#37
B A R R Y wrote:
On Sat, 25 Nov 2006 23:59:37 -0500, "Morgans" wrote: Transponders are required for all registered aircraft, if they were manufactured with an electrical system. I respectfully ask for the FAR where that is written. It doesn't exist. The only place where "manufactured with an engine-driven electrical system" appears is in the exemption for the Mode C veil. Transponders are otherwise required there and for everybody inside class A, B, and C, and above 10,000 feet in other controlled airspace. There was an exemption to the transponder rule for class B for certain airplanes without them but it is long expired. You can get temporary waivers on the class B rules by contacting ATC. |
#38
Greg B wrote:
"Morgans" wrote in message My Ercoupe (now sold) didn't have a transponder. I could, and did, fly it in any airspace except B (and A :-) ). Not legally. You can't fly above 10,000 feet in controlled airspace (admittedly a stretch in the 'coupe) nor in class C or within 30 miles of the class B airports. |
#39
BT wrote:
Not required in Class E, G, or D or C Very much required for class C, and D and E when above 10,000' |
#40
B A R R Y wrote in
: On Sat, 25 Nov 2006 23:59:37 -0500, "Morgans" wrote: Transponders are required for all registered aircraft, if they were manufactured with an electrical system. I respectfully ask for the FAR where that is written. http://masl.to/?P28B1534E FAR 91.215 section (b) paragraph (5) (b) All airspace. Unless otherwise authorized or directed by ATC, no person may operate an aircraft in the airspace described in paragraphs (b)(1) through (b)(5) of this section, unless that aircraft is equipped with an operable coded radar beacon transponder having either Mode 3/A 4096 code capability, replying to Mode 3/A interrogations with the code specified by ATC, or a Mode S capability, replying to Mode 3/A interrogations with the code specified by ATC and intermode and Mode S interrogations in accordance with the applicable provisions specified in TSO C–112, and that aircraft is equipped with automatic pressure altitude reporting equipment having a Mode C capability that automatically replies to Mode C interrogations by transmitting pressure altitude information in 100-foot increments. This requirement applies— .... (5) All aircraft except any aircraft which was not originally certificated with an engine-driven electrical system or which has not subsequently been certified with such a system installed, balloon, or glider— |
SPORTS CLASS/CLUB CLASS | 5 ugly | Soaring | 0 | July 2nd 06 11:14 PM |
Air Force One Had to Intercept Some Inadvertent Flyers / How? | Rick Umali | Piloting | 29 | February 15th 06 04:40 AM |
Nearly had my life terminated today | Michelle P | Piloting | 11 | September 3rd 05 02:37 AM |
Carrying flight gear on the airlines | Peter MacPherson | Piloting | 20 | November 25th 04 12:29 AM |
USAF = US Amphetamine Fools | RT | Military Aviation | 104 | September 25th 03 03:17 PM |
