#31
On Tue, 5 Dec 2006 17:08:41 -0500, "Capt. Geoffrey Thorpe" The Sea
Hawk at wow way d0t com wrote: So you would suggest the 185 instead? If you're going above a 182 the 205 or 206 would be your best bet in the Cessna line. I'd make sure you had a bunch of dual in it though as it is a much heavier airplane than what you are probably normally used to. HTH. z |
#32
"Jim Carter" wrote in message
news:000e01c718c9$4885a640$4b01a8c0@omnibook6100.. . ... Isn't the gross weight and useful load about the same on the 182 and 185? It has been 30 years since I was in one and then it was on floats at Kenmore in Seattle, so I honestly don't remember. I would however be a little concerned about putting a brand new pilot directly into a 185 without first getting quite a bit of experience in a T-craft or Cub or even a 170. Depends on the model, but from what I can find on the web - 185: gross 3200, empty 1520 with 260 ponies. "Similar" 182: 2650 gross 1650 empty 230 hp. Move up to the 185E: 3300 gross, 1550 empty with 300 up front. 182Q II 3100, 1775, 230 Looks to be about a 500 pound useful advantage. A 205 or 206 makes a real nice 4 place cross country bird, but man it is expensive for just a hop over for coffee. And you are worried about putting someone in a 185? :-) I will admit, you do have to unlearn all the bad habits you develop if you start out in a nosedragger. I watched my dad (after owning Navion's) struggle with that in a C-120 that I thought was the easiest thing to fly ever invented. -- Geoff The Sea Hawk at Wow Way d0t Com remove spaces and make the obvious substitutions to reply by mail When immigration is outlawed, only outlaws will immigrate. |
#33
-----Original Message----- From: Mike Spera ] Posted At: Tuesday, December 05, 2006 6:44 PM Posted To: rec.aviation.owning Conversation: First plane Subject: First plane .... First off, you are a student. Most cannot handle the added distraction of being a new owner while trying to learn how to fly AND taking ground school (aside from your day job/school/family). Also, you admitted yourself you are not sure of what to buy. Get your license and fly a while in other types of birds. Get a feel for where you want to GO first. Mike makes some very good points. I wouldn't really consider buying until after you've got your license, have joined a club or two and have flown several different models. I lusted after the Cardinal RG until I actually flew one. Man was I disappointed in the interior head room. I could not get the seat low enough to keep from constantly rubbing (not occasionally bumping) my head on the overhead. I was absolutely sure that was the bird for me, so I was crushed when I actually discovered they are not for real tall people. Get some experience and then buy if you can justify the hours. You might even find a partnership works well for your missions. |
#34
#35
Cory:
there's an option to download the spreadsheet at the bottom. I don't use IE either, and refuse to get the plugin. |
#36
Fred - you may want to consider a C172 w/180 hp. The extra hp will get
you no more then 5 knots, but what a lift you'll get. Climbs with gross weight (2550 lb) easily 1000 fpm. I have LRT, which allows me at about 65% bhp to cruise for 5 hours. Don't know if your bladder will hold up, but it's very close to you specs. My payload is 735 lb. That's not a bad payload figure. With the same hp in a Piper, you will not get close to this figure or the 1000 fpm either. I burn about 9.5, but use 10 gph. Now if go to a C182, you will get close to the same payload, but burn rate is much more and the cost to maintain is great. I love my hybrid fred wrote: I'm a newbie working on getting a PPL. People tell me that if I'm serious about flying, I should seriously look into purchasing a plane - in the long run it'll be cheaper than renting. If I buy (used, of course, but I'm open to the possibility of joint ownerships/partnerships), I'd need something that seats 4 adults and a small amount of luggage. Expected useage would be trips of a few hundred to about 500 miles. I'm learning in a Cessna 152. My gut tells me that I'd like something with a bit more speed than a C172, but I'm not seeking a high performance aircraft. High wing vs low wing is not a major issue. Cost could be an issue. What I seek is a table laying out performance and payload characteristics for your basic single engine prop planes. So what is the airplane equivalent of a Toyota Corolla or Honda Civic? Thanks in advance. |
#37
5pguy wrote:
Fred - you may want to consider a C172 w/180 hp. The extra hp will get you no more then 5 knots, but what a lift you'll get. Climbs with gross weight (2550 lb) easily 1000 fpm. I have LRT, which allows me at about 65% bhp to cruise for 5 hours. Don't know if your bladder will hold up, but it's very close to you specs. My payload is 735 lb. That's not a bad payload figure. With the same hp in a Piper, you will not get close to this figure or the 1000 fpm either. I burn about 9.5, but use 10 gph. Now if go to a C182, you will get close to the same payload, but burn rate is much more and the cost to maintain is great. /pedantry on You must mean your "payload with full fuel" is 735 lbs. Otherwise with 5 hours of fuel at 10 gal/hr that's 600 lbs and leaves only 135 lbs. for passengers or freight. "Payload" is usually used to mean the total weight of fuel, passengers, and freight, so that you can adjust the amount of fuel carried to fit the mission. Payload is a better measure of an aircraft's capability than "payload with full fuel". /pedantry off DB |
#38
Mike Spera wrote:
First off, you are a student. Most cannot handle the added distraction of being a new owner while trying to learn how to fly AND taking ground school (aside from your day job/school/family). I call BS on that. I bought a grumman cheetah while learning to fly. It was a great learning experience. Where do you get the data for "most cannot handle the added distraction?" Also, you admitted yourself you are not sure of what to buy. Get your license and fly a while in other types of birds. Get a feel for where you want to GO first. I agree with this. Buying an airplane without losing your shirt (and possibly your life) takes a bit of experience that you likely don't have. What's the hurry? The only way to get that experience and knowledge is to go through the process of looking and buying. Renting for years does not make anyone more qualified to purchase an airplane compared to a newbie looking to buy. Why beat up your bird learning how to land? Beat up the school's plane, then buy your own. Perhaps - but with good instruction and the fact that you have better understanding of the plane makes it a wash. "Cheaper in the long run" can be elusive. You need to fly a certain number of hours for the math to work out. Properly cared for airplanes cost money. Many owners simply run planes out and don't properly maintain or upgrade them. They live on a shoestring budget and roll the dice that nothing catastrophic will happen. Some win and some lose. The winners spout off about how "they did it". The losers say nothing and quietly lick their wounds. I have said it before. There is plenty of flying junk out there for sale. You likely cannot tell the difference. This group tells many tales about deals gone bad. What if you don't stick it out? The drop out rate for student pilots is not small. If you quit while owning, you have to sell the beast and that may take a while (unless you can accept a significant financial loss). Yes, renting has many drawbacks. Dirty, beat up planes that are unavailable when the weather is nice. But, they are usually maintained to some minimum level of safety and they have one great advantage that you might need right now. If anything goes wrong, you simply hand the keys to the FBO and say "next". And, like I said, you really don't need a premium airplane and the distractions of ownership at this point in your flying. Opinions vary. Good Luck. Mike All the rest I pretty much agree. It is not something to undertake lightly. Best wishes to the OP. |
#39
There isn't any real airplane equivalent to the Corolla or Civic.
Those machines provide high quality for reasonable price. 172s and Cherokees are the closest to mass produced airplanes, but they are more like Fords and Chevys - they're noisy, they corrode and leak, and cost a lot to maintain, particularly if you live in an urban area. As others have said, you need to fly at least 100 hrs a year to break even, and that's a lot of flying. Having said that, there is nothing like owning a well maintained airplane. I started looking for one of my own when every airplane I rented seemed to have something on the squawk list. |
#40
"fred" == fred writes:
fred I'm a newbie working on getting a PPL. People tell me that fred if I'm serious about flying, I should seriously look into fred purchasing a plane - in the long run it'll be cheaper than fred renting. Yes, but after your initial training. fred I'd need something that seats 4 adults and a small amount of fred luggage. Expected useage would be trips of a few hundred to fred about 500 miles. Keep in mind that most aircraft can't realistically fill the seats they have: you'll be overweight typically. Especially as Americans have supersized themselves since these aircraft were designed and built. So if you want to fly 4 adults, even without luggage, they better be slim and trim OR you will need a 6-seater OR you will need a real hauler airplane, like the C-182. Also, it might be slower, door-to-door timing, to fly to places instead of driving, less than 300-400 miles away, depending on a number of factors. fred What I seek is a table laying out performance and payload fred characteristics for your basic single engine prop planes. There are some books out there that offer this information, though not as handy as a single table. fred So what is the airplane equivalent of a Toyota Corolla or fred Honda Civic? Well, that's the problem. There are no Toyotas or Hondas in the used airplane market, only 25-50 year old Fords, Chevys, and Buicks. And a few of us on these groups remember how much maintenance the old cars required. You're doing the right thing. Continue to take your flight training and also continue to investigate a plane that fills your needs. I don't know how much money you're willing to spend, but you'll probably find that the initial cost, in the long run, isn't the big factor, though it naturally seems so. Instead, it's the operating and annual fixed costs, which you won't recoup, that you should be watching. Others will know the different planes and performance better than I, but it sounds like you might want to look at a C-182, or equivalent in the low wing aircraft. -- "If you give someone a program, you will frustrate them for a day; if you teach them how to program, you will frustrate them for a lifetime." |
| Thread Tools | |
| Display Modes | |
| Passenger crash-lands plane after pilot suffers heart attack | R.L. | Piloting | 7 | May 8th 05 12:17 AM |
| rec.aviation.aerobatics FAQ | Dr. Guenther Eichhorn | Aerobatics | 0 | October 1st 03 08:27 AM |
| rec.aviation.aerobatics FAQ | Dr. Guenther Eichhorn | Aerobatics | 0 | September 1st 03 08:27 AM |
| rec.aviation.aerobatics FAQ | Dr. Guenther Eichhorn | Aerobatics | 0 | August 1st 03 08:27 AM |
