The previous post on this topic got me wondering. Just how different
would the two engines need to be? I'm no expert, but it seems to me cam shaft(s), magnetos, and prop are the parts that would be different from one side to the other. I almost forgot, reverse the polarity on the starter motor. What am I missing? -- Chris W KE5GIX "Protect your digital freedom and privacy, eliminate DRM, learn more at http://www.defectivebydesign.org/what_is_drm" Gift Giving Made Easy Get the gifts you want & give the gifts they want One stop wish list for any gift, from anywhere, for any occasion! http://thewishzone.com |
"Chris W" wrote in message
... The previous post on this topic got me wondering. Just how different would the two engines need to be? I'm no expert, but it seems to me cam shaft(s), magnetos, and prop are the parts that would be different from one side to the other. I almost forgot, reverse the polarity on the starter motor. What am I missing? How about an engine with the crankshaft running out the front and back, so you could mount a prop on the either end? That way you could have counter-rotating props using the same engine. |
Steve Foley writes:
How about an engine with the crankshaft running out the front and back, so you could mount a prop on the either end? That way you could have counter-rotating props using the same engine. There's still some asymmetrical engine torque, since the engine itself turns in only one direction. -- Transpose mxsmanic and gmail to reach me by e-mail. |
Mxsmanic wrote:
Steve Foley writes: How about an engine with the crankshaft running out the front and back, so you could mount a prop on the either end? That way you could have counter-rotating props using the same engine. There's still some asymmetrical engine torque, since the engine itself turns in only one direction. I think he meant you could mount the engine backwards, then it would be spinning the other way. With the crank going out both ends you could mount the prop on it, no mater which way it was in the plane. Seems to be more work than what some twins do now if you ask me. Mounting the engine in backwards, would not a simple matter. -- Chris W KE5GIX "Protect your digital freedom and privacy, eliminate DRM, learn more at http://www.defectivebydesign.org/what_is_drm" Gift Giving Made Easy Get the gifts you want & give the gifts they want One stop wish list for any gift, from anywhere, for any occasion! http://thewishzone.com |
Please do not feed the trolls!
"Mxsmanic" wrote in message
... Steve Foley writes: There's still some asymmetrical engine torque, No, there is not. |
Steve Foley writes:
No, there is not. Unless the engine is weightless and frictionless, it will exert torque on the airframe whenever it is turning, even if there are no props. -- Transpose mxsmanic and gmail to reach me by e-mail. |
Mxsmanic wrote: Steve Foley writes: No, there is not. Unless the engine is weightless and frictionless, it will exert torque on the airframe whenever it is turning, even if there are no props. No, that's not true. If there is no prop, the engine will only exert torque on the airframe when its rotational speed is changing. My mom used to have a 1960-something Buick with a big-ass V8 and a mushy suspension. You could set the thing rocking just by revving the engine in neutral. |
Sorry, but you are wrong here. As long as there is no load external to
the engine, it's own friction torque will have no external manifestation. There will be an external torque, momentarily while the engine is accelerated or de-accelerated. tom Mxsmanic wrote: Steve Foley writes: No, there is not. Unless the engine is weightless and frictionless, it will exert torque on the airframe whenever it is turning, even if there are no props. -- Transpose mxsmanic and gmail to reach me by e-mail. |
![]() Steve Foley wrote: How about an engine with the crankshaft running out the front and back, so you could mount a prop on the either end? That way you could have counter-rotating props using the same engine. Two props mounted on a common crank would turn in the same direction, so they wouldn't be contra-rotating (I assume that is what you meant) but might be counter-rotating if they turn in the opposite direction of the other engine's props. Come to think of it, if an engine had contra-props mounted front & back (like the old Dornier Do X flying boat from the 30's) the props' torque would cancel each other's out but would there still be a torque reaction from the direction of engine rotation? I'm assuming the Do X props were contra-rotating, not 100% sure on that. |
Air Force One Had to Intercept Some Inadvertent Flyers / How? | Rick Umali | Piloting | 29 | February 15th 06 04:40 AM |
Gyrocopter Speed | Mark | Rotorcraft | 36 | August 16th 05 11:28 PM |
Towing | Roger Fowler | Soaring | 6 | August 11th 05 04:25 AM |
What if the germans... | Charles Gray | Military Aviation | 119 | January 26th 04 11:20 PM |
Corky's engine choice | Corky Scott | Home Built | 39 | August 8th 03 04:29 AM |
